扫一扫,分享给好友
平台:OKA40i-c V1.2 编译环境:OKA40i-VM_15_1_0-ubuntu18.04说明: 1.源码解码md5均验证无误 2.make menuconfig ARCH=arm修改了nfs配置 操作步骤:1.root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# pwd /root/workspace/allwinner/A40i/bsp/lichee root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# ./build.sh config 2.root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# ./build.sh build buidroot-201611... xgnueabihf sun8iw11p1_hf_defconfig INFO: ---------------------------------------- INFO: build lichee ... INFO: chip: sun8iw11p1 INFO: platform: linux INFO: kernel: linux-3.10 INFO: board: OKA40i_C INFO: output: out/sun8iw11p1/linux/OKA40i_C INFO: ---------------------------------------- INFO: build buildroot ... make: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611' >>> libglib2 2.50.1 Building PATH="/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/***in:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/***in:/usr/local/***in:/usr/local/bin:/usr/***in:/usr/bin:/***in:/bin:/usr/games:/usr/local/games" /usr/bin/make -j5 -C /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/ make[1]: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1' cd . && /bin/sh /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/missing automake-1.15 --gnu Makefile Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/${ <-- HERE ([^ t=:+{}]+)}/ at /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake-1.15 line 3936. Makefile:862: recipe for target 'Makefile.in' failed make[1]: *** [Makefile.in] Error 255 make[1]: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1' package/pkg-generic.mk:216: recipe for target '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built' failed make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built] Error 2 make: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611' ERROR: build buildroot Failed 望帮助解答,感谢! |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
739 浏览 0 评论
968 浏览 1 评论
856 浏览 1 评论
2075 浏览 1 评论
3322 浏览 1 评论
GMT+8, 2024-12-25 13:09 , Processed in 0.572289 second(s), Total 72, Slave 56 queries .
