openMV实现舵机定位色块STM32
实验目的:本实验实现使用openMV检测前方色块,并传回色块的坐标位置给STM32,控制舵机转动来跟踪色块。 openMV部分 import sensor, image, time from pyb import UART import json red_threshold = (87, 21, 27, 93, -5, 92) sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affeOpenMV_Xct. sensor.set_auto_whitebal(False) # turn this off. clock = time.clock() # Tracks FPS. uart = UART(3, 115200) uart.init(115200, bits=8, parity=None, stop=1) #8位数据位,无校验位,1位停止位 def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob def sending_data(cx_max,cy_max): global uart; data = ustruct.pack(" 0xfe, int(cx_max), int(cy_max)); #数据1 # up sample by 4#数据2LCD_ShowStringLCD_ShowString uart.write(data); #必须要传入一个字节数组 while(True): clock.tick() # Track elapsed milliseconds between snapshots(). img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([red_threshold]) if blobs: max_blob = find_max(blobs) img.draw_cross(max_blob.cx(),max_blob.cy()) img.draw_circle(max_blob.cx(),max_blob.cy(),max_blob.cx()-max_blob.x(), color = (255, 255, 255)) X =int(max_blob.cx()-img.width()/2) Y =int(max_blob.cy()-img.height()/2) # FH = bytearray([0xb3,0xb3]) # uart.write(FH) #打印帧头 data = bytearray([0xb3,0xb3,X,Y,0x5b]) uart.write(data) #打印XY轴的偏移坐标 print("X轴偏移坐标 : ",X) print("Y轴偏移坐标 : ",Y) print("帧率 : ",clock.fps()) sending_data(blob.X,blob.Y) 代码介绍:此部分为openMV追踪色块(黄色)并且传回色块的横坐标位置给STM32C8T6t,同时也可以用串口打印出来色块距离中心坐标位置偏移值。 如图所示 如果要利用串口显示的话可以用一根杜杜邦线接openMV的P4和USB转TTL的RXD接收端即可。 STM32部分 串口接收终端代码 void USART1_IRQHandler(void) //串口1中断服务程序 { u8 com_data; #if SYSTEM_SUPPORT_OS //如果SYSTEM_SUPPORT_OS为真,则需要支持OS. OSIntEnter(); #endif if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断(接收到的数据必须是0x0d 0x0a结尾) { USART_ClearFlag(USART1,USART_FLAG_RXNE); com_data = USART1->DR; Openmv_Receive_Data(com_data); //openmv数据处理函数 Openmv_Data(); //openmv数据处理函数 } #if SYSTEM_SUPPORT_OS //如果SYSTEM_SUPPORT_OS为真,则需要支持OS. OSIntExit(); #endif } 处理openMV数据代码 #include "openmv.h" int openmv[5];//stm32接收数据数组 int8_t OpenMV_X; /*OPENMV X 轴反馈坐标*/ int8_t OpenMV_Y; /*OPENMV X 轴反馈坐标*/ int i=0; void Openmv_Receive_Data(int16_t data)//接收Openmv传过来的数据 { static u8 state = 0; if(state==0&&data==0xb3) { state=1; openmv[0]=data; } else if(state==1&&data==0xb3) { state=2; openmv[1]=data; } else if(state==2) { state=3; openmv[2]=data; } else if(state==3) { state = 4; openmv[3]=data; } else if(state==4) //检测是否接受到结束标志 { if(data == 0x5B) { state = 0; openmv[4]=data; Openmv_Data(); } else if(data != 0x5B) { state = 0; for(i=0;i<5;i++) { openmv=0x00; } } } else { state = 0; for(i=0;i<5;i++) { openmv=0x00; } } } void Openmv_Data(void) { OpenMV_X=openmv[2]; OpenMV_Y=openmv[3]; } 其他部分的代码就很简单,在这里只列出关键部分代码 下面就是关键的控制舵机转动的代码 while (1) { OpenMV_X= openmv[2]; printf ("rn%drn",OpenMV_X); if(OpenMV_X>=0&&OpenMV_X<80) { s=185-OpenMV_X/16; TIM_SetCompare1(TIM1, s); } if(OpenMV_X>=180) { s=190-(OpenMV_X-180)/16; TIM_SetCompare1(TIM1, s); } } 舵机的初始化代码在这里我就不列了,我用的是TIM1。 它是根据STM32接收到的数据的坐标位置来进行一个条件判断,这里32端接受到的数据为横坐标值,当色块在右侧,数据为0—80,当色块在左侧时,数据为260—180.由此来计算舵机的占空比具体是多大。 |
2180 浏览 1 评论
1839 浏览 1 评论
1330 浏览 2 评论
872 浏览 2 评论
2207 浏览 2 评论
2112浏览 9评论
1025浏览 4评论
399浏览 3评论
725浏览 3评论
714浏览 3评论
GMT+8, 2025-4-11 17:51 , Processed in 1.256622 second(s), Total 77, Slave 61 queries .
