TF卡座能烧写镜像,SD卡也能正常识别,但是插入SDIO接口的网卡就不能识别,寻问威廉希尔官方网站
人员,答复只是说MMC3支持网卡,MMC1默认不支持,需要自己修改设备树文件ok5718-idk.dts,参考MMC3来配置MMC1,但是我这边搞了很久都没有成功。请问有人用SD卡座来接SDIO设备吗?或者有没有大佬会修改设备树?
下面是原版设备树: &mmc1 { pinctrl-names = "default", "hs", "sdr12", "sdr25", "sdr50", "ddr50"; pinctrl-0 = <&mmc1_pins_default>; pinctrl-1 = <&mmc1_pins_hs>; pinctrl-2 = <&mmc1_pins_sdr12>; pinctrl-3 = <&mmc1_pins_sdr25>; pinctrl-4 = <&mmc1_pins_sdr50>; pinctrl-5 = <&mmc1_pins_ddr50_rev20 &mmc1_iodelay_ddr50_conf>; pinctrl-6 = <&mmc1_pins_sdr104 &mmc1_iodelay_sdr104_rev20_conf>; vmmc-supply = <&vcc3_3>; vmmc_aux-supply = <&ldo1_reg>; bus-width = <4>; cd-gpios = <&gpio6 27 1>; /* gpio 219 */ status = "okay"; /delete-property/ sd-uhs-sdr104; }; &mmc2 { pinctrl-names = "default", "hs", "ddr_1_8v"; pinctrl-0 = <&mmc2_pins_default>; pinctrl-1 = <&mmc2_pins_hs>; pinctrl-2 = <&mmc2_pins_ddr_rev20 &mmc2_iodelay_ddr_conf>; status = "okay"; vmmc-supply = <&v3_3d>; bus-width = <8>; ti,non-removable; max-frequency = <96000000>; no-1-8-v; /delete-property/ mmc-hs200-1_8v; /delete-property/ sd-uhs-sdr25; /delete-property/ sd-uhs-sdr12; }; &mmc3 { pinctrl-names = "default", "hs"; pinctrl-0 = <&mmc3_pins_default>; pinctrl-1 = <&mmc3_pins_hs>; status = "okay"; vmmc-supply = <&v3_3d>; bus-width = <4>; ti,non-removable; cap-sdio-irq; max-frequency = <50000000>; no-1-8-v; /delete-property/ sd-uhs-sdr50; /delete-property/ sd-uhs-sdr25; /delete-property/ sd-uhs-sdr12; }; |
5718的cpu手册上关于MMC接口对SDIO的描述如上图,其中MMC1是用做SD,MMC2用做eMMC,MMC3/4用做SDIO,手册的描述是MMC接口所有模式的都支持,但是默认的配置不一样,如果使用的和这个不一样,这样就要修改内核和设备树配置了,具体手册位于:用户资料-20190612原厂资料spruhz7f.pdf关于具体的配置只能是参考mmc1的配置来做,如果还是不行,可以到ti官方论坛咨询:https://e2echina.ti.com/
436 浏览 0 评论
1477 浏览 3 评论
RK 主流平台参数对比文档:助力设计阶段快速选型(包含RK3588 RK3588S RK3588S2 RK3576 RK3568)
1077 浏览 0 评论
行业集结:共同定制 RK3566 集成 AI 眼镜的前沿 AR 方案
1701 浏览 1 评论
816 浏览 0 评论
GMT+8, 2025-3-6 03:38 , Processed in 0.360109 second(s), Total 41, Slave 36 queries .
