imx6q 开发板, 使用forlinx.com 上对应的内核linux 4.1.15-2018.10.23, uboot-2016.03-r0, 插入pcie2.0的卡开机后,dmesg报错:
[ 3.475296] 1ffc000.pcie supply pcie-bus not found, using dummy regulator [ 3.808893] imx6q-pcie 1ffc000.pcie: phy link never came up [ 3.814490] imx6q-pcie 1ffc000.pcie: failed to initialize host [ 3.820432] imx6q-pcie: probe of 1ffc000.pcie failed with error -22 这个该如何解决? 配置的pci 相关选项: CONFIG_PCI_QUIRKS=y CONFIG_PCI=y CONFIG_PCI_DOMAINS=y CONFIG_PCI_DOMAINS_GENERIC=y CONFIG_PCI_SYSCALL=y CONFIG_PCI_MSI=y CONFIG_PCI_DEBUG=y CONFIG_PCI_REALLOC_ENABLE_AUTO=y # CONFIG_PCI_STUB is not set CONFIG_PCI_ATS=y # CONFIG_PCI_IOV is not set CONFIG_PCI_PRI=y CONFIG_PCI_PASID=y CONFIG_PCIE_DW=y CONFIG_PCI_IMX6=y CONFIG_PCI_IMX6_COMPLIANCE_TEST=y # CONFIG_PCI_IMX_EP_DRV is not set # CONFIG_PCI_HOST_GENERIC is not set # CONFIG_PCI_LAYERSCAPE is not set # CONFIG_PCIE_IPROC is not set CONFIG_PCIEPORTBUS=y CONFIG_PCIEAER=y # CONFIG_PCIE_ECRC is not set CONFIG_PCIEAER_INJECT=y CONFIG_PCIEASPM=y CONFIG_PCIEASPM_DEBUG=y CONFIG_PCIEASPM_DEFAULT=y # CONFIG_PCIEASPM_POWERSAVE is not set # CONFIG_PCIEASPM_PERFORMANCE is not set CONFIG_PCIE_PME=y # CONFIG_PCIPCWATCHDOG is not set |
3个回答
您好,您接的什么卡,是否能够识别设备?
我用的是zynq 的卡,这个卡本身在x86主机上是可以正常识别的, 现在在板子上无法识别,总线本身初始化就过不去,还没开始枚举设备的代码
1684 浏览 3 评论
rk1126实现BT601输入,输入不带IIC接口的驱动程序
3449 浏览 0 评论
2301 浏览 1 评论
3522 浏览 3 评论
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
3794 浏览 1 评论
GMT+8, 2024-9-22 07:23 , Processed in 0.398125 second(s), Total 43, Slave 38 queries .
