在嵌入式STM32平台经常用到串口打印调试信息,HAL库提供的函数并不适合调试中使用将HAL库中的串口程序通过宏定义映射到printf的上即可。
代码如下: #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the EVAL_COM1 and Loop until the end of transmission */ HAL_UART_Transmit(&Debughuart, (uint8_t *)&ch, 1, 0xFFFF); return ch; } 在头文件中宏定义你的串口号: #define Debughuart huart4 也可以直接使用串口号,我这里使用的串口是huart4 !! #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the EVAL_COM1 and Loop until the end of transmission */ HAL_UART_Transmit(&huart4 , (uint8_t *)&ch, 1, 0xFFFF); return ch; } 将一段代码添加到任意一个c文件中视频。 |
1907 浏览 1 评论
1678 浏览 1 评论
1171 浏览 2 评论
770 浏览 2 评论
1730 浏览 2 评论
1970浏览 9评论
806浏览 4评论
254浏览 3评论
623浏览 3评论
634浏览 3评论
GMT+8, 2025-1-23 07:17 , Processed in 0.853483 second(s), Total 43, Slave 38 queries .
