首先我查看网络信息发现eth0并未启动
# ifconfig lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:130 errors:0 dropped:0 overruns:0 frame:0 TX packets:130 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:421536 (411.6 KiB) TX bytes:421536 (411.6 KiB) 尝试查看所有的网卡信息 # ifconfig -a eth0 Link encap:Ethernet HWaddr 1E:C6:7C:5C:64:25 inet addr:192.168.1.163 Bcast:192.168.1.255 Mask:255.255.255.0 BROADCAST MULtiCAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Interrupt:48 ip6tnl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 -00 NOARP MTU:1452 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:130 errors:0 dropped:0 overruns:0 frame:0 TX packets:130 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:421536 (411.6 KiB) TX bytes:421536 (411.6 KiB) sit0 Link encap:IPv6-in-IPv4 NOARP MTU:1480 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) 尝试启动eth0 # ifconfig eth0 up [ 1715.953000] eth0: device MAC address 1e:c6:7c:5c:64:25 [ 1716.047000] nxpmac_hw_setup: DMA engine initialization failed [ 1716.053000] stmmac_open: Hw setup failed ifconfig: SIOCSIFFLAGS: Device or resource busy 我应该如何解决? |
是核心板和底板接触不良
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1106 浏览 0 评论
1278 浏览 1 评论
993 浏览 1 评论
2293 浏览 1 评论
3619 浏览 1 评论
GMT+8, 2024-12-29 17:48 , Processed in 0.677080 second(s), Total 72, Slave 56 queries .
