按照A40I-Linux入门使用说明中的相关文件进行代码编译
进入源码路径, 执行./build.sh config 进行选择,选择后执行 ./build.sh 出现错误,错误提示信息为 >>> host-autoconf 2.69 Patching Applying 0001-dont-add-dirty-to-version.patch using patch: Error: duplicate filename '0001-dont-add-dirty-to-version.patch' Conflicting files are: already applied: /root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/package/autoconf/0001-dont-add-dirty-to-version.patch to be applied : /root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/package/autoconf/0001-dont-add-dirty-to-version.patch package/pkg-generic.mk:180: recipe for target '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/host-autoconf-2.69/.stamp_patched' failed make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/host-autoconf-2.69/.stamp_patched] Error 1 make: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611' ERROR: build buildroot Failed 请问是否遇到这问题,怎么解决,谢谢 |
3个回答
您做过什么修改吗?
没有任何修改,直接使用了网盘提供的源码。
1387 浏览 1 评论
2694 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
3434 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
6233 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
GMT+8, 2024-12-13 05:16 , Processed in 0.716900 second(s), Total 43, Slave 38 queries .
