MCU:stm32f103c8t6
通信模块:nrf24l01 连线:CE->PA2,SCK->PA3,MISO->PA4,CSN->PA5,MOSI->PA6,IRQ->PA7 模拟SPI,可以更改任意引脚。把源文件或者头文件,全选替换。 遇到的问题,硬件连线。连接错误,发送接收不正常。debug 到 错误点,检查错误点相应的硬件及软件。 源文件:NRF24L01.c #include "NRF24L01.h" const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址 const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //接收地址 void Delay(vu32 nCount) { for(; nCount != 0; nCount--); } //初始化NRF24L01IO口 //CE->PA2,CSN->PA5,SCK->PA3,MOSI->PA6,MISO->PA4,IRQ->PA7 void Init_NRF24L01(void) { //CE->PD2,CSN->PD5,SCK->PD3,MOSI->PD6 GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //使能GPIO 的时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_5|GPIO_Pin_3|GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); CE_H; //初始化时先拉高 CSN_H; //初始化时先拉高 //MISO->PD4,IRQ->PD7 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); IRQ_H; //IRQ置高 CE_L; //使能NRF24L01 CSN_H; //SPI片选取消 } //模拟SPI读写数据函数 u8 SPI_ReadWriteByte(u8 TxData) { u16 bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) { if(TxData & 0x80) MOSI_H; else MOSI_L; TxData = (TxData << 1); SCK_H; Delay(0xff); if(READ_MISO) TxData |= 0x01; SCK_L; Delay(0xff); } return(TxData); } //上电检测NRF24L01是否在位 //写5个数据然后再读回来进行比较, //相同时返回值0,表示在位; //否则返回1,表示不在位. u8 NRF24L01_Check(void) { u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5}; u8 buf1[5]; u8 i; NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址. NRF24L01_Read_Buf(TX_ADDR,buf1,5); //读出写入的地址 for(i=0;i<5;i++) if(buf1!=0XA5) break; if(i!=5) return 1; //NRF24L01不在位 return 0; //NRF24L01在位 } //通过SPI写寄存器 u8 NRF24L01_Write_Reg(u8 reg_addr,u8 data) { u8 status; CSN_L; //使能SPI传输 status =SPI_ReadWriteByte(reg_addr); //发送寄存器号 SPI_ReadWriteByte(data); //写入寄存器的值 CSN_H; //禁止SPI传输 return(status); //返回状态值 } //读取SPI寄存器值 ,regaddr:要读的寄存器 u8 NRF24L01_Read_Reg(u8 reg_addr) { u8 reg_val; CSN_L; //使能SPI传输 SPI_ReadWriteByte(reg_addr); //发送寄存器号 reg_val=SPI_ReadWriteByte(0);//读取寄存器内容 CSN_H; //禁止SPI传输 return(reg_val); //返回状态值 } //在指定位置读出指定长度的数据 //*pBuf:数据指针 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Read_Buf(u8 reg_addr,u8 *pBuf,u8 data_len) { u8 status,i; CSN_L; //使能SPI传输 status=SPI_ReadWriteByte(reg_addr); //发送寄存器值(位置),并读取状态值 for(i=0;i CSN_H; //关闭SPI传输 return status; //返回读到的状态值 } //在指定位置写指定长度的数据 //*pBuf:数据指针 //返回值,此次读到的状态寄存器值 u8 NRF24L01_Write_Buf(u8 reg_addr, u8 *pBuf, u8 data_len) { u8 status,i; CSN_L; //使能SPI传输 status = SPI_ReadWriteByte(reg_addr); //发送寄存器值(位置),并读取状态值 for(i=0; i CSN_H; //关闭SPI传输 return status; //返回读到的状态值 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:发送完成状况 u8 NRF24L01_TxPacket(u8 *tx_buf) { u8 state; CE_L; NRF24L01_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节 CE_H; //启动发送 while(READ_IRQ != 0); //等待发送完成 state=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(SPI_WRITE_REG+STATUS,state); //清除TX_DS或MAX_RT中断标志 if(state&MAX_TX) //达到最大重发次数 { NRF24L01_Write_Reg(FLUSH_TX,0xff); //清除TX FIFO寄存器 return MAX_TX; } if(state&TX_OK) //发送完成 { return TX_OK; } return 0xff; //其他原因发送失败 } //启动NRF24L01发送一次数据 //txbuf:待发送数据首地址 //返回值:0,接收完成;其他,错误代码 u8 NRF24L01_RxPacket(u8 *rx_buf) { u8 state; state=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值 NRF24L01_Write_Reg(SPI_WRITE_REG+STATUS,state); //清除TX_DS或MAX_RT中断标志 if(state&RX_OK) //接收到数据 { NRF24L01_Read_Buf(RD_RX_PLOAD,rx_buf,RX_PLOAD_WIDTH);//读取数据 NRF24L01_Write_Reg(FLUSH_RX,0xff); //清除RX FIFO寄存器 return 0; } return 1; //没收到任何数据 } //该函数初始化NRF24L01到RX模式 //设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR //当CE变高后,即进入RX模式,并可以接收数据了 void RX_Mode(void) { CE_L; //写RX节点地址 NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //使能通道0的自动应答 NRF24L01_Write_Reg(SPI_WRITE_REG+EN_AA,0x01); //使能通道0的接收地址 NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x01); //设置RF通信频率 NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,40); //选择通道0的有效数据宽度 NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(SPI_WRITE_REG+RF_SETUP,0x0f); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,PRIM_RX接收模式 NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG, 0x0f); //CE为高,进入接收模式 CE_H; } //该函数初始化NRF24L01到TX模式 //设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据, //选择RF频道,波特率和LNA HCURR PWR_UP,CRC使能 //当CE变高后,即进入RX模式,并可以接收数据了 //CE为高大于10us,则启动发送. void TX_Mode(void) { CE_L; //写TX节点地址 NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //使能通道0的自动应答 NRF24L01_Write_Reg(SPI_WRITE_REG+EN_AA,0x01); //使能通道0的接收地址 NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x01); //设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次 NRF24L01_Write_Reg(SPI_WRITE_REG+SETUP_RETR,0x1a); //设置RF通道为40 NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,40); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启 NRF24L01_Write_Reg(SPI_WRITE_REG+RF_SETUP,0x0f); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,PRIM_RX发送模式,开启所有中断 NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG,0x0e); // CE为高,10us后启动发送 CE_H; } |
头文件:NRF24L01.h
#ifndef _NRF24L01_H #define _NRF24L01_H #include "stm32f10x.h" /****************************************************************************************************/ //NRF24L01寄存器操作命令 #define SPI_READ_REG 0x00 //读配置寄存器,低5位为寄存器地址 #define SPI_WRITE_REG 0x20 //写配置寄存器,低5位为寄存器地址 #define RD_RX_PLOAD 0x61 //读RX有效数据,1~32字节 #define WR_TX_PLOAD 0xA0 //写TX有效数据,1~32字节 #define FLUSH_TX 0xE1 //清除TX FIFO寄存器.发射模式下用 #define FLUSH_RX 0xE2 //清除RX FIFO寄存器.接收模式下用 #define REUSE_TX_PL 0xE3 //重新使用上一包数据,CE为高,数据包被不断发送. #define NOP 0xFF //空操作,可以用来读状态寄存器 //SPI(NRF24L01)寄存器地址 #define CONFIG 0x00 //配置寄存器地址;bit0:1接收模式,0发射模式;bit1:电选择;bit2:CRC模式;bit3:CRC使能; //bit4:中断MAX_RT(达到最大重发次数中断)使能;bit5:中断TX_DS使能;bit6:中断RX_DR使能 #define EN_AA 0x01 //使能自动应答功能 bit0~5,对应通道0~5 #define EN_RXADDR 0x02 //接收地址允许,bit0~5,对应通道0~5 #define SETUP_AW 0x03 //设置地址宽度(所有数据通道):bit1,0:00,3字节;01,4字节;02,5字节; #define SETUP_RETR 0x04 //建立自动重发;bit3:0,自动重发计数器;bit7:4,自动重发延时 250*x+86us #define RF_CH 0x05 //RF通道,bit6:0,工作通道频率; #define RF_SETUP 0x06 //RF寄存器;bit3:传输速率(0:1Mbps,1:2Mbps);bit2:1,发射功率;bit0:低噪声放大器增益 #define STATUS 0x07 //状态寄存器;bit0:TX FIFO满标志;bit3:1,接收数据通道号(最大:6);bit4,达到最多次重发 //bit5:数据发送完成中断;bit6:接收数据中断; #define MAX_TX 0x10 //达到最大发送次数中断 #define TX_OK 0x20 //TX发送完成中断 #define RX_OK 0x40 //接收到数据中断 #define OBSERVE_TX 0x08 //发送检测寄存器,bit7:4,数据包丢失计数器;bit3:0,重发计数器 #define CD 0x09 //载波检测寄存器,bit0,载波检测; #define RX_ADDR_P0 0x0A //数据通道0接收地址,最大长度5个字节,低字节在前 #define RX_ADDR_P1 0x0B //数据通道1接收地址,最大长度5个字节,低字节在前 #define RX_ADDR_P2 0x0C //数据通道2接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define RX_ADDR_P3 0x0D //数据通道3接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define RX_ADDR_P4 0x0E //数据通道4接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define RX_ADDR_P5 0x0F //数据通道5接收地址,最低字节可设置,高字节,必须同RX_ADDR_P1[39:8]相等; #define TX_ADDR 0x10 //发送地址(低字节在前),ShockBurstTM模式下,RX_ADDR_P0与此地址相等 #define RX_PW_P0 0x11 //接收数据通道0有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P1 0x12 //接收数据通道1有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P2 0x13 //接收数据通道2有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P3 0x14 //接收数据通道3有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P4 0x15 //接收数据通道4有效数据宽度(1~32字节),设置为0则非法 #define RX_PW_P5 0x16 //接收数据通道5有效数据宽度(1~32字节),设置为0则非法 #define FIFO_STATUS 0x17 //FIFO状态寄存器;bit0,RX FIFO寄存器空标志;bit1,RX FIFO满标志;bit2,3,保留 //bit4,TX FIFO空标志;bit5,TX FIFO满标志;bit6,1,循环发送上一数据包.0,不循环; /**********************************************************************************************************/ //NRF2401片选信号 #define CE_L GPIO_ResetBits(GPIOA, GPIO_Pin_2) #define CE_H GPIO_SetBits(GPIOA, GPIO_Pin_2) //SPI时钟 #define SCK_L GPIO_ResetBits(GPIOA , GPIO_Pin_3) #define SCK_H GPIO_SetBits(GPIOA , GPIO_Pin_3) //SPI输入 #define READ_MISO GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_4) //SPI片选信号 #define CSN_L GPIO_ResetBits(GPIOA, GPIO_Pin_5) #define CSN_H GPIO_SetBits(GPIOA, GPIO_Pin_5) //SPI输出 #define MOSI_L GPIO_ResetBits(GPIOA , GPIO_Pin_6) #define MOSI_H GPIO_SetBits(GPIOA , GPIO_Pin_6) //IRQ中断脚 #define IRQ_L GPIO_ResetBits(GPIOA,GPIO_Pin_7) #define IRQ_H GPIO_SetBits(GPIOA,GPIO_Pin_7) #define READ_IRQ GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_7) //NRF24L01发送接收数据宽度定义 #define TX_ADR_WIDTH 5 //5字节的地址宽度 #define RX_ADR_WIDTH 5 //5字节的地址宽度 #define TX_PLOAD_WIDTH 32 //20字节的用户数据宽度 #define RX_PLOAD_WIDTH 32 //20字节的用户数据宽度 void Init_NRF24L01(void); //NRF24l01初始化 u8 SPI_ReadWriteByte(u8 TxData) ; //模拟SPI通讯函数 void RX_Mode(void); //配置为接收模式 void TX_Mode(void); //配置为发送模式 u8 NRF24L01_Write_Buf(u8 regaddr, u8 *pBuf, u8 datalen); //写数据区 u8 NRF24L01_Read_Buf(u8 regaddr, u8 *pBuf, u8 datalen); //读数据区 u8 NRF24L01_Read_Reg(u8 regaddr); //读寄存器 u8 NRF24L01_Write_Reg(u8 regaddr, u8 data); //写寄存器 u8 NRF24L01_Check(void); //检查NRF24L01是否在位 u8 NRF24L01_TxPacket(u8 *txbuf); //发送一个包的数据 u8 NRF24L01_RxPacket(u8 *rxbuf); //接收一个包的数据 void Delay(vu32 nCount); #endif 主函数:main.c /******************** (C) COPYRIGHT 2017 ************************** * 文件名 :main.c * 描述 :NRF24L01+ 的 接收 测试程序 * 实验平台:STM32F103VET6 * 库版本 :ST3.5.0 * 编写日期:2017-04-17 * 修改日期:2017-04-17 * 作者 : * 2017-04-17 * (1)NRF24L01+ 接收数据 测试正常! **********************************************************************************/ #include "usart1.h" #include "led.h" #include "tim2.h" #include "NRF24L01.h" #include "SysTick.h" /* * 函数名:main * 描述 : "主机"的主函数 * 输入 :无 * 输出 : 无 */ int main(void) { uint8_t tmp_buf[6]; SysTick_Init(); USART1_Config(9600); /* 初始化USART1 */ LED_GPIO_Config(); /* 运行LED初始化 */ TIM2_Config(); /* 定时器TIM2初始化 */ Init_NRF24L01(); printf("STM32F103VET6 NRF24L01 RECV Test!rn"); if(NRF24L01_Check()) { printf("NRF24L01 is Not work!rn"); } printf("NRF24L01 is working!rn"); RX_Mode(); //只收不发 while(1) { if(NRF24L01_RxPacket(tmp_buf)==0) //接收到数据 { printf("rn RECV Data is:%srn",tmp_buf); LED1(ON); Delay_ms(100); } LED1(OFF); } } /******************* (C) COPYRIGHT 2017 *****END OF FILE************/ |
1979 浏览 1 评论
1761 浏览 1 评论
1233 浏览 2 评论
819 浏览 2 评论
1776 浏览 2 评论
2015浏览 9评论
893浏览 4评论
320浏览 3评论
673浏览 3评论
662浏览 3评论
GMT+8, 2025-2-24 15:36 , Processed in 0.798664 second(s), Total 46, Slave 41 queries .
