STM32F7xx —— 内部flash
这个就没什么好说的了,直接上代码了,主要封装了三个函数,擦除,写flash,读flash。 // STM32F767IGT6: 1M flash // STM32F767ZIT6: 2M flash #define ADDR_FLASH_SECTOR_0 ((uint32_t)0x08000000) /* Base @ of Sector 0, 32 Kbytes */ #define ADDR_FLASH_SECTOR_1 ((uint32_t)0x08008000) /* Base @ of Sector 1, 32 Kbytes */ #define ADDR_FLASH_SECTOR_2 ((uint32_t)0x08010000) /* Base @ of Sector 2, 32 Kbytes */ #define ADDR_FLASH_SECTOR_3 ((uint32_t)0x08018000) /* Base @ of Sector 3, 32 Kbytes */ #define ADDR_FLASH_SECTOR_4 ((uint32_t)0x08020000) /* Base @ of Sector 4, 128 Kbytes */ #define ADDR_FLASH_SECTOR_5 ((uint32_t)0x08040000) /* Base @ of Sector 5, 256 Kbytes */ #define ADDR_FLASH_SECTOR_6 ((uint32_t)0x08080000) /* Base @ of Sector 6, 256 Kbytes */ #define ADDR_FLASH_SECTOR_7 ((uint32_t)0x080C0000) /* Base @ of Sector 7, 256 Kbytes */ #ifdef STM32F767ZIT6 #define ADDR_FLASH_SECTOR_8 ((uint32_t)0x08100000) /* Base @ of Sector 8, 256 Kbytes */ #define ADDR_FLASH_SECTOR_9 ((uint32_t)0x08140000) /* Base @ of Sector 9, 256 Kbytes */ #define ADDR_FLASH_SECTOR_10 ((uint32_t)0x08180000) /* Base @ of Sector 10, 256 Kbytes */ #define ADDR_FLASH_SECTOR_11 ((uint32_t)0x081C0000) /* Base @ of Sector 11, 256 Kbytes */ #endif // 获取要擦除扇区编号 static uint32_t flash_sector_number(uint32_t address) { uint32_t sector = 0; if((address < ADDR_FLASH_SECTOR_1) && (address >= ADDR_FLASH_SECTOR_0)) { sector = FLASH_SECTOR_0; } else if((address < ADDR_FLASH_SECTOR_2) && (address >= ADDR_FLASH_SECTOR_1)) { sector = FLASH_SECTOR_1; } else if((address < ADDR_FLASH_SECTOR_3) && (address >= ADDR_FLASH_SECTOR_2)) { sector = FLASH_SECTOR_2; } else if((address < ADDR_FLASH_SECTOR_4) && (address >= ADDR_FLASH_SECTOR_3)) { sector = FLASH_SECTOR_3; } else if((address < ADDR_FLASH_SECTOR_5) && (address >= ADDR_FLASH_SECTOR_4)) { sector = FLASH_SECTOR_4; } else if((address < ADDR_FLASH_SECTOR_6) && (address >= ADDR_FLASH_SECTOR_5)) { sector = FLASH_SECTOR_5; } else if((address < ADDR_FLASH_SECTOR_7) && (address >= ADDR_FLASH_SECTOR_6)) { sector = FLASH_SECTOR_6; } #ifdef STM32F767ZIT6 else if((address < ADDR_FLASH_SECTOR_8) && (address >= ADDR_FLASH_SECTOR_7)) { sector = FLASH_SECTOR_7; } else if((address < ADDR_FLASH_SECTOR_9) && (address >= ADDR_FLASH_SECTOR_8)) { sector = FLASH_SECTOR_8; } else if((address < ADDR_FLASH_SECTOR_10) && (address >= ADDR_FLASH_SECTOR_9)) { sector = FLASH_SECTOR_9; } else if((address < ADDR_FLASH_SECTOR_11) && (address >= ADDR_FLASH_SECTOR_10)) { sector = FLASH_SECTOR_10; } else if((address < 0x081C0000) && (address >= ADDR_FLASH_SECTOR_11)) { sector = FLASH_SECTOR_11; } #else else if(address >= ADDR_FLASH_SECTOR_7) { sector = FLASH_SECTOR_6; } #endif return sector; } // 擦除指定扇区数据 仔细的朋友会发现count没有用到,这里可以任意更改,我是为了兼容F1的命名。 void SocFlashErase(uint32_t addr, uint8_t count) { FLASH_EraseInitTypeDef flash_erase; uint32_t flash_error; HAL_FLASH_Unlock(); flash_erase.TypeErase = FLASH_TYPEERASE_SECTORS; // 擦除类型,扇区擦除 flash_erase.Sector = flash_sector_number(addr); // 要擦除的扇区 flash_erase.NbSectors = 1; // 一次只擦除一个扇区 这里可以使用参数的count 为了防止错误操作这里写成1 flash_erase.VoltageRange = FLASH_VOLTAGE_RANGE_3; // 电压范围,VCC=2.7~3.6V之间!! __HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR | FLASH_FLAG_PGAERR | FLASH_FLAG_PGPERR | FLASH_FLAG_ERSERR | FLASH_FLAG_BSY); HAL_FLASHEx_Erase(&flash_erase, &flash_error); FLASH_WaitForLastOperation(50000); HAL_FLASH_Lock(); } uint8_t SocFlashWrite(uint32_t addr, uint8_t *buffer, uint32_t length) { uint32_t i; uint16_t data = 0; if (length == 0) { return 0; } HAL_FLASH_Unlock(); __HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR | FLASH_FLAG_PGAERR | FLASH_FLAG_PGPERR | FLASH_FLAG_ERSERR | FLASH_FLAG_BSY); // 按半字编程 for (i = 0; i < length; i += 2) { data = (*(buffer + i + 1) << 8) + (*(buffer + i)); HAL_FLASH_Program(FLASH_TYPEPROGRAM_HALFWORD, (uint32_t)(addr + i), data); } HAL_FLASH_Lock(); return 0; } uint32_t SocFlashRead(uint32_t addr, uint8_t *buffer, uint32_t length) { memcpy(buffer, (void *)addr, length); return length; } |
1959 浏览 1 评论
1740 浏览 1 评论
1212 浏览 2 评论
803 浏览 2 评论
1766 浏览 2 评论
2010浏览 9评论
860浏览 4评论
303浏览 3评论
653浏览 3评论
654浏览 3评论
GMT+8, 2025-2-13 10:49 , Processed in 0.698213 second(s), Total 42, Slave 37 queries .
