UART接收发送数据:
平台:STM32F401 discovery版 此代码用的UART6,TX,RX对应的PIN脚是PC6,PC7 如图: 代码如下: 步骤一:初始化串口的GPIO,USART,并且配置上UART的RX中断 void USART6_Config(void) { USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIO clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC , ENABLE); /* Enable USART clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART6, ENABLE); /* Connect USART pins to */ GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_USART6); GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_USART6); /* Configure USART Tx and Rx as alternate function push-pull */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz ; //GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; GPIO_Init(GPIOC, &GPIO_InitStructure); /* USARTx configuration ----------------------------------------------------*/ USART_InitStructure.USART_BaudRate = 115200 ; //5250000; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART6, &USART_InitStructure); /* Enable the USARTx Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART6_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); USART_ITConfig(USART6, USART_IT_RXNE, ENABLE); USART_Cmd(USART6, ENABLE); } 步骤二:测试一下TX,即用printf,但是printf内部是调用fputs,所以需要重定向一下 int fputc(int ch, FILE *f) { USART_SendData(USART6, (unsigned char) ch); while (!(USART6->SR & USART_FLAG_TXE)); return (ch); } int fgetc(FILE *f) { while (USART_GetFlagStatus(USART6, USART_FLAG_RXNE) == RESET); return (int)USART_ReceiveData(USART6); } 步骤三:编写RX中断函数 void USART6_IRQHandler(void) { uint8_t ch; if(USART_GetITStatus(USART6, USART_IT_RXNE) != RESET) { ch = USART_ReceiveData(USART6); printf( "%cn", ch ); } } 注意地方:使用的IAR,冲定向的时候出现FILE类型找不到,可是在C原因中#include 追代码发现: #if _DLIB_FILE_DESCRIPTOR typedef _Filet FILE; #endif /* _DLIB_FILE_DESCRIPTOR */ _DLIB_FILE_DESCRIPTOR宏是0,但是IAR又不让修改,所以肯定是哪里的lib没有配置,于是找到如图就搞定了 |
1950 浏览 1 评论
1732 浏览 1 评论
1201 浏览 2 评论
795 浏览 2 评论
1759 浏览 2 评论
2007浏览 9评论
848浏览 4评论
293浏览 3评论
647浏览 3评论
651浏览 3评论
GMT+8, 2025-2-9 11:09 , Processed in 0.692920 second(s), Total 41, Slave 36 queries .
