一、硬件基础
1、STM3H743核心板 2、自制串口拓展板(控制485收发使用的TDHx01D485H2隔离模块,该模块EN为低电平是发送,高电平接收) 3、485串口模块 二、软件基础 从正点原子官方下载hal库例程,移植485.c文件,进行适当修改,我一共配置6个串口,以UART5对应的485_5.h和485_5.c为例进行配置: 1、RS485_5.h #ifndef __RS485_5_H #define __RS485_5_H #include "sys.h" extern u8 RS485_5_RX_BUF[64]; /接收缓冲 可自己定义 extern u8 RS485_5_RX_CNT; //接收数据长度 //如果想串口中断接收,设置EN_UART5_RX为1,否则设置为0 #define EN_UART5_RX 1 //0,不接收 1,接收 void RS485_5_Init(u32 bound); void RS485_5_Send_Data(u8 *buf,u8 len); void RS485_5_Receive_Data(u8 *buf,u8 *len); #endif 2、RS485_5.c 2.1 首先是控制RS485芯片的发送使能 1 /* 控制RS485芯片发送使能 */ #define RS485_TXEN_5_GPIO_CLK_ENABLE() __HAL_RCC_GPIOH_CLK_ENABLE() #define RS485_TXEN_5_GPIO_PORT GPIOA #define RS485_TXEN_5_PIN GPIO_PIN_7 #define RS485_RX_EN_5() RS485_TXEN_5_GPIO_PORT->BSRRL = RS485_TXEN_5_PIN #define RS485_TX_EN_5() RS485_TXEN_5_GPIO_PORT->BSRRH = RS485_TXEN_5_PIN 2.2 然后配置UART5中断函数 1 void UART5_IRQHandler(void) { u8 res; if(__HAL_UART_GET_IT(&UART5_RS485Handler,UART_IT_RXNE)!=RESET) //接收中断 { HAL_UART_Receive(&UART5_RS485Handler,&res,1,1000); if(RS485_5_RX_CNT<64) { RS485_5_RX_BUF[RS485_5_RX_CNT]=res; //记录接收的值 RS485_5_RX_CNT++; //接收数据增加1 } } } 2.3 然后进行485初始化配置 1 void RS485_5_Init(u32 bound) { //GPIO端口设置 GPIO_InitTypeDef GPIO_Initure; __HAL_RCC_GPIOA_CLK_ENABLE(); //使能GPIOA时钟 __HAL_RCC_GPIOB_CLK_ENABLE(); //使能GPIOB时钟 __HAL_RCC_GPIOD_CLK_ENABLE(); //使能GPIOB时钟 __HAL_RCC_UART5_CLK_ENABLE(); //使能UART5时钟 GPIO_Initure.Pin=GPIO_PIN_6; //PB6 GPIO_Initure.Mode=GPIO_MODE_AF_PP; //复用推挽输出 GPIO_Initure.Pull=GPIO_PULLUP; //上拉 GPIO_Initure.Speed=GPIO_SPEED_FREQ_VERY_HIGH;//高速 GPIO_Initure.Alternate=GPIO_AF14_UART5; //复用为UART5 TX HAL_GPIO_Init(GPIOB,&GPIO_Initure); //初始化PB6 GPIO_Initure.Pin=GPIO_PIN_2; //PD2 GPIO_Initure.Mode=GPIO_MODE_AF_PP; //复用推挽输出 GPIO_Initure.Pull=GPIO_PULLUP; //上拉 GPIO_Initure.Speed=GPIO_SPEED_FREQ_VERY_HIGH;//高速 GPIO_Initure.Alternate=GPIO_AF8_UART5; //复用为UART5 RX HAL_GPIO_Init(GPIOD,&GPIO_Initure); //初始化PD2 GPIO_Initure.Pin=GPIO_PIN_7; //PA7 GPIO_Initure.Mode=GPIO_MODE_OUTPUT_PP; //推挽输出 GPIO_Initure.Speed=GPIO_SPEED_FREQ_VERY_HIGH;//高速 HAL_GPIO_Init(GPIOA,&GPIO_Initure); //初始化PA7 //UART5初始化设置 UART5_RS485Handler.Instance=UART5; //UART5 UART5_RS485Handler.Init.BaudRate=bound; //波特率 UART5_RS485Handler.Init.WordLength=UART_WORDLENGTH_8B; //字长 UART5_RS485Handler.Init.StopBits=UART_STOPBITS_1; //一个停止位 UART5_RS485Handler.Init.Parity=UART_PARITY_NONE; //无奇偶校验位 UART5_RS485Handler.Init.HwFlowCtl=UART_HWCONTROL_NONE; //无硬件流控制 UART5_RS485Handler.Init.Mode=UART_MODE_TX_RX; //收发模式 HAL_UART_Init(&UART5_RS485Handler); //HAL_UART_Init()会使能UART5 __HAL_UART_CLEAR_IT(&UART5_RS485Handler,UART_CLEAR_TCF); #if EN_UART5_RX __HAL_UART_ENABLE_IT(&UART5_RS485Handler,UART_IT_RXNE);//开启接收中断 HAL_NVIC_EnableIRQ(UART5_IRQn); //使能UART5中断 HAL_NVIC_SetPriority(UART5_IRQn,3,3); //抢占优先级3,子优先级3 #endif // RS485_RX_EN_5(); RS485_TX_EN_5(); //设置为接收模式 } 之所以讲UART5初始化,是因为该函数有个特殊的地方,有部分STM32H743开发板使用PC12作为UART5的TX,部分电路板使用PB6,这里需要看手册,手册中可得知,PC12复用UART5的TX是AF8,PB6复用UART5的TX是AF14,没有养成看手册的习惯,这里坑了我一天,请大家注意。 2.4 发送函数 1 void RS485_5_Send_Data(u8 *buf,u8 len) { RS485_TX_EN_5(); //低电平设置为发送模式,在上面有定义 delay_ms(1); HAL_UART_Transmit(&UART5_RS485Handler,buf,len,1000);//串口2 发送数据 RS485_5_RX_CNT=0; RS485_RX_EN_5(); //设置为接收模式 delay_ms(1); } 有很多人会奇怪为什么会加delay_ms(1),此处也是一个坑,由于H743处理速度太快,当波特率设置过高时,会出现丢数据情况,越高丢的越多,因为管脚状态切换反应不过来,所以加一个1ms延时,该延时可根据具体情况自行修改,一般115200bps及以下不需要加该延时。 2.5. 接收函数 1 void RS485_5_Receive_Data(u8 *buf,u8 *len) { u8 rxlen=RS485_5_RX_CNT; u8 i=0; *len=0; delay_ms(10); if(rxlen==RS485_5_RX_CNT&&rxlen) { for(i=0;i buf=RS485_5_RX_BUF; } *len=RS485_5_RX_CNT; RS485_5_RX_CNT=0; } } 3.mian.c int main(void) { u8 rs485sendbuf5[5] = {0x51,0x53,0x55,0x58,0xff}; u8 rs485recivebuf5[5]; u8 length5; Cache_Enable(); //打开Li - cache HAL_Init(); //初始化HAL库 Stm32_Clock_Init(160,5,2,4); //设置时钟,400M delay_init(400); //RS485_1_Init(1000000); //RS485_2_Init(1000000); //RS485_3_Init(1000000); //RS485_4_Init(1000000); RS485_5_Init(1000 000); //RS485_6_Init(1000000); while(1) { RS485_5_Send_Data(rs485sendbuf5,5); delay_ms(200); RS485_5_Receive_Data(rs485recivebuf5,&length5); } } 三、心得 我的工程书如下图所示: 大拿可以将六个串口整合到一块,但是我是初学者,还有待提升,大佬勿喷,这是我做的项目的一个分支,从对STM32不太熟悉,两个礼拜一直从STM32F103学习到STM32F407,再到STM32H743,从标准库到HAL库,可能还比较笼统,没有养成看手册习惯,调试没有配合硬件一起调的习惯,继续努力改进吧。希望这篇文章中关于STM32H743的串口配置和需要注意的地方能帮助到大家。 |
1927 浏览 1 评论
1698 浏览 1 评论
1180 浏览 2 评论
779 浏览 2 评论
1745 浏览 2 评论
1985浏览 9评论
821浏览 4评论
269浏览 3评论
634浏览 3评论
638浏览 3评论
GMT+8, 2025-1-31 22:48 , Processed in 0.581699 second(s), Total 44, Slave 39 queries .
