在调试Modubus协议时需要用到串口的奇偶校验位,但是平时用串口时很少用到奇偶校验位,网上搜相关的历程也很少,将自己写的串口奇偶校验代码分享上来方便以后查阅。
如果用库函数的话,添加奇偶检验位就很简单,在初始化串口的时候,将默认的无校验位修改为奇校验或者偶校验,同时将数据位设置为9位。 串口初始化代码如下: #include "uart2.h" #define CHECK_NONE_ONE_STOP 0 //无校验位 1个停止位 1有效 0 无效 #define CHECK_NONE_TWO_STOP 1 //无校验位 2个停止位 1有效 0 无效 #define CHECK_EVEN 1 //偶数校验 1有效 0 无效 #define CHECK_ODD 0 //奇数校验 1有效 0 无效 void uart2_init( u32 baud ) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE ); RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART2, ENABLE ); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init( GPIOA, &GPIO_InitStructure ); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init( GPIOA, &GPIO_InitStructure ); NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x02; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init( &NVIC_InitStructure ); USART_InitStructure.USART_BaudRate = baud; USART_InitStructure.USART_WordLength = USART_WordLength_8b; //数据位8位 USART_InitStructure.USART_Parity = USART_Parity_No; //无奇偶校验位 USART_InitStructure.USART_StopBits = USART_StopBits_1; //1位停止位 #if(CHECK_EVEN == 1) //如果定义了偶校验 数据位长度要改为9位 USART_InitStructure.USART_WordLength = USART_WordLength_9b; USART_InitStructure.USART_Parity = USART_Parity_Even; #endif #if(CHECK_ODD == 1) //如果定义了偶校验 数据位长度要改为9位 USART_InitStructure.USART_WordLength = USART_WordLength_9b; USART_InitStructure.USART_Parity = USART_Parity_Odd; #endif #if(CHECK_NONE_ONE_STOP==1) //停止位为 一位 USART_InitStructure.USART_StopBits = USART_StopBits_1; #endif #if(CHECK_NONE_TWO_STOP==1) //停止位为 两位 USART_InitStructure.USART_StopBits = USART_StopBits_2; #endif USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_Init( USART2, &USART_InitStructure ); USART_ITConfig( USART2, USART_IT_RXNE, ENABLE ); USART_Cmd( USART2, ENABLE ); } void USART2_IRQHandler( void ) { u16 tem = 0; if( USART_GetITStatus( USART2, USART_IT_RXNE ) != RESET ) { tem = USART_ReceiveData( USART2 ); USART_SendData( USART2, tem ); } } 通过宏定义来设置是否使用奇偶校验位,停止位为1位还是2位。如果使用了奇偶校验时,要将数据位设置为9位。设置好之后就不用管了,具体校验工作由硬件来完成。 在串口中断函数中实现的功能是,将串口2接收到的数据通过串口2发送出去。 在宏定义中设置为2个停止位,偶校验。 串口测试效果如下: 如果串口助手设置和单片机发送不一致时,接收到的数据就为乱码。 源码地址https://download.csdn.net/download/qq_20222919/12921508 |
1298 浏览 1 评论
1310 浏览 1 评论
721 浏览 2 评论
531 浏览 2 评论
1327 浏览 2 评论
1730浏览 9评论
440浏览 4评论
393浏览 3评论
381浏览 3评论
361浏览 3评论
GMT+8, 2024-9-20 21:38 , Processed in 0.596805 second(s), Total 72, Slave 57 queries .
