扫一扫,分享给好友
Arduino IDE配置STM32开发环境和烧录
前言:最近在制作三维打印机,自己画了一块STM32F446的三维打印机板子(RUMBA32),但是在Arduino的编译马林固件的时候,一直报错,定时器显示中断有问题 怀疑可能的英文由于Arduino的IDE编译环境的问题,因此花了一点时间配置Arduino IDE,并成功实现了使用串口/DFU进行程序烧录,实现了最简单的LED显示屏和串口显示。1. 下载Arduino IDE并安装 方式1:官网下载,下载后安装2.在Arduino中安装STM32开发板
3.安装STM32CubeProgrammer
4.添加STM32CubeProgrammer中的bin文件夹的路径到系统路径中
至此,你的Arduino已经可以使用USB烧录程序到STM32中了。5.配合好BOOT0,使用串口/DFU(USB)进行烧录 烧录之前,需要将BOOT0置为1,按复位复位,之后才可以烧录程序再配一张制作一张自己的RUMBA322开发图: 之后制作成功3D打印机后,将和大家分享一下3D打印机的资料,分享一下 对了,马林2.0过程并在编译的时候,遇到了一些提示: sketchsrcHALSTM32timers.cpp: In function 'void HAL_timer_enable_interrupt(uint8_t)': sketchsrcHALSTM32timers.cpp:178:62: error: no matching function for call to 'HardwareTimer::attachInterrupt(void (&)(HardwareTimer*))' 178 | timer_instance[timer_num]->attachInterrupt(Step_Handler); | ^ In file included from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/stm32/analog.h:45, from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/board.h:8, from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/wiring.h:41, from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/Arduino.h:36, from c:usersasusappdatalocaltemparduino_build_611183sketchsrchalsharedmarduino.h:36, from c:usersasusappdatalocaltemparduino_build_611183sketchsrchalstm32hal.h:28, from c:usersasusappdatalocaltemparduino_build_611183sketchsrchalhal.h:26, from c:usersasusappdatalocaltemparduino_build_611183sketchsrcincmarlinconfig.h:30, from sketchsrcHALSTM32timers.cpp:24: C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:134:10: note: candidate: 'void HardwareTimer::attachInterrupt(callback_function_t)' 134 | void attachInterrupt(callback_function_t callback); // Attach interrupt callback which will be called upon update event (timer rollover) | ^~~~~~~~~~~~~~~ C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:134:46: note: no known conversion for argument 1 from 'void(HardwareTimer*)' to 'callback_function_t' {aka 'std::function 134 | void attachInterrupt(callback_function_t callback); // Attach interrupt callback which will be called upon update event (timer rollover) | ~~~~~~~~~~~~~~~~~~~~^~~~~~~~ C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:138:10: note: candidate: 'void HardwareTimer::attachInterrupt(uint32_t, callback_function_t)' 138 | void attachInterrupt(uint32_t channel, callback_function_t callback); // Attach interrupt callback which will be called upon compare match event of specified channel | ^~~~~~~~~~~~~~~ C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:138:10: note: candidate expects 2 arguments, 1 provided sketchsrcHALSTM32timers.cpp:181:62: error: no matching function for call to 'HardwareTimer::attachInterrupt(void (&)(HardwareTimer*))' 181 | timer_instance[timer_num]->attachInterrupt(Temp_Handler); | ^ In file included from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/stm32/analog.h:45, from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/board.h:8, from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/wiring.h:41, from C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/Arduino.h:36, from c:usersasusappdatalocaltemparduino_build_611183sketchsrchalsharedmarduino.h:36, from c:usersasusappdatalocaltemparduino_build_611183sketchsrchalstm32hal.h:28, from c:usersasusappdatalocaltemparduino_build_611183sketchsrchalhal.h:26, from c:usersasusappdatalocaltemparduino_build_611183sketchsrcincmarlinconfig.h:30, from sketchsrcHALSTM32timers.cpp:24: C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:134:10: note: candidate: 'void HardwareTimer::attachInterrupt(callback_function_t)' 134 | void attachInterrupt(callback_function_t callback); // Attach interrupt callback which will be called upon update event (timer rollover) | ^~~~~~~~~~~~~~~ C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:134:46: note: no known conversion for argument 1 from 'void(HardwareTimer*)' to 'callback_function_t' {aka 'std::function 134 | void attachInterrupt(callback_function_t callback); // Attach interrupt callback which will be called upon update event (timer rollover) | ~~~~~~~~~~~~~~~~~~~~^~~~~~~~ C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:138:10: note: candidate: 'void HardwareTimer::attachInterrupt(uint32_t, callback_function_t)' 138 | void attachInterrupt(uint32_t channel, callback_function_t callback); // Attach interrupt callback which will be called upon compare match event of specified channel | ^~~~~~~~~~~~~~~ C:UsersASUSAppDataLocalArduino15packagesSTM32hardwarestm321.9.0coresarduino/HardwareTimer.h:138:10: note: candidate expects 2 arguments, 1 provided exit status 1 为开发板 3D printer boards 编译时出错。 下载 https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json 时出错 下载 https://github.com/stm32duino/BoardManagerFiles/raw/master/STM32/package_stm_index.json 时出错 |
1909 浏览 1 评论
1678 浏览 1 评论
1172 浏览 2 评论
771 浏览 2 评论
1732 浏览 2 评论
1972浏览 9评论
807浏览 4评论
255浏览 3评论
624浏览 3评论
634浏览 3评论
GMT+8, 2025-1-24 09:30 , Processed in 0.430558 second(s), Total 42, Slave 37 queries .
