代码部分:
void my_uart_init() { //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //使能USART2,GPIOA时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); //USART2_TX GPIOA.2 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA.2 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.2 //USART2_RX GPIOA.3初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA.3 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.3 //Usart2 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority= 1 ;//抢占优先级1 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //子优先级1 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //USART 初始化设置 USART_InitStructure.USART_BaudRate = 1200;//串口波特率->根据需要修改 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART2, &USART_InitStructure); //初始化串口2 USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启串口接受中断 USART_Cmd(USART2, ENABLE); //使能串口2 } //简单中断函数接收到消息发送出去 void USART2_IRQHandler(void) { if(USART_GetITStatus(USART2,USART_IT_RXNE)) { value= USART_ReceiveData(USART2); //接收数据 } USART_SendData(USART2,Res); //发送数据 } 注意: 如果要用到USART2,下面一定不能错 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); |
1979 浏览 1 评论
1761 浏览 1 评论
1233 浏览 2 评论
819 浏览 2 评论
1776 浏览 2 评论
2015浏览 9评论
895浏览 4评论
320浏览 3评论
673浏览 3评论
662浏览 3评论
GMT+8, 2025-2-24 17:49 , Processed in 0.792386 second(s), Total 75, Slave 59 queries .
