stepmotor.h
#ifndef __STEPMOTOR_H #define __STEPMOTOR_H #include “stm32f10x.h” void motor_Init(void); //初始化引脚 extern void motor_F(int n); //反转,n 脉冲间隔时间 extern 可有可无 表明函数在其他地方有定义 void motor_Z(int n); //正转,n 脉冲间隔时间 void Motor_Off(void); //关闭电机 void Motor_Angle(int angle,int n); // angle 角度 n 脉冲间隔时间 #endif stepmotor.c #include “stepmotor.h” #include “stm32f10x.h” #include “delay.h” /********************************************** 用正点原子战舰版 STM32F103ZET6 PC0–PC7是给OLED显示屏用的,现在显示屏不用, 使用PC0,PC1,PC2,PC3 给步进电机用 驱动板上接线 PC0 -------IN1 PC1 -------IN2 PC2 -------IN3 PC3 -------IN4 步进电机型号:28BYJ-48 5VDC 驱动芯片;ULN2003APG 在CSDN找程序,改参数 2020/3/15 LZ完成 2020/3/17 修改注释 ***********************************************/ #define orange_H GPIO_SetBits(GPIOC, GPIO_Pin_0); //橙色 #define orange_L GPIO_ResetBits(GPIOC, GPIO_Pin_0); #define yellow_H GPIO_SetBits(GPIOC, GPIO_Pin_1); //黄色 #define yellow_L GPIO_ResetBits(GPIOC, GPIO_Pin_1); #define pink_H GPIO_SetBits(GPIOC, GPIO_Pin_2); //粉色 #define pink_L GPIO_ResetBits(GPIOC, GPIO_Pin_2); #define blue_H GPIO_SetBits(GPIOC, GPIO_Pin_3); //蓝色 #define blue_L GPIO_ResetBits(GPIOC, GPIO_Pin_3); void motor_Init(void)//PC0,PC1,PC2,PC3 { GPIO_InitTypeDef GPIO_InitStruct; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE); GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0;GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;GPIO_Init(GPIOC,&GPIO_InitStruct);GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1;GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;GPIO_Init(GPIOC,&GPIO_InitStruct);GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;GPIO_InitStruct.GPIO_Pin = GPIO_Pin_2;GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;GPIO_Init(GPIOC,&GPIO_InitStruct);GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;GPIO_InitStruct.GPIO_Pin = GPIO_Pin_3;GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;GPIO_Init(GPIOC,&GPIO_InitStruct);GPIO_ResetBits(GPIOC, GPIO_Pin_0);GPIO_ResetBits(GPIOC, GPIO_Pin_1);GPIO_ResetBits(GPIOC, GPIO_Pin_2);GPIO_ResetBits(GPIOC, GPIO_Pin_3); } void motor_F(int n) //反转 逆时针 { orange_H; delay_ms(n); blue_L; delay_ms(n); yellow_H; delay_ms(n); orange_L; delay_ms(n); pink_H; delay_ms(n); yellow_L; delay_ms(n); blue_H; delay_ms(n); pink_L; delay_ms(n); } void motor_Z(int n) //正转 顺时针 { blue_H; delay_ms(n); orange_L; delay_ms(n); pink_H; delay_ms(n); blue_L; delay_ms(n); yellow_H; delay_ms(n); pink_L; delay_ms(n); orange_H; delay_ms(n); yellow_L; delay_ms(n); } void Motor_Off(void) { GPIO_ResetBits(GPIOC, GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3); } void Motor_Angle(int angle,int n) //angle 角度 n 脉冲间隔时间 { u16 j; for(j=0;j<64*angle/45;j++) // 64 减速比 定子8个齿,正反转函数执行一次,转子转一个齿距角。360/45=8 { motor_F(n); // 反转(逆时针),换成正转函数就正转(顺时针) } } main.c int main(void) //步进电机主函数 逆时针转360度 停止 { motor_Init(); delay_init(); Motor_Angle(360,10); Motor_Off(); while(1){ delay_ms(1000); } } |
2173 浏览 1 评论
1837 浏览 1 评论
1327 浏览 2 评论
869 浏览 2 评论
2206 浏览 2 评论
2111浏览 9评论
1024浏览 4评论
397浏览 3评论
723浏览 3评论
712浏览 3评论
GMT+8, 2025-4-11 00:32 , Processed in 1.218204 second(s), Total 76, Slave 59 queries .
