扫一扫,分享给好友
stm32串口1的配置
#if EN_USART1_RX //如果使能了接收 //串口1中断服务程序 //注意,读取USARTx->SR能避免莫名其妙的错误 u8 USART_RX_BUF[USART_REC_LEN]; //接收缓冲,最大USART_REC_LEN个字节. //接收状态 //bit15, 接收完成标志 //bit14, 接收到0x0d //bit13~0, 接收到的有效字节数目 u16 USART_RX_STA=0; //接收状态标记 void uart_init(u32 bound){ //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟 //USART1_TX GPIOA.9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9 //USART1_RX GPIOA.10初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10 //Usart1 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //USART 初始化设置 USART_InitStructure.USART_BaudRate = bound;//串口波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口1 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断 USART_Cmd(USART1, ENABLE); //使能串口1 } void USART1_IRQHandler(void) //串口1中断服务程序 { u8 Res; #if SYSTEM_SUPPORT_OS //如果SYSTEM_SUPPORT_OS为真,则需要支持OS. OSIntEnter(); #endif if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断(接收到的数据必须是0x0d 0x0a结尾) { Res =USART_ReceiveData(USART1); //读取接收到的数据 if((USART_RX_STA&0x8000)==0)//接收未完成 { if(USART_RX_STA&0x4000)//接收到了0x0d { if(Res!=0x0a)USART_RX_STA=0;//接收错误,重新开始 else USART_RX_STA|=0x8000; //接收完成了 } else //还没收到0X0D { if(Res==0x0d)USART_RX_STA|=0x4000; else { USART_RX_BUF[USART_RX_STA&0X3FFF]=Res ; USART_RX_STA++; if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收数据错误,重新开始接收 } } } } rs485通信串口2的配置 #ifdef EN_USART2_RX //如果使能了接收 //接收缓存区 u8 RS485_RX_BUF[64]; //接收缓冲,最大64个字节. //接收到的数据长度 u8 RS485_RX_CNT=0; void USART2_IRQHandler(void) { u8 res; if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) //接收到数据 { res =USART_ReceiveData(USART2); //读取接收到的数据 if(RS485_RX_CNT<64) { RS485_RX_BUF[RS485_RX_CNT]=res; //记录接收到的值 RS485_RX_CNT++; //接收数据增加1 } } } #endif //初始化IO 串口2 //pclk1:PCLK1时钟频率(Mhz) //bound:波特率 void RS485_Init(u32 bound) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE);//使能GPIOA,D时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //PD7端口配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA2 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽 GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA3 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure); RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,ENABLE);//复位串口2 RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,DISABLE);//停止复位 #ifdef EN_USART2_RX //如果使能了接收 USART_InitStructure.USART_BaudRate = bound;//波特率设置 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据长度 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;///奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式 USART_Init(USART2, &USART_InitStructure); ; //初始化串口 NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //使能串口2中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; //先占优先级2级 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级2级 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能外部中断通道 NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器 USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启中断 USART_Cmd(USART2, ENABLE); //使能串口 #endif RS485_TX_EN=0; //默认为接收模式 } //RS485发送len个字节. //buf:发送区首地址 //len:发送的字节数(为了和本代码的接收匹配,这里建议不要超过64个字节) void RS485_Send_Data(u8 *buf,u8 len) { u8 t; RS485_TX_EN=1; //设置为发送模式 for(t=0;t { while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET); USART_SendData(USART2,buf[t]); } while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET); RS485_RX_CNT=0; RS485_TX_EN=0; //设置为接收模式 } //RS485查询接收到的数据 //buf:接收缓存首地址 //len:读到的数据长度 void RS485_Receive_Data(u8 *buf,u8 *len) { u8 rxlen=RS485_RX_CNT; u8 i=0; *len=0; //默认为0 delay_ms(10); //等待10ms,连续超过10ms没有接收到一个数据,则认为接收结束 if(rxlen==RS485_RX_CNT&&rxlen)//接收到了数据,且接收完成了 { for(i=0;i { buf=RS485_RX_BUF; } *len=RS485_RX_CNT; //记录本次数据长度 RS485_RX_CNT=0; //清零 } } 由以上的两段代码可以清晰明了的学习STM32的chan串口的配置 |
1298 浏览 1 评论
1310 浏览 1 评论
721 浏览 2 评论
531 浏览 2 评论
1327 浏览 2 评论
1729浏览 9评论
438浏览 4评论
392浏览 3评论
380浏览 3评论
360浏览 3评论
GMT+8, 2024-9-20 18:34 , Processed in 0.706272 second(s), Total 43, Slave 37 queries .
