以USART1为例,解释
//以STM32F429IGT6为例 /** @addtogroup Peripheral_memory_map * @{ */ #define PERIPH_BASE ((uint32_t)0x40000000) /*!< Peripheral base address in the alias region /*!< Peripheral memory map */ #define APB2PERIPH_BASE (PERIPH_BASE + 0x00010000) /*!< APB2 peripherals */ #define USART1_BASE (APB2PERIPH_BASE + 0x1000) /** @addtogroup Peripheral_declaration * @{ */ #define USART1 ((USART_TypeDef *) USART1_BASE)//将USART1_BASE强转为指向USART_TypeDef类型的指针 //开辟一个以0x40000000+0x00010000+ 0x1000为地址的结构体指针 /** * @brief Universal Synchronous Asynchronous Receiver Transmitter */ typedef struct { __IO uint32_t SR; /*!< USART Status register, Address offset: 0x00 */ __IO uint32_t DR; /*!< USART Data register, Address offset: 0x04 */ __IO uint32_t BRR; /*!< USART Baud rate register, Address offset: 0x08 */ __IO uint32_t CR1; /*!< USART Control register 1, Address offset: 0x0C */ __IO uint32_t CR2; /*!< USART Control register 2, Address offset: 0x10 */ __IO uint32_t CR3; /*!< USART Control register 3, Address offset: 0x14 */ __IO uint32_t GTPR; /*!< USART Guard time and prescaler register, Address offset: 0x18 */ } USART_TypeDef; //初始化IO 串口1 //bound:波特率 void uart_init(u32 bound) { //UART 初始化设置 UART1_Handler.Instance=USART1; //USART1 UART1_Handler.Init.BaudRate=bound; //波特率 UART1_Handler.Init.WordLength=UART_WORDLENGTH_8B; //字长为8位数据格式 UART1_Handler.Init.StopBits=UART_STOPBITS_1; //一个停止位 UART1_Handler.Init.Parity=UART_PARITY_NONE; //无奇偶校验位 UART1_Handler.Init.HwFlowCtl=UART_HWCONTROL_NONE; //无硬件流控 UART1_Handler.Init.Mode=UART_MODE_TX_RX; //收发模式 HAL_UART_Init(&UART1_Handler); //HAL_UART_Init()会使能UART1 } |
2134 浏览 1 评论
1833 浏览 1 评论
1312 浏览 2 评论
856 浏览 2 评论
2198 浏览 2 评论
2105浏览 9评论
1010浏览 4评论
388浏览 3评论
718浏览 3评论
708浏览 3评论
GMT+8, 2025-4-5 10:16 , Processed in 0.978312 second(s), Total 78, Slave 60 queries .
