前言
树莓派在控制外部硬件设备上还真有那么些时候,今天就又踩到了(其实这里有越复杂的问题解决了)。 ws2812 网上一搜几乎都是用的 rpi-ws281x 看看这个库 安装 还是比较简单的 sudo pip3 install rpi-ws281x 官方 示例程序的示例程序,这是一个名为 strandtest.py 的示例程序 当然还有其他的示例程序Github 链接 #!/usr/bin/env python3 # NeoPixel library strandtest example # Author: Tony DiCola (tony@tonydicola.com) # # Direct port of the Arduino NeoPixel library strandtest example. Showcases # various animations on a strip of NeoPixels. import time from rpi_ws281x import PixelStrip, Color import argparse # LED strip configuration: LED_COUNT = 16 # Number of LED pixels. LED_PIN = 18 # GPIO pin connected to the pixels (18 uses PWM!). # LED_PIN = 10 # GPIO pin connected to the pixels (10 uses SPI /dev/spidev0.0). LED_FREQ_HZ = 800000 # LED signal frequency in hertz (usually 800khz) LED_DMA = 10 # DMA channel to use for generating signal (try 10) LED_BRIGHTNESS = 255 # Set to 0 for darkest and 255 for brightest LED_INVERT = False # True to invert the signal (when using NPN transistor level shift) LED_CHANNEL = 0 # set to '1' for GPIOs 13, 19, 41, 45 or 53 # Define functions which animate LEDs in various ways. def colorWipe(strip, color, wait_ms=50): """Wipe color across display a pixel at a time.""" for i in range(strip.numPixels()): strip.setPixelColor(i, color) strip.show() time.sleep(wait_ms / 1000.0) def theaterChase(strip, color, wait_ms=50, iterations=10): """Movie theater light style chaser animation.""" for j in range(iterations): for q in range(3): for i in range(0, strip.numPixels(), 3): strip.setPixelColor(i + q, color) strip.show() time.sleep(wait_ms / 1000.0) for i in range(0, strip.numPixels(), 3): strip.setPixelColor(i + q, 0) def wheel(pos): """Generate rainbow colors across 0-255 positions.""" if pos < 85: return Color(pos * 3, 255 - pos * 3, 0) elif pos < 170: pos -= 85 return Color(255 - pos * 3, 0, pos * 3) else: pos -= 170 return Color(0, pos * 3, 255 - pos * 3) def rainbow(strip, wait_ms=20, iterations=1): """Draw rainbow that fades across all pixels at once.""" for j in range(256 * iterations): for i in range(strip.numPixels()): strip.setPixelColor(i, wheel((i + j) & 255)) strip.show() time.sleep(wait_ms / 1000.0) def rainbowCycle(strip, wait_ms=20, iterations=5): """Draw rainbow that uniformly distributes itself across all pixels.""" for j in range(256 * iterations): for i in range(strip.numPixels()): strip.setPixelColor(i, wheel( (int(i * 256 / strip.numPixels()) + j) & 255)) strip.show() time.sleep(wait_ms / 1000.0) def theaterChaseRainbow(strip, wait_ms=50): """Rainbow movie theater light style chaser animation.""" for j in range(256): for q in range(3): for i in range(0, strip.numPixels(), 3): strip.setPixelColor(i + q, wheel((i + j) % 255)) strip.show() time.sleep(wait_ms / 1000.0) for i in range(0, strip.numPixels(), 3): strip.setPixelColor(i + q, 0) # Main program logic follows: if __name__ == '__main__': # Process arguments parser = argparse.ArgumentParser() parser.add_argument('-c', '--clear', action='store_true', help='clear the display on exit') args = parser.parse_args() # Create NeoPixel object with appropriate configuration. strip = PixelStrip(LED_COUNT, LED_PIN, LED_FREQ_HZ, LED_DMA, LED_INVERT, LED_BRIGHTNESS, LED_CHANNEL) # Intialize the library (must be called once before other functions). strip.begin() print('Press Ctrl-C to quit.') if not args.clear: print('Use "-c" argument to clear LEDs on exit') try: while True: print('Color wipe animations.') colorWipe(strip, Color(255, 0, 0)) # Red wipe colorWipe(strip, Color(0, 255, 0)) # Green wipe colorWipe(strip, Color(0, 0, 255)) # Blue wipe print('Theater chase animations.') theaterChase(strip, Color(127, 127, 127)) # White theater chase theaterChase(strip, Color(127, 0, 0)) # Red theater chase theaterChase(strip, Color(0, 0, 127)) # Blue theater chase print('Rainbow animations.') rainbow(strip) rainbowCycle(strip) theaterChaseRainbow(strip) except KeyboardInterrupt: if args.clear: colorWipe(strip, Color(0, 0, 0), 10) 测试 新建一个py文件,copy上面那个示例程序,使用命令行运行 (直接在IDE运行会报错,目前不知道解决办法) 比如 我建的名字为 test.py, 放在了桌面 cd Desktop sudo python3 test.py 虽然没报错,但是灯是没有任何反应的,经过一番查找,在这里找到了原因,原来需要关闭音频输出。。。。。。 解决办法 打开终端运行 sudo nano /etc/modprobe.d/snd-blacklist.conf 添加下列语句 blacklist snd_bcm2835 ctrl+o保存 ctrl+x退出 修改conf.txt文件 sudo nano /boot/config.txt 找到下列语句(一般是在最下面) # Enable audio (loads snd_bcm2835) dtparam=audio=on 注释掉第二行 # Enable audio (loads snd_bcm2835) #dtparam=audio=on ctrl+o保存 ctrl+x退出 重启 sudo reboot 再次运行程序,可以成功点亮 |
3794 浏览 0 评论
3560 浏览 9 评论
3212 浏览 16 评论
3729 浏览 1 评论
9525 浏览 16 评论
1648浏览 3评论
3210浏览 3评论
713浏览 1评论
Banana Pi BPI-PicoW 和 BPI-Leaf-S3 创客教育与物联网开发板介绍
10641浏览 0评论
请问SEGGER Embedded Studio for ARM 7.32怎么实现代码自动补全功能
7700浏览 0评论
GMT+8, 2025-7-15 05:53 , Processed in 2.785643 second(s), Total 77, Slave 58 queries .
