在官方给的ubuntu18交叉编译环境下,未改变任何配置,使用make zlmage后报错:
forlinx@forlinx:~/workspace/allwinner/A40i/bsp/lichee/linux-3.10$ make zImage scripts/kconfig/conf --silentoldconfig Kconfig drivers/net/wireless/bcmdhd/Kconfig:50:warning: defaults for choice values not supported *** *** Configuration file ".config" not found! *** *** Please run some configurator (e.g. "make oldconfig" or *** "make menuconfig" or "make xconfig"). *** /home/forlinx/workspace/allwinner/A40i/bsp/lichee/linux-3.10/scripts/kconfig/Makefile:36: recipe for target 'silentoldconfig' failed make[2]: *** [silentoldconfig] Error 1 /home/forlinx/workspace/allwinner/A40i/bsp/lichee/linux-3.10/Makefile:503: recipe for target 'silentoldconfig' failed make[1]: *** [silentoldconfig] Error 2 make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/kernel.release'. Stop. 请大神帮忙解答一下,为什么会提示无线有问题?这块如何解决? |
您出现这个问题的原因是,编译之前没有配置环境变量。另外手册中提到的编译内核的方法是
Linux 内核编译 # cd /root/workspace/allwinner/A40i/bsp/lichee/ #根据自己的环境切换 # ./build.sh -m kernel |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
626 浏览 0 评论
887 浏览 1 评论
784 浏览 1 评论
1997 浏览 1 评论
3242 浏览 1 评论
GMT+8, 2024-12-23 17:57 , Processed in 0.609918 second(s), Total 66, Slave 49 queries .
