我想两个摄像头同时启动录像,我将用户配置修改如下, v4l2_scheme.useClipper0 = true;
v4l2_scheme.useDecimator0 = true; v4l2_scheme.useMlc0Video = true; v4l2_scheme.useClipper1 = true; v4l2_scheme.useDecimator1 = true; v4l2_scheme.useMlc0Video = true; 不能同时录像,但是如果useDecimator0 和useDecimator1 单独配置为true的话,相应的摄像头可以录像。 请问谁碰到过这种问题没? |
4个回答
从板子设计的话,设计两个摄像头接口,而不能同时浏览的话,感觉这种双摄像头设计有点多余,是驱动不支持还是硬件不支持啊
从官方的下面代码看,感觉是支持两个摄像头的,是不是还有其它的地方需要配置
int V4l2NexellPrivate::linkDefault() { int ret; if (SubdevUsage.useSensor0) { if (CameraInfo[0].IsMIPI) { // link sensor0 -> mipicsi if (!SubdevUsage.useMipiCSI) { ALOGE("%s: invalid SubDevUsageScheme!!!, sensor0 is mipi, but mipi not included", __func__); return -EINVAL; } ret = link(Sensor0, MipiCSI); if (ret) { ALOGE("%s: failed to link Sensor0 to MipiCSI", __func__); return ret; } ret = link(MipiCSI, Clipper0); if (ret) { ALOGE("%s: failed to link MipiCSI to Clipper0", __func__); return ret; } } else { ret = link(Sensor0, Clipper0); if (ret) { ALOGE("%s: failed to link Sensor0 to Clipper0", __func__); return ret; } } } if (SubdevUsage.useSensor1) { if (CameraInfo[1].IsMIPI) { // link sensor1 -> mipicsi if (!SubdevUsage.useMipiCSI) { ALOGE("%s: invalid SubDevUsageScheme!!!, sensor1 is mipi, but mipi not included", __func__); return -EINVAL; } ret = link(Sensor1, MipiCSI); if (ret) { ALOGE("%s: failed to link Sensor1 to MipiCSI", __func__); return ret; } ret = link(MipiCSI, Clipper1); if (ret) { ALOGE("%s: failed to link MipiCSI to Clipper1", __func__); return ret; } } else { ret = link(Sensor1, Clipper1); if (ret) { ALOGE("%s: failed to link Sensor1 to Clipper1", __func__); return ret; } } } if (UsageScheme.useDecimator0) { ret = link(Clipper0, Decimator0); if (ret) return ret; } if (UsageScheme.useDecimator1) { ret = link(Clipper1, Decimator1); if (ret) return ret; } return 0; } |
1659 浏览 0 评论
618 浏览 0 评论
Onenet云网关方案应用--基于米尔瑞芯微RK3576开发板
1189 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】Redis最新8.0.2版本源码安装及性能测试
1924 浏览 0 评论
2087 浏览 0 评论
GMT+8, 2025-7-15 05:04 , Processed in 0.958213 second(s), Total 46, Slave 40 queries .
