实验目的: 使用 STM32 的串口来发送和接收数据
实验步骤:
miniSTM32 板载 1 个USB串口和1个RS232串口,实验将使用USB串口将信息打印到电脑上; 串口设置步骤:
#define __IO volatile /*!< defines 'read / write' permissions */ //volatile是一个类型修饰符(type specifier),就像我们熟悉的const一样,它是被设计用来修饰被不同线程访问和修改的变量; //volatile的作用是作为指令关键字,确保本条指令不会因编译器的优化而省略,且要求每次直接读值; void USART_Init(USART_TypeDef* USARTx, USART_InitTypeDef* USART_InitStruct); typedef struct { __IO uint16_t SR; uint16_t RESERVED0; __IO uint16_t DR; uint16_t RESERVED1; __IO uint16_t BRR; uint16_t RESERVED2; __IO uint16_t CR1; uint16_t RESERVED3; __IO uint16_t CR2; uint16_t RESERVED4; __IO uint16_t CR3; uint16_t RESERVED5; __IO uint16_t GTPR; uint16_t RESERVED6; } USART_TypeDef; typedef struct { uint32_t USART_BaudRate; /*!< This member configures the USART communication baud rate. The baud rate is computed using the following formula: - IntegerDivider = ((PCLKx) / (16 * (USART_InitStruct->USART_BaudRate))) - FractionalDivider = ((IntegerDivider - ((u32) IntegerDivider)) * 16) + 0.5 */ uint16_t USART_WordLength; /*!< Specifies the number of data bits transmitted or received in a frame. This parameter can be a value of @ref USART_Word_Length */ uint16_t USART_StopBits; /*!< Specifies the number of stop bits transmitted. This parameter can be a value of @ref USART_Stop_Bits */ uint16_t USART_Parity; /*!< Specifies the parity mode. This parameter can be a value of @ref USART_Parity @note When parity is enabled, the computed parity is inserted at the MSB position of the transmitted data (9th bit when the word length is set to 9 data bits; 8th bit when the word length is set to 8 data bits). */ uint16_t USART_Mode; /*!< Specifies wether the Receive or Transmit mode is enabled or disabled. This parameter can be a value of @ref USART_Mode */ uint16_t USART_HardwareFlowControl; /*!< Specifies wether the hardware flow control mode is enabled or disabled. This parameter can be a value of @ref USART_Hardware_Flow_Control */ } USART_InitTypeDef; //赋值 USART_InitStructure.USART_BaudRate = bound; //波特率; USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为 8 位数据格式; USART_InitStructure.USART_StopBits = USART_StopBits_1; //一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No; //无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口 开启中断并且初始化 NVIC(如果需要开启中断才需要这个步骤) 使能串口 编写中断处理函数 数据发送与接收 通过寄存器 USART_DR 来实现 typedef unsigned short int uint16_t; void USART_SendData(USART_TypeDef* USARTx, uint16_t Data); //发送数据函数; uint16_t USART_ReceiveData(USART_TypeDef* USARTx); //从串口读取数据; 函数的具体实现目前不需要了解,大致是通过位操作来保留和读取数据; 串口状态读取 根据对串口状态寄存器 USART_SR 中一些标志位的读取来判断数据是接收到还是发送出去; —RXNE(读数据寄存器非空),当该位被置 1 的时候,就是提示已经有数据被接收到了; —TC(发送完成),当该位被置位的时候,表示 USART_DR 内的数据已经被发送完成了; 下面给出固件库函数里对状态读取的函数: FlagStatus USART_GetFlagStatus(USART_TypeDef* USARTx, uint16_t USART_FLAG); USART_GetFlagStatus(USART1, USART_FLAG_RXNE); //判断读寄存器是否非空(RXNE); USART_GetFlagStatus(USART1, USART_FLAG_TC); //判断发送是否完成(TC); //下面是这些标识符的宏定义,每一个都对应了 uint16_t 类型的一个值; #define USART_FLAG_CTS ((uint16_t)0x0200) #define USART_FLAG_LBD ((uint16_t)0x0100) #define USART_FLAG_TXE ((uint16_t)0x0080) #define USART_FLAG_TC ((uint16_t)0x0040) #define USART_FLAG_RXNE ((uint16_t)0x0020) #define USART_FLAG_IDLE ((uint16_t)0x0010) #define USART_FLAG_ORE ((uint16_t)0x0008) #define USART_FLAG_NE ((uint16_t)0x0004) #define USART_FLAG_FE ((uint16_t)0x0002) #define USART_FLAG_PE ((uint16_t)0x0001)
跳线帽连接 3. 软件设计 //bound:波特率 void uart_init(u32 bound) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; //①串口时钟使能,GPIO 时钟使能,复用时钟使能 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1| RCC_APB2Periph_GPIOA, ENABLE); //使能 USART1,GPIOA 时钟 //②串口复位 USART_DeInit(USART1); //复位串口 1 //③GPIO 端口模式设置,配置全双工的串口 1,那么 TX(PA9)管脚需要配置为推挽复用输出,RX(PA10)管脚配置为浮空输入或者带上拉输入 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //ISART1_TX PA.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化 GPIOA.9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART1_RX PA.10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化 GPIOA.10 //④串口参数初始化 USART_InitStructure.USART_BaudRate = bound; //波特率设置 USART_InitStructure.USART_WordLength = USART_WordLength_8b; //字长为 8 位 USART_InitStructure.USART_StopBits = USART_StopBits_1; //一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No; //无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口 #if EN_USART1_RX //如果使能了接收 //⑤初始化 NVIC NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ; //抢占优先级 3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级 3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ 通道使能 NVIC_Init(&NVIC_InitStructure); //中断优先级初始化 //⑤开启中断 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //开启中断 #endif //⑥使能串口 USART_Cmd(USART1, ENABLE); //使能串口 }
{ u8 t; u8 len; u16 times=0; delay_init(); //延时函数初始化 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 设置中断优先级分组2 uart_init(9600); //串口初始化为9600 LED_Init(); //初始化与LED连接的硬件接口 while(1) { if(USART_RX_STA&0x8000) //发送信息 { len=USART_RX_STA&0x3fff;//得到此次接收到的数据长度 printf("rn您发送的消息为:rn"); for(t=0;t USART1->DR=USART_RX_BUF[t]; while((USART1->SR&0X40)==0);//等待发送结束 } printf("rnrn");//插入换行 USART_RX_STA=0; } else //接收信息; { times++; if(times%5000==0) { printf("rnALIENTEK MiniSTM32开发板 串口实验rn"); printf("正点原子@ALIENTEKrnrnrn"); } if(times%200==0)printf("请输入数据,以回车键结束rn"); if(times%30==0)LED0=!LED0;//闪烁LED,提示系统正在运行. delay_ms(10); } } } |
1927 浏览 1 评论
1698 浏览 1 评论
1180 浏览 2 评论
779 浏览 2 评论
1745 浏览 2 评论
1984浏览 9评论
820浏览 4评论
268浏览 3评论
633浏览 3评论
637浏览 3评论
GMT+8, 2025-1-31 20:05 , Processed in 0.579572 second(s), Total 44, Slave 39 queries .
