stm32支持接受单个数据或者一帧数据,若配置单个数据接收中断的话,会出现接收包丢包,数据不完整的情况!因此在stm32的串口中断中,还有一个IDLE中断,用来产生串口接受一帧数据而产生的中断,比如说串口发来n个数据,会产生n次接收中断和一次IDLE中断,因此方便使用者来接收主机发送或者从机返回的数据!
1、配置串口中断 void USART1_Configuration(void) { USART_InitTypeDef USART_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Configure USART1 Rx (PA.10) as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //¸¡¿ÕÊäÈëģʽ GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure USART1 Tx (PA.09) as alternate function push-pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //¸ GPIO_Init(GPIOA, &GPIO_InitStructure); USART_InitStructure.USART_BaudRate = 9600; // USART_InitStructure.USART_WordLength = USART_WordLength_8b; // USART_InitStructure.USART_StopBits = USART_StopBits_1; // USART_InitStructure.USART_Parity = USART_Parity_No; // USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; /* Configure USART1 */ USART_Init(USART1, &USART_InitStructure); /* Enable USART1 Receive and Transmit interrupts */ USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); // USART_ITConfig(USART1, USART_IT_IDLE, ENABLE);// /* Enable the USART1 */ USART_Cmd(USART1, ENABLE); // } 关键 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//没收到一个字节进入一次中断 USART_ITConfig(USART1, USART_IT_IDLE, ENABLE); //开启串口空闲中断,每收到一帧数据进入一次中断 2、串口中断函数 处理一帧数据中所需要的内容 一帧数据原始内容: 我要提取出这帧数据中的31.93 char rece_buffer[BUFSIZ]; int RxCounter; void USART1_IRQHandler(void) { u8 clear=clear; USART_ClearFlag(USART1,USART_FLAG_TC); //接收一帧数据 if(USART_GetITStatus(USART1,USART_IT_RXNE)!=Bit_RESET) { rece_buffer[RxCounter++]=USART1->DR; } else if(USART_GetFlagStatus(USART1,USART_FLAG_IDLE)!=Bit_RESET) { clear=USART1->SR; clear=USART1->DR; RxCounter=0; //温度传感器的一帧数据,对需要的内容进行提取 if((rece_buffer[0]=='o')&&(rece_buffer[1]=='b')&&(rece_buffer[2]=='j')) { if(rece_buffer[9]=='-') //¸ºÊý { ; } else { if(rece_buffer[10]=='.') //x.xx { obj=(rece_buffer[9]-0x30)*100+(rece_buffer[11]-0x30)*10+(rece_buffer[2]-0x30); } if(rece_buffer[11]=='.') //xx.xx { obj=(rece_buffer[9]-0x30)*1000+(rece_buffer[10]-0x30)*100+(rece_buffer[12]-0x30)*10+(rece_buffer[13]-0x30); } if(rece_buffer[12]=='.') //xxx.xx { obj=(rece_buffer[9]-0x30)*10000+(rece_buffer[10]-0x30)*1000+(rece_buffer[11]-0x30)*100+(rece_buffer[13]-0x30)*10+(rece_buffer[14]-0x30)*10; } obj_T=obj/100; } printf("目标温度:%f",obj_T); } //printf("%s",rece_buffer); } } 最终获得需要是数据 |
1786 浏览 1 评论
1622 浏览 1 评论
1089 浏览 2 评论
730 浏览 2 评论
1680 浏览 2 评论
1941浏览 9评论
739浏览 4评论
576浏览 3评论
598浏览 3评论
560浏览 3评论
GMT+8, 2024-12-25 11:11 , Processed in 0.767244 second(s), Total 75, Slave 59 queries .
