static void MX_USART1_UART_Init(void)
{ huart1.Instance = USART1; huart1.Init.BaudRate = 115200; huart1.Init.WordLength = UART_WORDLENGTH_8B; huart1.Init.StopBits = UART_STOPBITS_1; huart1.Init.Parity = UART_PARITY_NONE; huart1.Init.Mode = UART_MODE_TX_RX; huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart1.Init.OverSampling = UART_OVERSAMPLING_16; if (HAL_UART_Init(&huart1) != HAL_OK) { Error_Handler(); } } 前面是串口的一些配置。 HAL_UART_Init(&huart1)是真正的初始化函数。 初始化函数定义在DriversStm32F1xx_HAL_DriversSrcstm32f1xx_hal_uart.c 中。 HAL_StatusTypeDef HAL_UART_Init(UART_HandleTypeDef *huart) { /* Check the UART handle allocation */ if (huart == NULL) { return HAL_ERROR; } /* Check the parameters */ if (huart->Init.HwFlowCtl != UART_HWCONTROL_NONE) //硬件流控制吗 { /* The hardware flow control is available only for USART1, USART2 and USART3 */ assert_param(IS_UART_HWFLOW_INSTANCE(huart->Instance)); assert_param(IS_UART_HARDWARE_FLOW_CONTROL(huart->Init.HwFlowCtl)); } else { assert_param(IS_UART_INSTANCE(huart->Instance)); } assert_param(IS_UART_WORD_LENGTH(huart->Init.WordLength)); //检查数据位 #if defined(USART_CR1_OVER8) assert_param(IS_UART_OVERSAMPLING(huart->Init.OverSampling)); #endif /* USART_CR1_OVER8 */ if (huart->gState == HAL_UART_STATE_RESET) { /* Allocate lock resource and initialize it */ huart->Lock = HAL_UNLOCKED; #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) UART_InitCallbacksToDefault(huart); if (huart->MspInitCallback == NULL) { huart->MspInitCallback = HAL_UART_MspInit; } /* Init the low level hardware */ huart->MspInitCallback(huart); #else /* Init the low level hardware : GPIO, CLOCK */ HAL_UART_MspInit(huart); //--->>>跳转到Srcstm32f1xx_hal_msp.c //在这个函数中初始化了时钟、GPIO、中断 #endif /* (USE_HAL_UART_REGISTER_CALLBACKS) */ } huart->gState = HAL_UART_STATE_BUSY; /* Disable the peripheral */ __HAL_UART_DISABLE(huart); /* Set the UART Communication parameters */ UART_SetConfig(huart); //真正配置寄存器 /* In asynchronous mode, the following bits must be kept cleared: - LINEN and CLKEN bits in the USART_CR2 register, - SCEN, HDSEL and IREN bits in the USART_CR3 register.*/ CLEAR_BIT(huart->Instance->CR2, (USART_CR2_LINEN | USART_CR2_CLKEN)); CLEAR_BIT(huart->Instance->CR3, (USART_CR3_SCEN | USART_CR3_HDSEL | USART_CR3_IREN)); /* Enable the peripheral */ __HAL_UART_ENABLE(huart); //使能串口 /* Initialize the UART state */ huart->ErrorCode = HAL_UART_ERROR_NONE; huart->gState = HAL_UART_STATE_READY; huart->RxState = HAL_UART_STATE_READY; return HAL_OK; } //中断服务函数,在Srcstm32f1xx_it.c中定义 void USART1_IRQHandler(void) { /* USER CODE BEGIN USART1_IRQn 0 */ /* USER CODE END USART1_IRQn 0 */ HAL_UART_IRQHandler(&huart1); /* USER CODE BEGIN USART1_IRQn 1 */ /* USER CODE END USART1_IRQn 1 */ } //中断服务函数,在DriversStm32F1xx_HAL_DriversSrcstm32f1xx_hal_uart.c中给定义好了 void HAL_UART_IRQHandler(UART_HandleTypeDef *huart) { uint32_t isrflags = READ_REG(huart->Instance->SR); //读取SR寄存器 uint32_t cr1its = READ_REG(huart->Instance->CR1); //读取CR1寄存器 uint32_t cr3its = READ_REG(huart->Instance->CR3); //读取CR3寄存器 uint32_t errorflags = 0x00U; uint32_t dmarequest = 0x00U; /* If no error occurs */ errorflags = (isrflags & (uint32_t)(USART_SR_PE | USART_SR_FE | USART_SR_ORE | USART_SR_NE)); //如果出现错误:PE校验错误;FE: 帧错误;ORE:过载错误;NE: 噪声错误 if (errorflags == RESET) //RESET=0 ;如果没错误 { /* UART in mode Receiver -------------------------------------------------*/ if (((isrflags & USART_SR_RXNE) != RESET) && ((cr1its & USART_CR1_RXNEIE) != RESET)) //RXNE:读数据寄存器非空 ,0:数据没有收到;1:收到数据,可以读出。 //RXNEIE:接收缓冲区非空中断使能 (RXNE interrupt enable) 该位由软件设置或清除。 //0:禁止产生中断; //1:当USART_SR中的ORE或者RXNE为’1’时,产生USART中断。 { UART_Receive_IT(huart); //处理函数 return; } } /* If some errors occur */ /*如果有错误发生*/ if ((errorflags != RESET) && (((cr3its & USART_CR3_EIE) != RESET) || ((cr1its & (USART_CR1_RXNEIE | USART_CR1_PEIE)) != RESET))) //EIE:错误中断使能 (Error interrupt enable) //在多缓冲区通信模式下,当有帧错误、过载或者噪声错误时(USART_SR中的FE=1,或者 //ORE=1,或者NE=1)产生中断。 //0:禁止中断; //1:只要USART_CR3中的DMAR=1,并且USART_SR中的FE=1,或者ORE=1,或者NE=1, //则产生中断 //RXNEIE:接收缓冲区非空中断使能 (RXNE interrupt enable) //该位由软件设置或清除。 //0:禁止产生中断; //1:当USART_SR中的ORE或者RXNE为’1’时,产生USART中断。 // PEIE: PE中断使能 (PE interrupt enable) //该位由软件设置或清除。 //0:禁止产生中断; //1:当USART_SR中的PE为’1’时,产生USART中断 { /* UART parity error interrupt occurred ----------------------------------*/ if (((isrflags & USART_SR_PE) != RESET) && ((cr1its & USART_CR1_PEIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_PE; } /* UART noise error interrupt occurred -----------------------------------*/ if (((isrflags & USART_SR_NE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_NE; } /* UART frame error interrupt occurred -----------------------------------*/ if (((isrflags & USART_SR_FE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_FE; } /* UART Over-Run interrupt occurred --------------------------------------*/ if (((isrflags & USART_SR_ORE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_ORE; } /* Call UART Error Call back function if need be --------------------------*/ if (huart->ErrorCode != HAL_UART_ERROR_NONE) { /* UART in mode Receiver -----------------------------------------------*/ if (((isrflags & USART_SR_RXNE) != RESET) && ((cr1its & USART_CR1_RXNEIE) != RESET)) { UART_Receive_IT(huart); } /* If Overrun error occurs, or if any error occurs in DMA mode reception, consider error as blocking */ dmarequest = HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR); if (((huart->ErrorCode & HAL_UART_ERROR_ORE) != RESET) || dmarequest) { /* Blocking error : transfer is aborted Set the UART state ready to be able to start again the process, Disable Rx Interrupts, and disable Rx DMA request, if ongoing */ UART_EndRxTransfer(huart); /* Disable the UART DMA Rx request if enabled */ if (HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR)) { CLEAR_BIT(huart->Instance->CR3, USART_CR3_DMAR); /* Abort the UART DMA Rx channel */ if (huart->hdmarx != NULL) { /* Set the UART DMA Abort callback : will lead to call HAL_UART_ErrorCallback() at end of DMA abort procedure */ huart->hdmarx->XferAbortCallback = UART_DMAAbortOnError; if (HAL_DMA_Abort_IT(huart->hdmarx) != HAL_OK) { /* Call Directly XferAbortCallback function in case of error */ huart->hdmarx->XferAbortCallback(huart->hdmarx); } } else { /* Call user error callback */ #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) /*Call registered error callback*/ huart->ErrorCallback(huart); #else /*Call legacy weak error callback*/ HAL_UART_ErrorCallback(huart); #endif /* USE_HAL_UART_REGISTER_CALLBACKS */ } } else { /* Call user error callback */ #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) /*Call registered error callback*/ huart->ErrorCallback(huart); #else /*Call legacy weak error callback*/ HAL_UART_ErrorCallback(huart); #endif /* USE_HAL_UART_REGISTER_CALLBACKS */ } } else { /* Non Blocking error : transfer could go on. Error is notified to user through user error callback */ #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) /*Call registered error callback*/ huart->ErrorCallback(huart); #else /*Call legacy weak error callback*/ HAL_UART_ErrorCallback(huart); #endif /* USE_HAL_UART_REGISTER_CALLBACKS */ huart->ErrorCode = HAL_UART_ERROR_NONE; } } return; } /* End if some error occurs */ /* UART in mode Transmitter ------------------------------------------------*/ if (((isrflags & USART_SR_TXE) != RESET) && ((cr1its & USART_CR1_TXEIE) != RESET)) { UART_Transmit_IT(huart); return; } /* UART in mode Transmitter end --------------------------------------------*/ if (((isrflags & USART_SR_TC) != RESET) && ((cr1its & USART_CR1_TCIE) != RESET)) { UART_EndTransmit_IT(huart); return; } } //中断接收 /** * @brief Receives an amount of data in non blocking mode * @param huart Pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @retval HAL status */ static HAL_StatusTypeDef UART_Receive_IT(UART_HandleTypeDef *huart) { uint16_t *tmp; |
/* Check that a Rx process is ongoing */
if (huart->RxState == HAL_UART_STATE_BUSY_RX) //如果忙 { if (huart->Init.WordLength == UART_WORDLENGTH_9B) // 1:一个起始位, 9个数据位, n个停止位。 { tmp = (uint16_t *) huart->pRxBuffPtr; //tmp =pRxBuffPtr,接收缓冲器 if (huart->Init.Parity == UART_PARITY_NONE)//无奇偶校验 { *tmp = (uint16_t)(huart->Instance->DR & (uint16_t)0x01FF); huart->pRxBuffPtr += 2U; } else { *tmp = (uint16_t)(huart->Instance->DR & (uint16_t)0x00FF); huart->pRxBuffPtr += 1U; } } else //数据位8位7位小于等于8位.... { if (huart->Init.Parity == UART_PARITY_NONE) { *huart->pRxBuffPtr++ = (uint8_t)(huart->Instance->DR & (uint8_t)0x00FF);//没有奇偶校验,全部为数据 } else { *huart->pRxBuffPtr++ = (uint8_t)(huart->Instance->DR & (uint8_t)0x007F);//有奇偶校验,除掉第8位,取得7位数据 } } if (--huart->RxXferCount == 0U) { /* Disable the UART Data Register not empty Interrupt */ __HAL_UART_DISABLE_IT(huart, UART_IT_RXNE); //关闭中断 /* Disable the UART Parity Error Interrupt */ __HAL_UART_DISABLE_IT(huart, UART_IT_PE); //关闭中断 /* Disable the UART Error Interrupt: (Frame error, noise error, overrun error) */ __HAL_UART_DISABLE_IT(huart, UART_IT_ERR); //关闭中断 /* Rx process is completed, restore huart->RxState to Ready */ huart->RxState = HAL_UART_STATE_READY; //接收完成 #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) /*Call registered Rx complete callback*/ huart->RxCpltCallback(huart); #else /*Call legacy weak Rx complete callback*/ HAL_UART_RxCpltCallback(huart); //中断服务函数 #endif /* USE_HAL_UART_REGISTER_CALLBACKS */ return HAL_OK; } return HAL_OK; } else { return HAL_BUSY; } } __weak void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) //本函数是__weak ,需要重写。 { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE: This function should not be modified, when the callback is needed, the HAL_UART_RxCpltCallback could be implemented in the user file */ } |
1786 浏览 1 评论
1622 浏览 1 评论
1089 浏览 2 评论
730 浏览 2 评论
1680 浏览 2 评论
1942浏览 9评论
739浏览 4评论
576浏览 3评论
599浏览 3评论
561浏览 3评论
GMT+8, 2024-12-25 23:27 , Processed in 0.667135 second(s), Total 45, Slave 40 queries .
