操作文档如下
https://gstreamer.freedesktop.org/documentation/installing/on-linux.html?gi-language=c 可以使用以下命令克隆GIT存储库: git clone https://gitlab.freedesktop.org/gstreamer/gst-docs 整体架构aarch64-poky-linux-gcc basic-tutorial-1.c -o basic-tutorial-1 `pkg-config --cflags --libs gstreamer-1.0`出错forlinx@ubuntu:~/gstreamer/gst-docs/examples/教程$ aarch64-poky-linux-gcc basic-tutorial-1.c -o basic-tutorial-1 `pkg-config --cflags --libs gstreamer-1.0`/opt/fsl-imx-xwayland/5.4-zeus/ sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real-ld: 找到crt1.o:没有那个文件或目录/opt/fsl - imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real-ld: 找不到crti.o:没有这样的文件或目录/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real -ld:找不到 crtbegin.o:没有这样的文件或目录/opt/fsl-imx-xwayland/5。4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc /aarch64-poky-linux/9.2.0/real-ld:找不到-lgstreamer-1.0/opt/fsl-imx -xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real-ld:找不到-lgobject-2.0/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real- ld:找不到-lglib-2.0 /opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2. 0/real-ld:找不到 - lgcc/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/ 9.2.0/real-ld:找不到-lgcc_s/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky- linux/9.2.0/real-ld: 找不到-lpthread/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64- poky-linux/9.2 。0/real-ld:找不到-lc/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/ 9.2.0/real-ld:找不到f-lgcc/opt/imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky- linux /9.2.0/real-ld: 找不到-lgcc_s/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64- poky-linux/9.2.0/real-ld:找不到目录 crtend.o:没有那个文件或/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64 -poky- linux/gcc/aarch64-poky-linux/9.2.0/real-ld: 找不到 crtn.o: No such file or directorycollect2: 错误:ld 返回 1 个退出状态4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux /9.2.0/real-ld:找到-lgcc_s/opt/fsl-imx- xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real-ld: 找不到 crtend.o: 没有那个文件或目录/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real-ld:找不到crtn.o: No such file or directorycollect2: 错误:ld 返回1个退出状态4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux /9.2.0/real-ld:找到-lgcc_s/opt/fsl-imx- xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real-ld: 找不到 crtend.o: 没有那个文件或目录/opt/fsl-imx-xwayland/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/9.2.0/real-ld:找不到crtn.o: No such file or directorycollect2: 错误:ld 返回1个退出状态 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
3301 浏览 0 评论
3111 浏览 1 评论
2584 浏览 1 评论
3921 浏览 1 评论
4653 浏览 1 评论
GMT+8, 2025-2-3 19:36 , Processed in 0.450707 second(s), Total 39, Slave 34 queries .
