1、使能定时器时钟: RCC_APB1PeriphClockCmd();
例如: RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE); //开定时器3时钟 1 2、设置定时器的基本参数(计数方式、计数周期、分频系数等) 注:①计数方式有TIM_CounterMode_Up(向上计数)、TIM_CounterMode_Down(向下计数)等方式; ②分频系数(TIM_Prescaler)可以为1~65535之间的任意数; ③计数初值的计算:(计数周期 + 1) * (分频系数 + 1) / (计时器频率),定时器频率一般情况下都是默认的从AHB二分频之后再倍频得到的,所以说还是72M; 比如说,要定时100ms,即可写为:计数周期 = 999,分频系数 = 7199 ,即为(999 + 1) * (7199 + 1) / (72,000,000),因为 分频系数 / 计数器频率 即为计一个数所用的时间,所以说用计数总数乘上这个时间即为总时间。 TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Down; //向下计数 TIM_TimeBaseInitStruct.TIM_Period = 4999; TIM_TimeBaseInitStruct.TIM_Prescaler = 7199; TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStruct); 3、定时器中断配置: /*定时器中断参数设置*/ TIM3->SR &= 0xFFFE; //清除update中断标志位,否则会出现刚配置完中断就进入中断服务函数的问题 TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE); //配置为更新中断 NVIC_InitStruct.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); 4、使能定时器: TIM_Cmd(TIM3,ENABLE); 5、编写中断服务函数: void TIM3_IRQHandler(void) { if(TIM_GetITStatus(TIM3,TIM_FLAG_Update) != RESET) { TIM3->SR &= ~(0x01 << 0); //清除中断标志位 flag_1s ++; flag_500ms ++; } if(flag_500ms >= 1) { flag_500ms = 0; PBout(5) = !PBout(5); } if(flag_1s >= 2) { flag_1s = 0; PDout(12) = !PDout(12); } } 附上测试源程序: #include "stm32f10x.h" #include "stm32f10x_rcc.h" #include "delay.h" unsigned char time_count = 0; unsigned char flag_500ms = 0; unsigned char flag_1s = 0; void TIM3_IRQHandler(void) { if(TIM_GetITStatus(TIM3,TIM_FLAG_Update) != RESET) { TIM3->SR &= ~(0x01 << 0); //清除中断标志位 flag_1s ++; flag_500ms ++; } if(flag_500ms >= 1) { flag_500ms = 0; PBout(5) = !PBout(5); } if(flag_1s >= 2) { flag_1s = 0; PDout(12) = !PDout(12); } } int main(void) { unsigned char clear = clear; GPIO_InitTypeDef GPIO_InitStruct; USART_InitTypeDef USART_InitStruct; TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct; NVIC_InitTypeDef NVIC_InitStruct; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //中断分组设置 delay_init(); /*LED指示灯初始化,用来标志全部初始化完成*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE); GPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5; GPIO_Init(GPIOB,&GPIO_InitStruct); GPIO_SetBits(GPIOB,GPIO_Pin_5); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,ENABLE); GPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12; GPIO_Init(GPIOD,&GPIO_InitStruct); GPIO_SetBits(GPIOB,GPIO_Pin_5); GPIO_SetBits(GPIOD,GPIO_Pin_12); /*串口端口初始化*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); //串口1时钟使能 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); //GPIOA时钟使能 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_9; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA,&GPIO_InitStruct); GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA,&GPIO_InitStruct); /*串口参数初始化*/ USART_InitStruct.USART_BaudRate = 115200; USART_InitStruct.USART_WordLength = USART_WordLength_8b; USART_InitStruct.USART_StopBits = USART_StopBits_1; USART_InitStruct.USART_Parity = USART_Parity_No; USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_Init(USART1,&USART_InitStruct); //USART1->SR = USART1->SR; USART_Cmd(USART1,ENABLE); /*定时器3基本参数初始化*/ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE); //开定时器3时钟 TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Down; //向下计数 TIM_TimeBaseInitStruct.TIM_Period = 4999; TIM_TimeBaseInitStruct.TIM_Prescaler = 7199; TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStruct); /*定时器中断参数设置*/ TIM3->SR &= 0xFFFE; //清除update中断标志位,否则会出现刚配置完中断就进入中断服务函数的问题 TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE); //配置为更新中断 NVIC_InitStruct.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); /*初始化完成*/ GPIO_ResetBits(GPIOB,GPIO_Pin_5); GPIO_ResetBits(GPIOD,GPIO_Pin_12); TIM_Cmd(TIM3,ENABLE); while(1) { } } 就先更新到这里,困了,有机会再更,今天上班的时候刚好对串口又加深了理解,有时间就更新一下。 |
1996 浏览 1 评论
1781 浏览 1 评论
1245 浏览 2 评论
824 浏览 2 评论
1799 浏览 2 评论
2031浏览 9评论
942浏览 4评论
338浏览 3评论
682浏览 3评论
668浏览 3评论
GMT+8, 2025-3-6 17:04 , Processed in 0.662390 second(s), Total 42, Slave 37 queries .
