3个回答
一、移植文件
PS:此工程基于STM32精英板! 将 chess.c 、 chess.h两个文件添加到过程文件夹下 1.1chess.c #include "delay.h" #include "lcd.h" #include "text.h" #include "touch.h" #include "chess.h" #include "timer.h" char param; //游戏模式 char player = p1; //默认黑棋先手 char chess[N][N]; //棋盘地图 int a[N],b[N]; //记录每一步棋子的坐标位置 int chess_num = 0; //总棋子数 char p1_time = time; //黑棋剩余时间 char p2_time = time; //白棋剩余时间 extern u16 POINT_COLOR; //画笔颜色 void start1()//开始游戏 { Oninit(); draw_checkboard();//画棋盘 //show_param(param); while (1) { chesscomputer(); } } void mymsg(int fun)//游戏结束弹出选择窗口 { LCD_Fill(Grid_wid,Grid_wid*3,Grid_wid*14,Grid_wid*9,LGRAY);//填充单色 实心矩形 BACK_COLOR=LGRAY; POINT_COLOR=BLACK; if(fun == p1) Show_Str(Grid_wid*4,Grid_wid*4,200,24,"黑棋获胜!",24,0); else if(fun == p2) Show_Str(Grid_wid*4,Grid_wid*4,200,24,"白棋获胜!",24,0); else if(fun == 3) Show_Str(Grid_wid*4,Grid_wid*4,200,24,"平局!",24,0); Show_Str(Grid_wid*2,Grid_wid*7,100,16,"重新开始",16,0); Show_Str(Grid_wid*9,Grid_wid*7,100,16,"退出游戏",16,0); POINT_COLOR=WHITE; LCD_DrawRectangle(Grid_wid*2-3, Grid_wid*7-3, Grid_wid*6+3, Grid_wid*8+3); LCD_DrawRectangle(Grid_wid*9-3, Grid_wid*7-3, Grid_wid*13+3, Grid_wid*8+3); POINT_COLOR=BLACK; BACK_COLOR=BROWN; } void Oninit()//初始化参数 { int i,j; player = p1; //默认黑棋先手 for (i = 0; i < N;i++)//棋盘清零 { a= Nochess; b= Nochess; for (j = 0; j < N; j++) { chess[j] = Nochess; } } chess_num = 0; //总棋子数清零 p1_time = time; //黑棋剩余时间 p2_time = time; //白棋剩余时间 } void selete()//选择游戏模式 { draw_interface();//显示初始游戏菜单 int xtemp,ytemp; while (1) { tp_dev.scan(0);//扫描 if (tp_dev.sta&TP_PRES_DOWN)//有按键被按下 { delay_ms(10);//必要的延时,否则老认为有按键按下. xtemp = tp_dev.x[0]; ytemp = tp_dev.y[0]; if(xtemp>=112&&xtemp<=208&&ytemp>=114&&ytemp<=146) { param=player_player; LCD_DrawRectangle(112, 114, 208, 146); delay_ms(500); return; } else if(xtemp>=112&&xtemp<=208&&ytemp>=164&&ytemp<=196) { param=player_AI; LCD_DrawRectangle(112, 164, 208, 196); delay_ms(500); return; } } else delay_ms(10); } } void start()//开始游戏 { int x1, y1; Oninit(); draw_checkboard();//画棋盘 show_param(param); show_time(); while (1) { TIM_Cmd(TIM3, ENABLE); //使能TIMx tp_dev.scan(0);//扫描 if (tp_dev.sta&TP_PRES_DOWN)//有按键被按下 { delay_ms(10);//必要的延时,否则老认为有按键按下 //按下悔棋按钮 改变外框颜色 if(tp_dev.x[0]>=Grid_wid*(N + 1)-2&&tp_dev.x[0]<=Grid_wid*(N + 3)+2&&tp_dev.y[0]>=Grid_wid*(N/2 + 1)&&tp_dev.y[0]<=Grid_wid*(N/2 + 2)+6) { LCD_DrawRectangle(Grid_wid*(N + 1)-2, Grid_wid*(N/2 + 1), Grid_wid*(N + 3)+2, Grid_wid*(N/2 + 2)+6); retract_chess();//悔棋 delay_ms(500); POINT_COLOR=WHITE; LCD_DrawRectangle(Grid_wid*(N + 1)-2, Grid_wid*(N/2 + 1), Grid_wid*(N + 3)+2, Grid_wid*(N/2 + 2)+6); POINT_COLOR=BLACK; } x1 = mod_xy(tp_dev.x[0]); y1 = mod_xy(tp_dev.y[0]); if (param == player_player) { TIM_Cmd(TIM3, DISABLE); //关闭使能TIMx外设 delay_ms(100); Chess_piece(x1, y1); } else if (param == player_AI) { if (Chess_piece(x1, y1)) { TIM_Cmd(TIM3, DISABLE); //关闭使能TIMx外设 delay_ms(500); chesscomputer(); } } } if(p1_time == 0||p2_time == 0)//到时间了则对方获胜 { p1_time=time; p2_time=time; Restart(1,p1+p2-player); } } } void Restart(int par,int player)//重新开始游戏 { if (par == 1) mymsg(player); else mymsg(3); int xtemp,ytemp; while (1) { p1_time = time; //黑棋剩余时间 p2_time = time; //白棋剩余时间 tp_dev.scan(0);//扫描 if (tp_dev.sta&TP_PRES_DOWN)//有按键被按下 { delay_ms(10);//必要的延时,否则老认为有按键按下. xtemp = tp_dev.x[0]; ytemp = tp_dev.y[0]; if(xtemp>=Grid_wid*2-3&&xtemp<=Grid_wid*6+3&&ytemp>=Grid_wid*7-3&&ytemp<=Grid_wid*8+3) { LCD_DrawRectangle(Grid_wid*2-3, Grid_wid*7-3, Grid_wid*6+3, Grid_wid*8+3); delay_ms(300); start(); } else if(xtemp>=Grid_wid*9-3&&xtemp<=Grid_wid*13+3&&ytemp>=Grid_wid*7-3&&ytemp<=Grid_wid*8+3) { LCD_DrawRectangle(Grid_wid*9-3, Grid_wid*7-3, Grid_wid*13+3, Grid_wid*8+3); delay_ms(300); //软件复位 __disable_fault_irq(); NVIC_SystemReset(); } } else delay_ms(10); } } void draw_checkboard()//绘制棋盘 { BACK_COLOR=BROWN; LCD_Clear(BROWN);//设置背景色 int i; for (i = 0; i < N;i++)//画地图 { lcd_draw_bline(m_wid + i*Grid_wid, m_wid, m_wid + i*Grid_wid, m_wid + Grid_wid * (N - 1),1,BLACK); lcd_draw_bline(m_wid, m_wid + i*Grid_wid, m_wid + Grid_wid * (N - 1), m_wid + i*Grid_wid,1,BLACK); } //3 3 3 11 7 7 11 3 11 11 五个点的位置 gui_fill_circle(m_wid+3*Grid_wid, m_wid+3*Grid_wid, 3, BLACK); gui_fill_circle(m_wid+3*Grid_wid, m_wid+11*Grid_wid, 3, BLACK); gui_fill_circle(m_wid+7*Grid_wid, m_wid+7*Grid_wid, 3, BLACK); gui_fill_circle(m_wid+11*Grid_wid, m_wid+3*Grid_wid, 3, BLACK); gui_fill_circle(m_wid+11*Grid_wid, m_wid+11*Grid_wid, 3, BLACK); } void draw_interface()//绘制初始游戏选择界面 { BACK_COLOR=LIGHTGREEN; LCD_Clear(LIGHTGREEN); int x1=72; POINT_COLOR=YELLOW; Show_Str(x1,48,200,24,"五",24,0); POINT_COLOR=WHITE; Show_Str(x1+24*3,48,200,24,"子",24,0); POINT_COLOR=BROWN; Show_Str(x1+24*6,48,200,24,"棋",24,0); POINT_COLOR=WHITE; LCD_DrawRectangle(112, 114, 208, 146); LCD_DrawRectangle(112, 164, 208, 196); POINT_COLOR=BLACK; Show_Str(128,122,200,16,"人人对战",16,0); Show_Str(128,172,200,16,"人机对战",16,0); BACK_COLOR=BROWN; } void remove_chess(int x1,int y1)//擦除棋子 { gui_fill_circle(m_wid+x1*Grid_wid, m_wid+y1*Grid_wid, Chess_R, BROWN); lcd_draw_bline(m_wid+x1*Grid_wid-Chess_R, m_wid+y1*Grid_wid,m_wid+x1*Grid_wid+Chess_R, m_wid+y1*Grid_wid,1,BLACK); lcd_draw_bline(m_wid+x1*Grid_wid, m_wid+y1*Grid_wid-Chess_R,m_wid+x1*Grid_wid, m_wid+y1*Grid_wid+Chess_R,1,BLACK); if(x1==0) lcd_draw_bline(m_wid, m_wid+y1*Grid_wid,m_wid+Chess_R, m_wid+y1*Grid_wid,1,BLACK); if(y1==0) lcd_draw_bline(m_wid+x1*Grid_wid, m_wid,m_wid+x1*Grid_wid, m_wid+Chess_R,1,BLACK); if(x1==N-1) lcd_draw_bline(m_wid+x1*Grid_wid+2, m_wid+y1*Grid_wid,m_wid+x1*Grid_wid+Chess_R, m_wid+y1*Grid_wid,1,BACK_COLOR); if(y1==N-1) lcd_draw_bline(m_wid+x1*Grid_wid, m_wid+y1*Grid_wid+1,m_wid+x1*Grid_wid, m_wid+y1*Grid_wid+Chess_R,1,BACK_COLOR); //如果是五个特殊点 五个点的位置:3 3 3 11 7 7 11 3 11 11 if( (x1==3&&y1==3) || (x1==3&&y1==11) || (x1==7&&y1==7) || (x1==11&&y1==3) || (x1==11&&y1==11) ) { gui_fill_circle(m_wid+x1*Grid_wid, m_wid+y1*Grid_wid, 3, BLACK); } } void retract_chess()//悔棋 { if(chess_num>=2) { int x1,y1; x1 = a[chess_num-1]; y1 = b[chess_num-1]; chess[x1][y1] = Nochess; remove_chess(x1,y1); chess_num--; x1 = a[chess_num-1]; y1 = b[chess_num-1]; chess[x1][y1] = Nochess; remove_chess(x1,y1); chess_num--; p1_time = time; //黑棋剩余时间 p2_time = time; //白棋剩余时间 } } void show_param(int n)//显示游戏模式 { POINT_COLOR=WHITE; if(n==player_AI) { Show_Str(Grid_wid*N,Grid_wid*(N/2 - 2), 200,16,"人机对战",16,0); } else if(n==player_player) { Show_Str(Grid_wid*N,Grid_wid*(N/2 - 2), 200,16,"人人对战",16,0); } POINT_COLOR=BLACK; Show_Str(Grid_wid*(N + 1),Grid_wid*(N/2 + 1)+3, 200,16,"悔棋",16,0); POINT_COLOR=WHITE; LCD_DrawRectangle(Grid_wid*(N + 1)-2, Grid_wid*(N/2 + 1), Grid_wid*(N + 3)+2, Grid_wid*(N/2 + 2)+6); POINT_COLOR=BLACK; } void show_time(void)//显示剩余时间 { gui_fill_circle(Grid_wid*N+Chess_R, Grid_wid*2+Chess_R, Chess_R, BLACK); Show_Str (Grid_wid*(N+1), Grid_wid*2, 200,16, "剩余:",16,0); LCD_ShowNum (Grid_wid*(N+3)+m_wid, Grid_wid*2, p1_time-1,2,16);//显示一个数字 Show_Str (Grid_wid*(N+5)-m_wid, Grid_wid*2, 200,16, "s",16,0); gui_fill_circle(Grid_wid*N+Chess_R, Grid_wid*12+Chess_R, Chess_R, WHITE); Show_Str (Grid_wid*(N+1), Grid_wid*12, 200,16, "剩余:",16,0); LCD_ShowNum (Grid_wid*(N+3)+m_wid, Grid_wid*12, p2_time-1,2,16);//显示一个数字 Show_Str (Grid_wid*(N+5)-m_wid, Grid_wid*12, 200,16, "s",16,0); } int mod_xy(int xy)//坐标修正 { int res = (int)((double)(xy-m_wid) / Grid_wid + 0.5); if (res < N && res >= 0) { return res; } else { return -1; } } int judge(int x, int y)//判断此位置是否可以落子 { return chess[x][y] ? 0 : 1; } int judge_win(int x, int y)//判断游戏输赢 { int i, j, k; const int step[4][2] = { { 1, 0 }, { 0, 1 }, { 1, 1 }, { 1, -1 } }; for (i = 0; i < 4; ++i) { const int d[2] = { -1, 1 }; int count = 1; for (j = 0; j < 2; ++j) for (k = 1; k <= 4; ++k) { int row = x + k*d[j] * step[0]; int col = y + k*d[j] * step[1]; if (row >= 1 && row <= N && col >= 1 && col <= N && chess[x][y] == chess[row][col]) count += 1; else break; } if (count >= 5) return 1; } if (chess_num == N*N) { delay_ms(1000); Restart(2,player); } return 0; } int Chess_piece(int x1, int y1)//落子 { if(x1 == -1||y1 == -1) { return 0; } if (judge(x1, y1)) { if (player == p1) gui_fill_circle(m_wid+x1*Grid_wid, m_wid+y1*Grid_wid, Chess_R, BLACK); else gui_fill_circle(m_wid+x1*Grid_wid, m_wid+y1*Grid_wid, Chess_R, WHITE); chess[x1][y1] = player; //按顺序存储每一个棋子的坐标位置 a[chess_num] = x1; b[chess_num] = y1; chess_num++; if (judge_win(x1, y1)) { delay_ms(1000); Restart(1,player); } changeplayer(); p1_time=time; LCD_ShowNum (Grid_wid*(N+3)+m_wid,Grid_wid*2, p1_time-1,2,16); //显示一个数字 p2_time=time; LCD_ShowNum (Grid_wid*(N+3)+m_wid,Grid_wid*12, p2_time-1,2,16); //显示一个数字 return 1; } return 0; } void changeplayer()//玩家交换 { player = p1 + p2 - player; } int scorejudge(int row,int col)//评分系统使用的判断是否可以落子函数 { if ((row >= 0 && row < N) && (col >= 0 && col < N)) { return 1; } else { return 0; } } |
int chessscore(int x, int y, int worb)//棋盘权值函数
{ int sumscore = 0; char u, d, l, r, lu, ld, ru, rd;//u上 d下 l左 r右 lu左上 ld左下 ru右上 rd右下 int row, col, count1, count2, count3, count4; //1横 2竖 3斜上 4斜下 count1 = count2 = count3 = count4 = 1; l = r = u = d = lu = ld = ru = rd = 0; chess[x][y] = worb; //模拟下棋 //横向 row = x, col = y + 1; while (chess[row][col] == worb && scorejudge(row,col)) { count1++; col++; } while (chess[row][col] == 0 && scorejudge(row, col)) { r++; col++; } row = x, col = y - 1; while (chess[row][col] == worb && scorejudge(row, col)) { count1++; col--; } while (chess[row][col] == 0 && scorejudge(row, col)) { l++; col--; } //竖向 row = x + 1, col = y; while (chess[row][col] == worb && scorejudge(row, col)) { count2++; row++; } while (chess[row][col] == 0 && scorejudge(row, col)) { d++; row++; } row = x - 1, col = y; while (chess[row][col] == worb && scorejudge(row, col)) { count2++; row--; } while (chess[row][col] == 0 && scorejudge(row, col)) { u++; row--; } //斜上 row = x - 1, col = y + 1; while (chess[row][col] == worb && scorejudge(row, col)) { count3++; col++; row--; } while (chess[row][col] == 0 && scorejudge(row, col)) { ru++; col++; row--; } row = x + 1, col = y - 1; while (chess[row][col] == worb && scorejudge(row, col)) { count3++; col--; row++; } while (chess[row][col] == 0 && scorejudge(row, col)) { ld++; col--; row++; } //斜下 row = x + 1, col = y + 1; while (chess[row][col] == worb && scorejudge(row, col)) { count4++; col++; row++; } while (chess[row][col] == 0 && scorejudge(row, col)) { rd++; col++; row++; } row = x - 1, col = y - 1; while (chess[row][col] == worb && scorejudge(row, col)) { count4++; col--; row--; } while (chess[row][col] == 0 && scorejudge(row, col)) { lu++; col--; row--; } chess[x][y] = Nochess; if (count1 >= 5 || count2 >= 5 || count3 >= 5 || count4 >= 5)//成五 { return sumscore = 5000000; } if ((count1 == 4 && count2 == 4 && l >= 1 && r >= 1 && u >= 1 && d >= 1) || (count1 == 4 && count3 == 4 && l >= 1 && r >= 1 && ru >= 1 && ld >= 1) || (count1 == 4 && count4 == 4 && l >= 1 && r >= 1 && rd >= 1 && lu >= 1) || (count2 == 4 && count3 == 4 && u >= 1 && d >= 1 && ru >= 1 && ld >= 1) || (count2 == 4 && count4 == 4 && u >= 1 && d >= 1 && lu >= 1 && rd >= 1) || (count3 == 4 && count4 == 4 && ru >= 1 && ld >= 1 && lu >= 1 && rd >= 1)) //双活四 { return sumscore = 4000000; } if ((count1 == 4 && l >= 1 && r >= 1) || (count2 == 4 && u >= 1 && d >= 1) || (count3 == 4 && ru >= 1 && ld >= 1) || (count4 == 4 && lu >= 1 && rd >= 1)) //活四 { return sumscore = 800000; } if ((count1 == 4 && ((l == 0 && r >= 1) || (l >= 1 && r == 0))) || (count2 == 4 && ((u == 0 && d >= 1) || (u >= 1 && d == 0))) ||(count3 == 4 && ((ld == 0 && ru >= 1) || (ld >= 1 && ru == 0))) || (count4 == 4 && ((lu == 0 && rd >= 1) || (lu >= 1 && rd == 0)))) { sumscore = sumscore + 35000; //成四 } if ((count1 == 3 && count2 == 3 && l >= 1 && r >= 1 && u >= 1 && d >= 1) || (count1 == 3 && count3 == 3 && l >= 1 && r >= 1 && ru >= 1 && ld >= 1) || (count1 == 3 && count4 == 3 && l >= 1 && r >= 1 && rd >= 1 && lu >= 1) || (count2 == 3 && count3 == 3 && u >= 1 && d >= 1 && ru >= 1 && ld >= 1) || (count2 == 3 && count4 == 3 && u >= 1 && d >= 1 && lu >= 1 && rd >= 1) || (count3 == 3 && count4 == 3 && ru >= 1 && ld >= 1 && lu >= 1 && rd >= 1)) //双活三 { return sumscore + 400000; } if ((count1 == 3 && l >= 1 && r >= 1) || (count2 == 3 && u >= 1 && d >= 1) || (count3 == 3 && ru >= 1 && ld >= 1) || (count4 == 3 && lu >= 1 && rd >= 1)) //活三 { sumscore = sumscore + 60000; return sumscore; } if ((count1 == 2 && count2 == 2 && l >= 1 && r >= 1 && u >= 1 && d >= 1) || (count1 == 2 && count3 == 2 && l >= 1 && r >= 1 && ru >= 1 && ld >= 1) || (count1 == 2 && count4 == 2 && l >= 1 && r >= 1 && rd >= 1 && lu >= 1) || (count2 == 2 && count3 == 2 && u >= 1 && d >= 1 && ru >= 1 && ld >= 1) || (count2 == 2 && count4 == 2 && u >= 1 && d >= 1 && lu >= 1 && rd >= 1) || (count3 == 2 && count4 == 2 && ru >= 1 && ld >= 1 && lu >= 1 && rd >= 1)) //双活二 { sumscore = sumscore + 20000; } if ((count1 == 2 && l >= 1 && r >= 1) || (count2 == 2 && u >= 1 && d >= 1) || (count3 == 2 && ru >= 1 && ld >= 1) || (count4 == 2 && lu >= 1 && rd >= 1)) //单活二 { sumscore = sumscore + 10000; } if ((count1 == 3 && ((l == 0 && r >= 1) || (l >= 1 && r == 0))) || (count2 == 3 && ((u == 0 && d >= 1) || (u >= 1 && d == 0))) || (count3 == 3 && ((ld == 0 && ru >= 1) || (ld >= 1 && ru == 0))) || (count4 == 3 && ((lu == 0 && rd >= 1) || (lu >= 1 && rd == 0)))) { sumscore = sumscore + 5000; //成三 } return sumscore; } void chesscomputer()//机器落子 { int i, j, cscore, cscorel, pscore, pscorel, row1, col1, row2, col2; cscore = pscore = 0; row1 = row2 = col1 = col2 = -1; //寻找最优落子位置 if (chess_num <= 1) { row1 = 7; col1 = 7; do { row1++; col1++; } while (!judge(row1, col1)); Chess_piece(row1, col1); } else { for (i = 0; i < N; i++) { for (j = 0; j < N; j++) { if (judge(i, j)) { cscorel = chessscore(i, j, p1); if (cscorel > cscore) { cscore = cscorel; row1 = i; col1 = j; } pscorel = chessscore(i, j, p2); if (pscorel > pscore) { pscore = pscorel; row2 = i; col2 = j; } } } } if (row1 == -1 && col1 == -1 && row2 == -1 && col2 == -1)//没找到最优解 平局 { Restart(2,player); } else { if (chess_num == 3) { Chess_piece(row2, col2); } else { if (cscore > pscore) { Chess_piece(row1, col1); } else { Chess_piece(row2, col2); } } } } } |
1.2chess.h
#ifndef __CHESS_H__ #define __CHESS_H__ #define Grid_wid 16 //网格宽度 #define m_wid (Grid_wid/2) //修正宽度 #define Chess_R (Grid_wid/2) //棋子半径 #define p1 1 //玩家1 #define p2 2 //玩家2 #define Nochess 0 //空棋 #define N 15 //棋盘格数 #define player_player 3 //人人模式 #define player_AI 4 //人机模式 #define time 16 //每方下棋剩余时间 void start1(); //机器与机器对战,测试用 void mymsg(int fun); //游戏结束弹出选择窗口 void Oninit(void); //初始化参数 void selete(void); //选择游戏模式 void start(void); //开始游戏 void Restart(int par,int player); //重新开始游戏 void draw_checkboard(void); //绘制棋盘 void draw_interface(void); //绘制初始游戏选择界面 void remove_chess(int x1,int y1); //擦除棋子 void retract_chess(void); //悔棋 void show_param(int n); //显示游戏模式 void show_time(void); //显示剩余时间 int mod_xy(int xy); //坐标修正 int judge(int x, int y); //判断此位置是否可以落子 int judge_win(int x, int y); //判断游戏输赢 int Chess_piece(int x, int y); //落子 void changeplayer(void); //玩家交换 int scorejudge(int row,int col); //评分系统使用的判断是否可以落子函数 int chessscore(int x, int y, int worb);//棋盘权值函数 void chesscomputer(void); //机器落子 #endif 二、运行游戏 2.1 修改main.c添加Restart函数并调用start函数 #include "stm32f10x.h" #include "sys.h" #include "delay.h" #include "usart.h" #include "led.h" #include "lcd.h" #include "key.h" #include "malloc.h" #include "sdio_sdcard.h" #include "w25qxx.h" #include "ff.h" #include "exfuns.h" #include "text.h" #include "atk_ncr.h" #include "touch.h" #include "chess.h" #include "timer.h" int main(void) { delay_init(); //延时函数初始化 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级 uart_init(115200); //串口初始化为115200 LED_Init(); //初始化与LED连接的硬件接口 KEY_Init(); //初始化按键 LCD_Init(); //初始化LCD W25QXX_Init(); //初始化W25Q128 tp_dev.init(); //初始化触摸屏 my_mem_init(SRAMIN); //初始化内部内存池 exfuns_init(); //为fatfs相关变量申请内存 f_mount(fs[0], "0:", 1); //挂载SD卡 f_mount(fs[1], "1:", 1); //挂载FLASH. alientek_ncr_init(); //初始化手写识别 while (font_init()) //检查字库 { LCD_ShowString(30, 50, 200, 16, 16, "Font Error!"); delay_ms(200); LCD_Fill(30, 50, 240, 66, WHITE);//清除显示 } TIM3_Int_Init(9999,7199);//计时器 1s TP_Init(); //TP_Adjust(); //start1();//开始游戏 selete();//游戏模式选择 start();//开始游戏 } |
1979 浏览 1 评论
1761 浏览 1 评论
1233 浏览 2 评论
819 浏览 2 评论
1776 浏览 2 评论
2015浏览 9评论
895浏览 4评论
320浏览 3评论
673浏览 3评论
662浏览 3评论
GMT+8, 2025-2-24 17:14 , Processed in 0.977638 second(s), Total 79, Slave 62 queries .
