rf射频数据收发芯片的一个数据接收指示引脚连接stm32的一个gpio口,设置为中断口。当rf接收到数据的时候,数据接收指示引脚由高电平变为低电平,所以中断配置里面配置的是IPU,下降沿触发。系统复位后,发送模块没有发送数据,也就是说这个接收模块没有接收到数据,这个中断口根本不会触发立马。可是实际上是一旦复位,在线调试发现k=100,说明进入中断服务函数,不得其解,大佬帮忙看看是不是配置错误呢。中断代码如下:
#include "wakeup_interrupt.h" extern uint8_t Signalll; uint8_t g_RF24L01RxBuffer[ 32 ] = { 0 }; uint32_t t=0,i = 0,n=0,k=0; const char *g_changeok = "changeok"; const char *g_wakingup = "wakingup"; void wakeup_interrupt_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_Init(GPIOA, &GPIO_InitStructure); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE); GPIO_EXTILineConfig(GPIO_PortSourceGPIOA , GPIO_PinSource12); } //*****外部事件的配置函数 void EXTI_Configuration(void) { EXTI_InitTypeDef EXTI_InitStructure; /*PA12外部中断输入*/ EXTI_InitStructure.EXTI_Line = EXTI_Line12; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); } //*********中断配置函数 void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); /*外部中断线*/ NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn ; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0 ; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE ; NVIC_Init(&NVIC_InitStructure); } //**********中断服务函数 void EXTI15_10_IRQHandler(void) { k=100; if(EXTI_GetITStatus(EXTI_Line12)!= RESET) { EXTI_ClearITPendingBit(EXTI_Line12); Signalll = 50; i = CC1101_Rx_Packet( g_RF24L01RxBuffer ); //此程序里面包含了打开spi模式 if((g_RF24L01RxBuffer[0])!=0) { drv_uart_tx_bytes(g_RF24L01RxBuffer, 32 ); } if(memcmp(g_wakingup,g_RF24L01RxBuffer,8) == 0)//判断接收到的字符串 { drv_uart_tx_bytes("recieved waking up command", 26 ); t=10; CC1101_Set_Idle_Mode( ); n=1; while(1) { CC1101_Tx_Packet( (uint8_t *)g_changeok, 8 , ADDRESS_CHECK ); t=2; //输出发送的数据到串口显示器 drv_delay_500Ms( 1 ); drv_delay_500Ms( 1 ); } } } } 除此之外,主程序里面的灯不闪烁,貌似是被直接中断了,下面是部分main程序: int main( void ) { //串口初始化,设置波特率 drv_uart_init( 115200 ); //延时初始化 drv_delay_init( ); //LED初始化 drv_led_init( ); //SPI初始化 drv_spi_init( ); //CC1101初始化 CC1101_Init( ); //唤醒时中断的相关配置 wakeup_interrupt_Configuration(); NVIC_Configuration(); EXTI_Configuration(); for(a=0;a<6;a++)//红灯绿灯分别亮灭3次代表初始化成功,处于发送或接收状态 { led_red_flashing( ); led_green_flashing( ); drv_delay_500Ms( 1 ); } 系统复位时,理论上程序从头到尾运行,然而上面的红灯绿灯没有闪烁。 |
1996 浏览 1 评论
1781 浏览 1 评论
1245 浏览 2 评论
824 浏览 2 评论
1799 浏览 2 评论
2030浏览 9评论
942浏览 4评论
338浏览 3评论
682浏览 3评论
668浏览 3评论
GMT+8, 2025-3-6 12:56 , Processed in 0.733194 second(s), Total 43, Slave 38 queries .
