一、MDK设置
在工程的 Target中MicroLib 二、main函数之前添加如下编译代码: #define COM USART1 //串口选择初始化,USART1为串口1,USART2为串口2 #ifdef __GNUC__ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif PUTCHAR_PROTOTYPE { USART_SendData(COM, (uint8_t) ch); //此处用到了 COM宏定义为了 USART1 //注意:这里可以定义printf()使用板载的任意USART(COM1或者COM2均可) while (USART_GetFlagStatus(COM, USART_FLAG_TC) == RESET) {} return ch; } 三、程序配置 时钟使能 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); //串口2时钟初始化 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //串口1时钟初始化 IO脚配置 void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; //USART1管脚初始化 //USART1发送TX=PA9管脚初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //USART1接收RX=PA10管脚初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); //USART2管脚初始化 //USART2发送TX=PA2管脚初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //USART2接收RX=PA3管脚初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); } 串口参数设置 void USART_Configuration(void) { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 115200; // 设置了USART传输的波特率 ; USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 8位数据 ; USART_InitStructure.USART_StopBits = USART_StopBits_1; // 在帧结尾传输1个停止位 ; USART_InitStructure.USART_Parity = USART_Parity_No ; // 奇偶失能 ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;// RTS和CTS失能 ; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // 接收发送使能 ; USART_Init(COM, &USART_InitStructure); // 根据USART_InitStruct中指定的参数初始化外设USART寄存器 ; USART_Cmd(COM, ENABLE); // 使能USART外设,此处COM为USART1,在宏定义中,可以设置 while(NbrOfDataToTransfer--) //测试用,初始化发送数据,NbrOfDataToTransfer为输出字符串的长度 { USART_SendData(USART2, TxBuffer[TxCounter++]); // 通过外设USART发送单个数据 ; while(USART_GetFlagStatus(COM, USART_FLAG_TXE) == RESET); // 检查发送数据寄存器空标志位; } } 3、在main中添加 printf("nrSTM32 USART2:%d n",10); 即可实现C库printf函数的正常使用 |
1927 浏览 1 评论
1698 浏览 1 评论
1180 浏览 2 评论
779 浏览 2 评论
1745 浏览 2 评论
1986浏览 9评论
822浏览 4评论
269浏览 3评论
634浏览 3评论
638浏览 3评论
GMT+8, 2025-2-1 05:03 , Processed in 0.661000 second(s), Total 43, Slave 38 queries .
