扫一扫,分享给好友
一、安装VScode
在ubuntu中找到Ubuntu Software 点击右上角弹出搜索框并搜索vscode,进去后点击install下载 二、环境构建 打开VScode,在搜索栏中搜索C/C++,并点击install进行插件的下载 选择打开一个文件夹,并在文件夹中新建一个文件hello.cpp 输入代码: #include using namespace std; int main() { cout<<"hello world!"< } 搭建环境 完成后会得到默认生成的launch.json文件 然后将其中的代码替换成以下代码: { // Use IntelliSense to learn about possible attributes. // Hover to view descriptions of existing attributes. // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387 "version": "0.2.0", "configurations": [ { "name": "g++ - Build and debug active file", "type": "cppdbg", "request": "launch", "program": "${fileDirname}/${fileBasenameNoExtension}", "args": [], "stopAtEntry": false, "cwd": "${workspaceFolder}", "environment": [], "externalConsole": false, "MIMode": "gdb",q "setupCommands": [ { "description": "Enable pretty-printing for gdb", "text": "-enable-pretty-printing", "ignoreFailures": true } ], "preLaunchTask": "C/C++: g++ build active file", "miDebuggerPath": "/usr/bin/gdb" } ] } 生成tasks.json文件 然后将其中的代码替换成以下代码: { "version": "2.0.0", "tasks": [ { "label": "build", "type": "shell", "command": "g++", "args": [ "-g", "${file}", "-std=c++11", "-o", "${fileBasenameNoExtension}.out" ] } ] } 然后即可在.cpp文件中开始调试 三 、参考 ①Ubuntu下使用可视化调试前端软件KDBG和VScode ②Ubuntu中用VScode编译调试CC++ |
949 浏览 0 评论
1243 浏览 1 评论
2605 浏览 5 评论
2952 浏览 9 评论
2820 浏览 6 评论
1401浏览 3评论
255浏览 2评论
526浏览 2评论
437浏览 2评论
510浏览 1评论
GMT+8, 2025-3-5 06:26 , Processed in 1.091352 second(s), Total 78, Slave 59 queries .
