电子发烧友论坛|
STM32F103C8T6串口1(PA10/RXD1,PA9/TXD1)用来烧写程序,串口2(PA3/RXD2,PA2/TXD2)接串口模块与电脑串口助手通信。IO口PA1接LED+470R电阻+D3V3。
调试后,能正常运行的程序如下: #include "stm32f10x.h" #include "stm32f10x_usart.h" #define LED_ON GPIO_ResetBits(GPIOA ,GPIO_Pin_1) #define LED_OFF GPIO_SetBits(GPIOA ,GPIO_Pin_1) void GPIO_Config(void); void USART2_Config(void); void RCC_Config(void); void Delay(u32 nCount) { for(; nCount != 0; nCount--); } int main(void) { RCC_Config(); //时钟设置 GPIO_Config(); USART2_Config(); while(1) { LED_OFF; Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); USART_SendData(USART2,0x12); LED_ON; Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); Delay(0xfffff); } } void RCC_Config(void) { /*开启外设时钟*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); } void GPIO_Config(void){ GPIO_InitTypeDef GPIO_InitStructure; //定义一个结构体变量 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化库函数 //PA2 TXD2 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //PA3 RXD2 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); } void USART2_Config(void) { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART2, &USART_InitStructure); USART_ITConfig(USART2, USART_IT_RXNE, ENABLE); //开启接收中断 USART_ITConfig(USART2, USART_IT_TXE, ENABLE); //开启发送中断 USART_Cmd(USART2, ENABLE); } 程序编写过程中出现的问题: 1、时钟设置函数void RCC_Config(void)中 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); 若写成 RCC_APB2PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); 程序编译能够通过,但烧写后,程序无法正常运行。 2、若没有配置串口USART2(PA3/RXD2,PA2/TXD2)对应IO口的输入输出模式,编译能够通过,但程序无法正常运行。 PA2/TXD2应配置为 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; PA3/RXD2应配置为 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; 以上问题的具体解释都可以在STM32固件函数库用户手册找到。 APB1时钟设置 GPIO模式时钟设置 |
1780 浏览 1 评论
1621 浏览 1 评论
1081 浏览 2 评论
728 浏览 2 评论
1679 浏览 2 评论
1938浏览 9评论
731浏览 4评论
570浏览 3评论
596浏览 3评论
556浏览 3评论
GMT+8, 2024-12-24 04:10 , Processed in 0.850057 second(s), Total 78, Slave 62 queries .
