18.4环境下,装了path,按教程整体编译出错
>>> libglib2 2.50.1 Building PATH="/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/***in:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/***in:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/:/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/:/usr/local/***in:/usr/local/bin:/usr/***in:/usr/bin:/***in:/bin:/snap/bin:/usr/local/arm/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin" /usr/bin/make -j5 -C /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/ make[1]: Entering directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1' cd . && /bin/sh /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/missing automake-1.15 --gnu Makefile Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/${ <-- HERE ([^ t=:+{}]+)}/ at /root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/automake-1.15 line 3936. Makefile:862: recipe for target 'Makefile.in' failed make[1]: *** [Makefile.in] Error 255 make[1]: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1' package/pkg-generic.mk:216: recipe for target '/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built' failed make: *** [/root/workspace/allwinner/A40i/bsp/lichee/out/sun8iw11p1/linux/common/buildroot/build/libglib2-2.50.1/.stamp_built] Error 2 make: Leaving directory '/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611' ERROR: build buildroot Failed root@forlinx:~/workspace/allwinner/A40i/bsp/lichee# |
1、18.04整体编译,需要装上开发环境资料里的patch,安装方法可以参考资料里的pdf文件。
2、您编译的时候是用的出厂镜像还是自己做过修改,我这边用出厂镜像测过,没出现buildroot的报错。 3、另外您是为什么用全编译?如果不用buildroot,不建议全编译,只要涉及到编译内核,就单独编译内核,打包文件系统,最后pack成img就可以了,没必要全编译的 |
1387 浏览 1 评论
2694 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
3434 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
6233 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
GMT+8, 2024-12-13 05:16 , Processed in 0.361462 second(s), Total 39, Slave 34 queries .
