在观察内核编译日志过程中,注意到日志
```txt DTC arch/arm/boot/dts/sun8iw11p1-FPGA.dtb Error: arch/arm/boot/dts/sun8iw11p1.dtsi:1016.21-22 syntax error FATAL ERROR: Unable to parse input tree scripts/Makefile.lib:278: recipe for target 'arch/arm/boot/dts/sun8iw11p1-fpga.dtb' failed make[1]: *** [arch/arm/boot/dts/sun8iw11p1-fpga.dtb] Error 1 /home/ubuntu/proj/a40i/src/lichee/linux-3.10.65-merge-test/arch/arm/Makefile:296: recipe for target 'dtbs' failed make: *** [dtbs] Error 2 make: *** Waiting for unfinished jobs.... CC drivers/mmc/card/block.o ``` 虽然最终内核仍然会编译出来,但这个`dtb`文件是否有语法问题?能修改正确吗? |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
2531 浏览 0 评论
2818 浏览 1 评论
2308 浏览 1 评论
3639 浏览 1 评论
4390 浏览 1 评论
GMT+8, 2025-1-24 13:47 , Processed in 0.451869 second(s), Total 39, Slave 33 queries .
