我是用遍历两个数组让数码管流动显示数字
main.c #include "sys.h" #include "delay.h" #include "num.h" int main(void) { RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //系统时钟设置PLL作为系统时钟 delay_init(); //初始化延时函数 NUM_FLOW(); //数码管流动显示 } num.c #include "num.h" #include "delay.h" //动态数码管段码 //unsigned char seg[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //流动数码管 u8 smgduan[4]={0xF9,0xB0,0xF9,0x99};//段选 u8 smgwei[4]={0xfE,0xfd,0xfb,0xf7}; //位选 //数码管初始化 void NUM_Init(void){ GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //使能GPIO端口时钟,数码管显示GPIO使能配置 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //位选使能 //段码设置 GPIO_InitStructure.GPIO_Pin = NUM_STATIC_GPIO; //数码管段选显示GPIO引脚配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz; //最高输出速率50MHz GPIO_Init(GPIOD, &GPIO_InitStructure); //IO口初始化 //位选设置 GPIO_InitStructure.GPIO_Pin = NUM_STATIC_BIT; //数码管位选显示GPIO引脚配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz; //最高输出速率50MHz GPIO_Init(GPIOC, &GPIO_InitStructure); //IO口初始化 GPIO_ResetBits(GPIOC, NUM_STATIC_BIT); //给数码管位码置0 } //数码管流动显示 void NUM_FLOW(void){ uint16_t i; NUM_Init(); while(1) { for(i=0;i<4;i++) { GPIO_Write(GPIOD,0xff); GPIO_Write(GPIOC,0xff); GPIO_Write(GPIOC,smgwei); //位选输出 GPIO_Write(GPIOD,smgduan); //段码输出 delay_ms(10); } } } num.h #include "sys.h" //段码引脚 #define NUM_STATIC_GPIO GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7 #define NUM_STATIC_BIT GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3 //数码管流动显示 void NUM_FLOW(void); |
1980 浏览 1 评论
1764 浏览 1 评论
1233 浏览 2 评论
819 浏览 2 评论
1777 浏览 2 评论
2017浏览 9评论
897浏览 4评论
320浏览 3评论
673浏览 3评论
662浏览 3评论
GMT+8, 2025-2-25 00:05 , Processed in 0.680243 second(s), Total 44, Slave 39 queries .
