GPIO_InitTypeDef GPIO_InitStructure;
24 USART_InitTypeDef USART_InitStructure; 25 NVIC_InitTypeDef NVIC_InitStructure; 初始化gpio 30 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 31 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; 32 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 33 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9 34 35 //USART1_RX GPIOA.10初始化 36 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10 37 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 38 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10 Usart1 NVIC 配置 41 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级 0-3; 42 43 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; 44 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3 45 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 46 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 47 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 48 USART 初始化设置 50 51 USART_InitStructure.USART_BaudRate = 115200;//串口波特率 52 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 53 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 54 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 55 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 56 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 57 58 USART_Init(USART1, &USART_InitStructure); //初始化串口1 59 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断 60 USART_Cmd(USART1, ENABLE); //使能串口1 // 发送一个字节 void usart_sendbyte(USART_TypeDef * pUSARTx, uint8_t ch) { // 第一步,发送一个字节 USART_SendData(USART1, ch); // 等待发送完成 while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) { } } void usart_sendstring(USART_TypeDef * pUSARTx, char *data) { // 发送每个字符,不包括结束字符’ ’ while(*data != ‘ ’) { usart_sendbyte(pUSARTx, *data); data++; } } // 实现fputc int fputc(int ch, FILE *f) { usart_sendbyte(USART1, ch); return ch; } // 禁止半主机模式,没有勾选MicroLib #pragma import(__use_no_semihosting) struct __FILE { int a; }; FILE __stdout; void _sys_exit(int x) { } |
1561 浏览 1 评论
1501 浏览 1 评论
933 浏览 2 评论
665 浏览 2 评论
1555 浏览 2 评论
1847浏览 9评论
609浏览 4评论
503浏览 3评论
507浏览 3评论
488浏览 3评论
GMT+8, 2024-11-10 15:39 , Processed in 0.516055 second(s), Total 45, Slave 40 queries .
