18.4环境下,装了path,按教程整体编译出错 >>> libglib2 2.50.1 Building PATH="/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/***in:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/***in:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/:/usr/local/***in:/usr/local/bin:/usr/***in:/usr/bin:/***in:/bin:/snap/bin:/usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin" /usr/bin/make -j5 -C /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/ make[1]: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1' cd . && /bin/sh /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/missing automake-1.15 --gnu Makefile Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/${ <-- HERE ([^ t=:+{}]+)}/ at /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake-1.15 line 3936. Makefile:862: recipe for target 'Makefile.in' failed make[1]: *** [Makefile.in] Error 255 make[1]: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1' package/pkg-generic.mk:216: recipe for target '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built' failed make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built] Error 2 make: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611' ERROR: build buildroot Failed root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# |
我们buildroot源码不开源的,源码里没有这部分源码
1、18.04整体编译,需要装上开发环境资料里的patch,安装方法可以参考资料里的pdf文件。
2、您编译的时候是用的出厂镜像还是自己做过修改,我这边用出厂镜像测过,没出现buildroot的报错。 3、另外您是为什么用全编译?如果不用buildroot,不建议全编译,只要涉及到编译内核,就单独编译内核,打包文件系统,最后pack成img就可以了,没必要全编译的 |
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
979 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1104 浏览 0 评论
503 浏览 0 评论
473 浏览 0 评论
777 浏览 0 评论
GMT+8, 2025-2-23 21:02 , Processed in 0.468096 second(s), Total 74, Slave 58 queries .
