刚开始是用51写的,lcd1602显示,写的也算可以,数据显示的也很稳定,后来想做的项目51实现不了,就想着用32去实现,可这就出现了一些问题,我用的是正点原子的mini板子,hx711压力传感
第一个问题就是,程序下进去后,再复位或者断开电源,lcd就不显示内容了,后里发现是主函数的uart_init 函数,不能去掉,因为在 LCD_Init 函数里面调用了 printf,所以一旦你去掉这个初始化,就会死机了,就不再会显示 第二就是显示数字不稳定,因为这是24位的,很灵敏,如果给的电压不稳定,就会导致显示突变,刚开始我的未放置东西,数字都会显示9988294,这个数字也不是什么无效数字,就是不准,但是放置物品显示却正确,我也调了好长时间的时序,发现并没什么用,后来才发现是电压的影响,而且连接线松了也会造成影响 关于hx711很多卖家都会提供资料,不过基本上都是51的,用32写的话,只需要模拟io口就行了 #include "sys.h" #include "delay.h" #include "hx711.h" unsigned long Weight_Shiwu = 0; unsigned long Weight_Maopi = 0; void hx711_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //DT <-----> PC0 //SCK <-----> PC13 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); } unsigned long Hx711_Read() { unsigned long val = 0; //DT <-----> PC0 unsigned int i = 0; //SCK <-----> PC13 GPIO_SetBits(GPIOC, GPIO_Pin_0); delay_us(1);// GPIO_ResetBits(GPIOC, GPIO_Pin_13); while(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_0)); for(i=0; i<24; i++) { GPIO_SetBits(GPIOC,GPIO_Pin_13); delay_us(1); val=val<<1; GPIO_ResetBits(GPIOC,GPIO_Pin_13); if(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_0)) val++; delay_us(1); } GPIO_SetBits(GPIOC,GPIO_Pin_13); val = val^0x800000; delay_us(1); GPIO_ResetBits(GPIOC,GPIO_Pin_13); delay_us(1); return val; } void Get_Maopi() { Weight_Maopi = Hx711_Read(); } void Get_Weight() { Weight_Shiwu = Hx711_Read(); Weight_Shiwu = Weight_Shiwu - Weight_Maopi; if(Weight_Shiwu > 0) { Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/430); } else { Weight_Shiwu = 0; } } #include "stm32f10x.h" #include "hx711.h" #include "lcd.h" #include "delay.h" #include "usart.h" int main(void) { delay_init(); //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); uart_init(9600); LCD_Init(); hx711_Init(); Get_Maopi(); LCD_ShowString(160,150,240,320,12, "g"); while(1) { Get_Weight(); LCD_ShowxNum(100,150,Weight_Shiwu,10,12,0); } } |
2523 浏览 1 评论
1959 浏览 1 评论
1491 浏览 2 评论
982 浏览 2 评论
3131 浏览 2 评论
1298浏览 4评论
556浏览 3评论
842浏览 3评论
799浏览 3评论
823浏览 3评论
GMT+8, 2025-7-1 06:45 , Processed in 0.726029 second(s), Total 47, Slave 41 queries .
