创建了 1175/16384 个 inode 和 5079/65536 个块的文件系统
rm -f /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls10461_64b/ls10461_64b工作/ OK104x-Linux的OpenWrt的-C2 / build_dir /目标aarch64_generic_musl / Linux的layerscape_armv8_64b / vmlinux中的/ home / forlinx /工作/ OK104x-Linux的OpenWrt的-C2 / build_dir /目标aarch64_generic_musl / Linux的layerscape_armv8_64b / vmlinux中的.bin 的gzip -9n -c /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin > /home/forlinx/work/OK104x-linux-openwrt -C2/ build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin.new mkimage -A arm64 -O linux -T 内核 -C gzip -a 0x80080000 -e 0x80080000 -n 'ARM64 LEDE Linux-4.9.63' -d /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target -aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb- kernel.bin /home/forlinx/work/OK104x -linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046_64b/ls1046 /home/forlinx/work/OK104x -linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin -4.9.63 创建时间:2020年12月16日星期三 06:14:46 图片类型:AArch64Linux压缩) 数据大小:7278345 字节 = 7107.76 kB = 6.94 MB 加载地址:80080000 入口点:8000 mv /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin.new /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir -aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin [ -f /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/xlinx /OK104x- /OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/root.squashfs] rm -f /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target -aarch64/generic_layervscapel /tmp/lede-layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin dd if=/home/forlinx/work/OK104x-linux-openwrt-C2/staging_dir/target-aarch64_generic_musl/image/ls1046ardb-rcw.bin >> /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/ target-aarch64_generic_musl/linux-layerscape_armv8_64b/tmp/lede-layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin dd:无法打开'/home/forlinx/work/OK104x-linux-openwrt-C2/target-64-geneaarch10 -firmware.bin image/ls1046ardb-rcw.bin': 没有那个文件或目录 Makefile:170: 目标的配方'/home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b /tmp/lede -layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin' 失败 make[5]: *** [/home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/tmp/lede-layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin。错误 1 make[5]: Leaving directory '/home/forlinx/work/OK104x-linux-openwrt-C2/target/linux/layerscape/image' Makefile:25: 目标 'install' 的配方失败 make[4]: * ** [install] 错误 2 make[4]:离开目录 '/home/forlinx/work/OK104x-linux-openwrt-C2/target/linux/layerscape' Makefile:13:目标 'install' 的配方失败 make[3 ]: *** [install] Error 2 make[3]: Leaving directory '/home/forlinx/work/OK104x-linux-openwrt-C2/target/linux' target/Makefile:23: 目标'target/linux的配方/安装失败 make[2]: *** [target/linux/install] 错误 2 make[2]:离开目录'/home/forlinx/work/OK104x-linux-openwrt-C2' target/Makefile:19: 目标'/home/forlinx/work/OK104x-linux-openwrt-C2/staging_dir/的配方target-aarch64_generic_musl/stamp/.target_install' make [1]失败:*** [/home/forlinx/work/OK104x-linux-openwrt-C2 /staging_dir/target-aarch64_generic_musl/stamp/.target_install] 错误 2 make[1 ]:离开目录'/home/forlinx/work/OK104x-linux-openwrt-C2' /home/forlinx/work/OK104x-linux-openwrt-C2/include/toplevel.mk:216:目标'world'的配方失败 make: *** [world] Error 2 源码解压没有添加编译。 编译出的bin文件用什么方式刷入开发板? |
6个回答
建议您再多编译一次,openwrt 编译不是很容易通过
建议您再多编译一次,openwrt 编译不是很容易通过。
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
3237 浏览 0 评论
3081 浏览 1 评论
2559 浏览 1 评论
3897 浏览 1 评论
4629 浏览 1 评论
GMT+8, 2025-2-2 12:19 , Processed in 0.732235 second(s), Total 80, Slave 64 queries .
