在 STM32F4 固件库中对串口 USART 的描述原文如下:
************************************************************************ * @brief This file provides firmware functions to manage the following * functionalities of the Universal synchronous asynchronous receiver * transmitter (USART): * + Initialization and Configuration * + Data transfers * + Multi-Processor Communication * + LIN mode * + Half-duplex mode * + Smartcard mode * + IrDA mode * + DMA transfers management * + Interrupts and flags management * =================================================================== ##### How to use this driver ##### =================================================================== [..] (#) Enable peripheral clock using the following functions RCC_APB2PeriphClockCmd(RCC_APB2Periph_USARTx, ENABLE) for USART1 and USART6 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USARTx, ENABLE) for USART2, USART3, UART4 or UART5. (#) According to the USART mode, enable the GPIO clocks using RCC_AHB1PeriphClockCmd() function. (The I/O can be TX, RX, CTS, or/and SCLK). (#) Peripheral's alternate function: (++) Connect the pin to the desired peripherals' Alternate Function (AF) using GPIO_PinAFConfig() function (++) Configure the desired pin in alternate function by: GPIO_InitStruct->GPIO_Mode = GPIO_Mode_AF (++) Select the type, pull-up/pull-down and output speed via GPIO_PuPd, GPIO_OType and GPIO_Speed members (++) Call GPIO_Init() function (#) Program the Baud Rate, Word Length , Stop Bit, Parity, Hardware flow control and Mode(Receiver/Transmitter) using the USART_Init() function. (#) For synchronous mode, enable the clock and program the polarity, phase and last bit using the USART_ClockInit() function. (#) Enable the NVIC and the corresponding interrupt using the function USART_ITConfig() if you need to use interrupt mode. (#) When using the DMA mode (++) Configure the DMA using DMA_Init() function (++) Active the needed channel Request using USART_DMACmd() function (#) Enable the USART using the USART_Cmd() function. (#) Enable the DMA using the DMA_Cmd() function, when using DMA mode. -@- Refer to Multi-Processor, LIN, half-duplex, Smartcard, IrDA sub-sections for more details [..] In order to reach higher communication baudrates, it is possible to enable the oversampling by 8 mode using the function USART_OverSampling8Cmd(). This function should be called after enabling the USART clock (RCC_APBxPeriphClockCmd()) and before calling the function USART_Init(). @endverbatim ****************************************************************************** * @attention * *
1932 浏览 1 评论
1705 浏览 1 评论
1185 浏览 2 评论
785 浏览 2 评论
1750 浏览 2 评论
1992浏览 9评论
827浏览 4评论
279浏览 3评论
637浏览 3评论
644浏览 3评论
GMT+8, 2025-2-2 19:32 , Processed in 0.650593 second(s), Total 44, Slave 38 queries .
