1. STM32串口默认是打开Overrun、DMA on RX Error
2. 使用HAL库,打开Overrun 如果出现错误,HAL库函数会关闭接收,再调用错误回调函数(用户需实现,不然串口接收不再工作,从外部看串口死机) void HAL_UART_IRQHandler(UART_HandleTypeDef *huart) { errorcode = huart->ErrorCode; if ((HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR)) || ((errorcode & (HAL_UART_ERROR_RTO | HAL_UART_ERROR_ORE)) != 0U)) { /* Blocking error : transfer is aborted Set the UART state ready to be able to start again the process, Disable Rx Interrupts, and disable Rx DMA request, if ongoing */ UART_EndRxTransfer(huart); //关闭接收 HAL_UART_ErrorCallback(huart); //调用错误回调函数 } } HAL_StatusTypeDef HAL_UART_Init(UART_HandleTypeDef *huart) { if (huart->AdvancedInit.AdvFeatureInit != UART_ADVFEATURE_NO_INIT) { UART_AdvFeatureConfig(huart); } } 所以需在错误回调中重新开启接收 uint8_t buf[10]; void HAL_UART_ErrorCallback(UART_HandleTypeDef *huart) { if(huart == &huart1) { __HAL_UNLOCK(huart); HAL_UART_Receive_IT(&huart1,buf,1); } } /** * @brief Configure the UART peripheral advanced features. * @param huart UART handle. * @retval None */ void UART_AdvFeatureConfig(UART_HandleTypeDef *huart) { /* Check whether the set of advanced features to configure is properly set */ assert_param(IS_UART_ADVFEATURE_INIT(huart->AdvancedInit.AdvFeatureInit)); /* if required, configure RX overrun detection disabling */ if (HAL_IS_BIT_SET(huart->AdvancedInit.AdvFeatureInit, UART_ADVFEATURE_RXOVERRUNDISABLE_INIT)) { assert_param(IS_UART_OVERRUN(huart->AdvancedInit.OverrunDisable)); MODIFY_REG(huart->Instance->CR3, USART_CR3_OVRDIS, huart->AdvancedInit.OverrunDisable); } /* if required, configure DMA disabling on reception error */ if (HAL_IS_BIT_SET(huart->AdvancedInit.AdvFeatureInit, UART_ADVFEATURE_DMADISABLEONERROR_INIT)) { assert_param(IS_UART_ADVFEATURE_DMAONRXERROR(huart->AdvancedInit.DMADisableonRxError)); MODIFY_REG(huart->Instance->CR3, USART_CR3_DDRE, huart->AdvancedInit.DMADisableonRxError); } } 3. 在不使用HAL库来实现串口接收时需禁止Overrun,不然出现串口接收溢出,则串口自动关闭接收,从外部看来串口死机。 |
1780 浏览 1 评论
1621 浏览 1 评论
1081 浏览 2 评论
728 浏览 2 评论
1679 浏览 2 评论
1938浏览 9评论
731浏览 4评论
570浏览 3评论
596浏览 3评论
556浏览 3评论
GMT+8, 2024-12-23 20:52 , Processed in 0.589717 second(s), Total 43, Slave 38 queries .
