一、MLX90614
MLX90614简介 是一款用于非接触式测量的红外温度计。IR敏感型热电堆检测器芯片和信号调节ASIC都集成在同一TO-39罐封装中。MLX90614集成有低噪声放大器、1 位 ADC 单元,因此温度计兼具和专注。 该温度计前已经过恢复,可通过温度传感器提供整个温度内的温度范围(精度范围为 C0.02°) )。 用户可以将数字输出配置为脉宽调制(PWM)。标准情况下,将10位PWM配置为以0.14℃下的分辨率连续传输介于-20和120℃之间的测量温度。 二、移植环境 芯片:STM32F4 平台:keil、STM32CubeIDE 开发库类型:HAL 三、程序代码 I2C初始化 这里使用的时I2C1,引脚: PB6 ------> I2C1_SCL PB7 ------> I2C1_SDA void MLX90614init() { __HAL_RCC_GPIOC_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); hi2c1.Instance = I2C1; hi2c1.Init.ClockSpeed = 100000; hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2; hi2c1.Init.OwnAddress1 = 0; hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT; hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE; hi2c1.Init.OwnAddress2 = 0; hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE; hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE; if (HAL_I2C_Init(&hi2c1) != HAL_OK) { // Error_Handler(); } /** Configure Analogue filter */ if (HAL_I2CEx_ConfigAnalogFilter(&hi2c1, I2C_ANALOGFILTER_ENABLE) != HAL_OK) { // Error_Handler(); } /** Configure Digital filter */ if (HAL_I2CEx_ConfigDigitalFilter(&hi2c1, 0) != HAL_OK) { // Error_Handler(); } } I2C设备配置 这里比较坑,从STM32CubeIDE移植过来的I2C初始化直接使用,设备配置时错误的,需要增加以下代码才能成功初始化 void HAL_I2C_MspInit(I2C_HandleTypeDef* i2cHandle) { GPIO_InitTypeDef GPIO_InitStruct; if(i2cHandle->Instance==I2C1) { /* USER CODE BEGIN I2C1_MspInit 0 */ /* I2C super reset */ GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Speed = GPIO_SPEED_HIGH; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); HAL_GPIO_WritePin(GPIOB, 6, GPIO_PIN_SET); HAL_GPIO_WritePin(GPIOB, 7, GPIO_PIN_SET); hi2c1.Instance->CR1 = I2C_CR1_SWRST; //??I2C??? hi2c1.Instance->CR1 = 0; /**/ /**I2C1 GPIO Configuration PB6 ------> I2C1_SCL PB7 ------> I2C1_SDA */ GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_I2C1; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); /* I2C1 clock enable */ __HAL_RCC_I2C1_CLK_ENABLE(); /* USER CODE BEGIN I2C1_MspInit 1 */ /* USER CODE END I2C1_MspInit 1 */ } } void HAL_I2C_MspDeInit(I2C_HandleTypeDef* i2cHandle) { if(i2cHandle->Instance==I2C1) { /* USER CODE BEGIN I2C1_MspDeInit 0 */ /* USER CODE END I2C1_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_I2C1_CLK_DISABLE(); /**I2C1 GPIO Configuration PB6 ------> I2C1_SCL PB7 ------> I2C1_SDA */ HAL_GPIO_DeInit(GPIOB, GPIO_PIN_6|GPIO_PIN_7); /* USER CODE BEGIN I2C1_MspDeInit 1 */ /* USER CODE END I2C1_MspDeInit 1 */ } } 其他算法部分 #include #include #include #include #include "stm32f4xx_hal.h" #include "mlx90614.h" //#include "sys.h" I2C_HandleTypeDef hi2c1; char *temp_buff= ""; int i=0; static const uint8_t crc_table[] = { 0x00, 0x07, 0x0e, 0x09, 0x1c, 0x1b, 0x12, 0x15, 0x38, 0x3f, 0x36, 0x31, 0x24, 0x23, 0x2a, 0x2d, 0x70, 0x77, 0x7e, 0x79, 0x6c, 0x6b, 0x62, 0x65, 0x48, 0x4f, 0x46, 0x41, 0x54, 0x53, 0x5a, 0x5d, 0xe0, 0xe7, 0xee, 0xe9, 0xfc, 0xfb, 0xf2, 0xf5, 0xd8, 0xdf, 0xd6, 0xd1, 0xc4, 0xc3, 0xca, 0xcd, 0x90, 0x97, 0x9e, 0x99, 0x8c, 0x8b, 0x82, 0x85, 0xa8, 0xaf, 0xa6, 0xa1, 0xb4, 0xb3, 0xba, 0xbd, 0xc7, 0xc0, 0xc9, 0xce, 0xdb, 0xdc, 0xd5, 0xd2, 0xff, 0xf8, 0xf1, 0xf6, 0xe3, 0xe4, 0xed, 0xea, 0xb7, 0xb0, 0xb9, 0xbe, 0xab, 0xac, 0xa5, 0xa2, 0x8f, 0x88, 0x81, 0x86, 0x93, 0x94, 0x9d, 0x9a, 0x27, 0x20, 0x29, 0x2e, 0x3b, 0x3c, 0x35, 0x32, 0x1f, 0x18, 0x11, 0x16, 0x03, 0x04, 0x0d, 0x0a, 0x57, 0x50, 0x59, 0x5e, 0x4b, 0x4c, 0x45, 0x42, 0x6f, 0x68, 0x61, 0x66, 0x73, 0x74, 0x7d, 0x7a, 0x89, 0x8e, 0x87, 0x80, 0x95, 0x92, 0x9b, 0x9c, 0xb1, 0xb6, 0xbf, 0xb8, 0xad, 0xaa, 0xa3, 0xa4, 0xf9, 0xfe, 0xf7, 0xf0, 0xe5, 0xe2, 0xeb, 0xec, 0xc1, 0xc6, 0xcf, 0xc8, 0xdd, 0xda, 0xd3, 0xd4, 0x69, 0x6e, 0x67, 0x60, 0x75, 0x72, 0x7b, 0x7c, 0x51, 0x56, 0x5f, 0x58, 0x4d, 0x4a, 0x43, 0x44, 0x19, 0x1e, 0x17, 0x10, 0x05, 0x02, 0x0b, 0x0c, 0x21, 0x26, 0x2f, 0x28, 0x3d, 0x3a, 0x33, 0x34, 0x4e, 0x49, 0x40, 0x47, 0x52, 0x55, 0x5c, 0x5b, 0x76, 0x71, 0x78, 0x7f, 0x6a, 0x6d, 0x64, 0x63, 0x3e, 0x39, 0x30, 0x37, 0x22, 0x25, 0x2c, 0x2b, 0x06, 0x01, 0x08, 0x0f, 0x1a, 0x1d, 0x14, 0x13, 0xae, 0xa9, 0xa0, 0xa7, 0xb2, 0xb5, 0xbc, 0xbb, 0x96, 0x91, 0x98, 0x9f, 0x8a, 0x8d, 0x84, 0x83, 0xde, 0xd9, 0xd0, 0xd7, 0xc2, 0xc5, 0xcc, 0xcb, 0xe6, 0xe1, 0xe8, 0xef, 0xfa, 0xfd, 0xf4, 0xf3 }; uint8_t CRC8_Calc (uint8_t *p, uint8_t len) { uint16_t i; uint16_t crc = 0x0; while (len--) { i = (crc ^ *p++) & 0xFF; crc = (crc_table ^ (crc << 8)) & 0xFF; } return crc & 0xFF; } void MLX90614_WriteReg(uint8_t devAddr, uint8_t regAddr, uint16_t data) { uint8_t i2cdata[4], temp[4]; temp[0] = (devAddr << 1); temp[1] = regAddr; temp[2] = 0x00; temp[3] = 0x00; // For a write word command, in the crc8 calculus, you have to include [SA_W, Command, LSB, MSB] i2cdata[0] = temp[1]; //EEPROM-address i2cdata[1] = temp[2]; //Delete-Byte, low i2cdata[2] = temp[3]; //Delete-Byte, high i2cdata[3] = CRC8_Calc(temp, 4); //CRC8-checksum calculation: http://www.sunshine2k.de/coding/javascript/crc/crc_js.html HAL_I2C_Master_Transmit(&hi2c1, (devAddr << 1), i2cdata, 4, 0xFFFF); HAL_Delay(10); MLX90614_SendDebugMsg(MLX90614_DBG_MSG_W, devAddr, i2cdata[0], (i2cdata[1] <<8 | i2cdata[2]), i2cdata[3], 0x00); temp[2] = data & 0xFF; //Getting LSB first temp[3] = data >> 8; //Getting MSB after i2cdata[0] = temp[1]; //EEPROM-address i2cdata[1] = temp[2]; //Delete-Byte, low i2cdata[2] = temp[3]; //Delete-Byte, high i2cdata[3] = CRC8_Calc(temp, 4); //CRC8-checksum calculation: http://www.sunshine2k.de/coding/javascript/crc/crc_js.html HAL_I2C_Master_Transmit(&hi2c1, (devAddr << 1), i2cdata, 4, 0xFFFF); HAL_Delay(10); MLX90614_SendDebugMsg(MLX90614_DBG_MSG_W, devAddr, i2cdata[0], data, i2cdata[3], 0x00); } uint16_t MLX90614_ReadReg(uint8_t devAddr, uint8_t regAddr, uint8_t dbg_lvl) { uint16_t data; uint8_t in_buff[3], crc_buff[5], crc; HAL_I2C_Mem_Read(&hi2c1, (devAddr<<1), regAddr, 1, in_buff, 3, 100); // For a read word command, in the crc8 calculus, you have to include [SA_W, Command, SA_R, LSB, MSB] crc_buff[0] = (devAddr<<1); crc_buff[1] = regAddr; crc_buff[2] = (devAddr<<1) + 1; crc_buff[3] = in_buff[0]; crc_buff[4] = in_buff[1]; crc = CRC8_Calc(crc_buff, 5); data = (in_buff[1] <<8 | in_buff[0]); //TODO: implement CRC8 check on data received if (crc != in_buff[2]) { data = 0x0000; } if(dbg_lvl == MLX90614_DBG_ON) MLX90614_SendDebugMsg(MLX90614_DBG_MSG_R, devAddr, regAddr, data, in_buff[2], crc); //HAL_Delay(1); return data; } float MLX90614_ReadTemp(uint8_t devAddr, uint8_t regAddr) { float temp; uint16_t data; data = MLX90614_ReadReg(devAddr, regAddr, MLX90614_DBG_OFF); temp = data*0.02 - 273.15; return temp; } void MLX90614_ScanDevices (void) { HAL_StatusTypeDef result; for ( i = 0; i<128; i++) { result = HAL_I2C_IsDeviceReady(&hi2c1, (uint16_t) (i<<1), 2, 2); if (result != HAL_OK) { sprintf(temp_buff, "."); // CDC_Transmit_FS(temp_buff, strlen((const char *)temp_buff)); } if (result == HAL_OK) { sprintf(temp_buff, "0x%X", i); // CDC_Transmit_FS(temp_buff, strlen((const char *)temp_buff)); } } } void MLX90614_SendDebugMsg(uint8_t op_type, uint8_t devAddr, uint8_t regAddr, uint16_t data, uint8_t crc_in, uint8_t crc_calc) { if(op_type == MLX90614_DBG_MSG_W) { snprintf(temp_buff, sizeof(temp_buff), "W Dev: 0x%02X, Reg: 0x%02X, Data: 0x%04X, CRC8_calc:0x%02Xrn", devAddr, regAddr, data, crc_calc); // CDC_Transmit_FS(temp_buff, strlen((const char *)temp_buff)); } else if (op_type == MLX90614_DBG_MSG_R) { snprintf(temp_buff, sizeof(temp_buff), "R Dev: 0x%02X, Reg: 0x%02X, Data: 0x%04X, CRC8_in:0x%02X, CRC8_calc:0x%02Xrn", devAddr, regAddr, data, crc_in, crc_calc); // CDC_Transmit_FS(temp_buff, strlen((const char *)temp_buff)); } } 串口输出重定向 int fputc(int ch, FILE *f) { while((USART6->SR&0X40)==0);//Ñ»··¢ËÍ,Ö±µ½·¢ËÍÍê±Ï USART6->DR = (u8) ch; return ch; } 主程序调用 #include "sys.h" #include "delay.h" #include "usart.h" #include "mlx90614.h" int main(void) { u8 len; u16 times=0; float temp =0; HAL_Init(); //³õʼ»¯HAL¿â // Stm32_Clock_Init(360,25,2,8); //ÉèÖÃʱÖÓ,180Mhz Stm32_Clock_Init(384,25,2,8); delay_init(180); //³õʼ»¯ÑÓʱº¯Êý uart_init(115200); //³õʼ»¯USART MLX90614init(); while(1) { temp= MLX90614_ReadTemp(0x00,0x07); printf("TEM:%fn",temp); delay_ms(500); } } 测试结果 |
2601 浏览 1 评论
1982 浏览 1 评论
1523 浏览 2 评论
999 浏览 2 评论
3223 浏览 2 评论
1381浏览 4评论
594浏览 3评论
862浏览 3评论
814浏览 3评论
863浏览 3评论
GMT+8, 2025-7-16 07:31 , Processed in 0.620362 second(s), Total 45, Slave 39 queries .
