扫一扫,分享给好友
开机
$KARMARMCCbinfromelf.exe --bin --output=.out bin@L.bin !L
/******************************************************************************** * @file main.c * @author jianqiang.xue * @Version V1.0.0 * @Date 2021-04-03 * @brief ********************************************************************************/ #include #include "cx32l003_hal.h" #include "bsp_system_clock.h" #include "bsp_key.h" #include "bsp_uart.h" #include "business_gpio.h" #define APP_TARGET_ADDR (BS_FLASH_BOOT_SIZE + BS_FLASH_USER_INFO_SIZE) typedef void (*p_func)(void); p_func jump_app; uint32_t jump_addr; void hardware_init(void) { /* Configure the system clock to HIRC 24MHz*/ bsp_system_clock_config(); bsp_button_init(); bsp_uart_init(); } /* * main: initialize and start the system */ int main(void) { hardware_init(); printf("runrn"); if (bsp_button_get_state(BSP_BUTTON_0) == 0) { boot: printf("bootrn"); } else { HAL_NVIC_DisableIRQ(UART0_IRQn); bsp_uart0_deinit(); bsp_button_deinit(BSP_BUTTON_0); if (((*(__IO uint32_t*)APP_TARGET_ADDR) & 0x2FFE0000 ) == 0x20000000) { /* jump to user application */ jump_addr = *(__IO uint32_t*) (APP_TARGET_ADDR + 4); jump_app = (p_func) jump_addr; /* initialize user application's stack pointer */ __set_PSP(*(__IO uint32_t*) APP_TARGET_ADDR); __set_CONTROL(0); __set_MSP(*(__IO uint32_t*) APP_TARGET_ADDR); jump_app(); } goto boot; } while(1); } APP
$KARMARMCCbinfromelf.exe --bin --output=.outbin@L.bin !L
/******************************************************************************** * @file main.c * @author jianqiang.xue * @Version V1.0.0 * @Date 2021-04-03 * @brief ********************************************************************************/ #include #include "os_api.h" #include "bsp_system_clock.h" #include "bsp_led.h" #include "bsp_key.h" #include "bsp_adc.h" #include "bsp_i2c.h" #include "bsp_uart.h" #include "app_key.h" #include "business_function.h" extern uint8_t app_main_init(void); void hardware_init(void) { /* Configure the system clock to HIRC 24MHz*/ bsp_system_clock_config(); bsp_led_init(); bsp_button_init(); bsp_adc0_init(); bsp_i2c_init(); bsp_uart_init(); } /* * main: initialize and start the system */ int main(void) { hardware_init(); os_kernel_initialize(); app_key_init(); app_main_init(); os_kernel_start(); }
#define VECT_TAB_OFFSET (0)改: #define VECT_TAB_OFFSET (BS_FLASH_BOOT_SIZE + BS_FLASH_USER_INFO_SIZE) |
633 浏览 0 评论
3336 浏览 9 评论
3013 浏览 16 评论
3506 浏览 1 评论
9098 浏览 16 评论
1216浏览 3评论
631浏览 2评论
619浏览 2评论
2361浏览 2评论
1925浏览 2评论
GMT+8, 2025-1-11 05:30 , Processed in 0.812125 second(s), Total 46, Slave 38 queries .
