扫一扫,分享给好友
1.首先打开startup_stm32f10x_hd.s文件,右击systemInit,进入函数;在SystemInit函数中,找到SetSysClock()函数,右击进入函数;在SetSysClock()函数中找到SetSysClockTo72(),把系统时钟设置为72MHZ,右击进入函数; 在函数中找到 /* PLL configuration: PLLCLK = HSE * 9 = 72 MHz // PLL configuration: PLLCLK = HSE * 9 = 72 MHz / RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL)); RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9),将最后的RCC_CFGR_PLLMULL9改为RCC_CFGR_PLLMULL6,126,刚好72MHZ; 2.在stm32f10x.h中找到 #if !defined HSE_VALUE #ifdef STM32F10X_CL #define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz / #else #define HSE_VALUE ((uint32_t)8000000) /!< Value of the External oscillator in Hz / #endif / STM32F10X_CL / #endif / HSE_VALUE */ #define HSE_STARTUP_TIMEOUT ((uint16_t)0x0500) /*!< Time out for HSE start up */ #define HSI_VALUE ((uint32_t)8000000) /!< Value of the Internal oscillator in Hz/, 把8000000,改为12000000; 3.将8.0改为12.0. |
2232 浏览 1 评论
1856 浏览 1 评论
1355 浏览 2 评论
884 浏览 2 评论
2218 浏览 2 评论
2122浏览 9评论
1052浏览 4评论
414浏览 3评论
742浏览 3评论
722浏览 3评论
GMT+8, 2025-4-23 11:49 , Processed in 1.053881 second(s), Total 45, Slave 39 queries .
