我想保留网口1,去掉网口二,但是fec2disabled后第一个网口也不能用了,请问该怎么配置? 295 &fec1 { 296 pinctrl-names = "default";
297 pinctrl-0 = <&pinctrl_enet1>; 298 phy-mode = "rmii"; 299 phy-handle = <ðphy0>; 300 status = "okay"; 301 }; 302 303 &fec2 { 304 pinctrl-names = "default"; 305 pinctrl-0 = <&pinctrl_enet2>; 306 phy-mode = "rmii"; 307 phy-handle = <ðphy1>; 308 status = "disabled"; 309 310 mdio { 311 #address-cells = <1>; 312 #size-cells = <0>; 313 314 ethphy0: ethernet-phy@2 { 315 compatible = "ethernet-phy-ieee802.3-c22"; 316 reg = <2>; 317 }; 318 319 ethphy1: ethernet-phy@1 { 320 compatible = "ethernet-phy-ieee802.3-c22"; 321 reg = <1>; 322 }; 323 }; 324 }; 848 pinctrl_enet1: enet1grp { 849 fsl,pins = < 850 MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 851 MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0 852 MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 853 MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 854 MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 855 MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 856 MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 857 MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031 858 >; 859 }; 875 pinctrl_enet2: enet2grp { 876 fsl,pins = < 877 MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0 878 MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0 879 MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0 880 MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0 881 MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0 882 MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0 883 MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0 884 MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0 885 MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0 886 MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031 887 MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x80000000 888 >; 889 }; |
4个回答
两个网口共用mdio,mdio在&fec2里,关掉就不能用了,需要改一下
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
979 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1104 浏览 0 评论
503 浏览 0 评论
473 浏览 0 评论
777 浏览 0 评论
GMT+8, 2025-2-23 21:38 , Processed in 0.705566 second(s), Total 76, Slave 60 queries .
