1、我的程序snd_pcm_open(&pcm, "default", SND_PCM_STREAM_CAPTURE, 0);
返回错误,报以下错。 ALSA lib pcm_hw.c:1788:(_snd_pcm_hw_open) Unknown field slave 这是怎么回事? 2、还有我用的alsa的库文件,放在系统源文件的什么位置? |
root@ubuntu:~/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/include/external/include/alsa# ls
alisp.h asoundlib.h conf.h global.h local.h output.h pcm_ioplug.h rawmidi.h seqmid.h timer.h version.h alsa-symbols.h asoundlib-head.h control_external.h hwdep.h Makefile.am pcm_external.h pcm_old.h search.h seq_midi_event.h topology.h aserver.h asoundlib-tail.h control.h input.h mixer_abst.h pcm_extplug.h pcm_plugin.h seq_event.h sound type_compat.h asoundef.h bswap.h error.h list.h mixer.h pcm.h pcm_rate.h seq.h sys.h use-case.h root@ubuntu:~/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build# ls alsa-lib-1.1.2 bash-4.3.30 expat-2.2.0 host-gettext-0.19.8.1 host-m4-1.4.17 host-util-linux-2.28.2 libsndfile-1.0.27 readline-6.3 zlib-1.2.8 alsa-utils-1.1.2 buildroot-config host-autoconf-2.69 host-libffi-3.2.1 host-ncurses-5.9 host-zlib-1.2.8 ncurses-5.9 skeleton attr-2.4.47 build-time.log host-automake-1.15 host-libglib2-2.50.1 host-pcre-8.39 libffi-3.2.1 packages-file-list.txt toolchain audiofile-0.3.6 busybox-1.25.1 host-bison-3.0.4 host-libtool-2.4.6 host-pkgconf-0.9.12 libglib2-2.50.1 pcre-8.39 toolchain-external aumix-2.9.1 dbus-1.10.12 host-expat-2.2.0 host-libxml2-2.9.4 host-python-2.7.13 libsamplerate-0.1.8 python-2.7.13 util-linux-2.28.2 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
3251 浏览 0 评论
3088 浏览 1 评论
2565 浏览 1 评论
3903 浏览 1 评论
4634 浏览 1 评论
GMT+8, 2025-2-2 18:17 , Processed in 0.702940 second(s), Total 70, Slave 54 queries .
