简单生成代码后找到MDK的驱动文件
官方建议步骤 #####数据EEPROM编程功能##### ======================== ================================================== ===== [..] 或石墨编程的任何操作都应遵循步骤: (#)调用@ref HAL_FLASHEx_DATAEEPROM_Unlock()可以启用数据EEPROM访问 和闪存程序控制权限访问。 (#)调用所需的功能来擦除或编程数据。 (#)调用@ref HAL_FLASHEx_DATAEEPROM_Lock()来禁用数据EEPROM访问 状语从句:闪存程序擦除控制寄存器访问(推荐 保护DATA_EEPROM免受可能的意外操作)。 实验总结,只需要三解锁步 写入数据(擦除也是写入数据只不过写的是0×00) 上锁(建议上锁,其实没啥用,不用问题不是很大) void Program_EEPROM(void) { uint32_t data = 0x12345678; HAL_FLASHEx_DATAEEPROM_Unlock(); HAL_FLASHEx_DATAEEPROM_Program( FLASH_TYPEPROGRAMDATA_WORD, 0x08080000, data); HAL_FLASHEx_DATAEEPROM_Program( FLASH_TYPEPROGRAMDATA_WORD, 0x08080000 + 4, data); HAL_FLASHEx_DATAEEPROM_Erase(FLASH_TYPEERASEDATA_WORD, 0x08080000); HAL_FLASHEx_DATAEEPROM_Lock(); } FLASH_TYPEPROGRAMDATA_WORD 是数据类型,可以是Program word (32-bit) at a specified address OR Program word (16-bit) at a specified address OR Program word (8-bit) at a specified address 0x08080000 是地址,在官方手册中,可以查到。 数据写入的英文的数据 实际运行效果 擦除也是写入 /** * @brief Erase a word in data memory. * @param Address specifies the address to be erased. * @param TypeErase Indicate the way to erase at a specified address. * This parameter can be a value of @ref FLASH_Type_Program * @note To correctly run this function, the @ref HAL_FLASHEx_DATAEEPROM_Unlock() function * must be called before. * Call the @ref HAL_FLASHEx_DATAEEPROM_Lock() to the data EEPROM access * and Flash program erase control register access(recommended to protect * the DATA_EEPROM against possible unwanted operation). * @retval HAL_StatusTypeDef HAL Status */ HAL_StatusTypeDef HAL_FLASHEx_DATAEEPROM_Erase(uint32_t TypeErase, uint32_t Address) { HAL_StatusTypeDef status = HAL_OK; /* Check the parameters */ assert_param(IS_TYPEPROGRAMDATA(TypeErase)); assert_param(IS_FLASH_DATA_ADDRESS(Address)); /* Wait for last operation to be completed */ status = FLASH_WaitForLastOperation(FLASH_TIMEOUT_VALUE); if(status == HAL_OK) { /* Clean the error context */ pFlash.ErrorCode = HAL_FLASH_ERROR_NONE; if(TypeErase == FLASH_TYPEERASEDATA_WORD) { /* Write 00000000h to valid address in the data memory */ *(__IO uint32_t *) Address = 0x00000000U; } if(TypeErase == FLASH_TYPEERASEDATA_HALFWORD) { /* Write 0000h to valid address in the data memory */ *(__IO uint16_t *) Address = (uint16_t)0x0000; } if(TypeErase == FLASH_TYPEERASEDATA_BYTE) { /* Write 00h to valid address in the data memory */ *(__IO uint8_t *) Address = (uint8_t)0x00; } status = FLASH_WaitForLastOperation(FLASH_TIMEOUT_VALUE); } /* Return the erase status */ return status; } 不懂的可以搜索指针强制类型转换学习一下。 数据读取 读取数据参照上面擦写部分,只需要反过来就好了。 data_8bit = *(__ IO uint8_t *)地址; data_16bit = *(__ IO uint16_t *)地址; data_32bit = *(__ IO uint32_t的*)的地址; 我有几个问题很疑惑是否 会影响这部分区域吗? 答:这部分程序是进行特意的,这个部分可能不会有其他方式的数据,比如,烧录, flash也可以用一样的函数吗? 个人觉得不行,flash是按页分的,EEPROM可以按字节编辑,所以肯定有区别。(未进行实验,也没什么意义) |
1975 浏览 1 评论
1760 浏览 1 评论
1232 浏览 2 评论
819 浏览 2 评论
1776 浏览 2 评论
2015浏览 9评论
889浏览 4评论
318浏览 3评论
670浏览 3评论
661浏览 3评论
GMT+8, 2025-2-23 15:04 , Processed in 0.753846 second(s), Total 75, Slave 59 queries .
