STM32F103C8T6 4*4矩阵键盘 通过串口输出,可以用来写密码锁
程序的思路如下: 1、首先需要配置的是矩阵键盘:配置两个函数: KEY44_Init(矩阵键盘初始化)和key44_Scan(扫描并获取值) 。 2、其次,设置串口(本文设置为STM32F103C8T6的串口三): 我们需要对USART进行初始化设置,详细请见下文。 3、然后就开始写我们的主函数:主函数比较简单。因为程序已经分装了。 4、最后我们要实现按下一个键,串口打出一个字符(按下1键,打出1) ——————————————————————————————————————————————————- 下边为程序:所用芯片为STM32F103C8T6 串口3的管脚为PB10 -> TX 配置复用推挽式输出 PB11 ->RX配置浮空输入 配置矩阵键盘为PA0~PA3 推挽式输出 PA4~PA7 上拉输入 矩阵键盘的配置: 声明: #define H_1 PAout(0) #define H_2 PAout(1) #define H_3 PAout(2) #define H_4 PAout(3) #define L_1 PAin(4) #define L_2 PAin(5) #define L_3 PAin(6) #define L_4 PAin(7) void KEY44_Init(void); unsigned char key44_Scan(void); KEY44_Init(矩阵键盘初始化): void KEY44_Init(void) { GPIO_InitTypeDef GPIO_InitStructure;//PA0~PA3 推挽式输出 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//初始化GPIOA时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 |GPIO_Pin_1 |GPIO_Pin_2 |GPIO_Pin_3 ; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_5 |GPIO_Pin_6 |GPIO_Pin_7 ; //PA4~PA7 上拉输入 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_Init(GPIOA, &GPIO_InitStructure); } 配置为串口三: void USART3_Init (u32 bound) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; //开启GPIOB和复用推挽式输出 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO,ENABLE); //开启USART3初始化 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE); //PB10 -> TX 配置复用推挽式输出 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 ; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); //PB11 ->RX配置浮空输入 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 ; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOB, &GPIO_InitStructure); //串口初始化 USART_InitStructure.USART_BaudRate = bound; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl =USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; USART_Init(USART3, &USART_InitStructure); //使能串口 USART_Cmd(USART3,ENABLE); USART_ClearFlag(USART3,USART_FLAG_TC);//解决发送第一个字节丢失的问题 } 主函数: #include "sys.h" # include "KEY44.h" #include "usart3.h" #include "delay.h" u8 key_num = 0;//缓冲变量 int main() { uart3_init(115200); delay_init(); KEY44_Init(); while(1) { key_num = key44_Scan(); if(key_num !=0) { printf("KEY Num is %drn",key_num); } } } 最后要注意的是,本文不是库编程打印,所以要在程序里加入以下程序,并加上头文件# include int fputc(int ch, FILE *f) { while((USART3->SR&0X40)==0);//循环发送,直到发送完毕 USART3->DR = (u8) ch; return ch; |
1883 浏览 1 评论
1661 浏览 1 评论
1146 浏览 2 评论
762 浏览 2 评论
1720 浏览 2 评论
1963浏览 9评论
790浏览 4评论
613浏览 3评论
629浏览 3评论
593浏览 3评论
GMT+8, 2025-1-12 18:28 , Processed in 0.599356 second(s), Total 44, Slave 39 queries .
