我的是四位的数码管,共阳极 一个数码管有八段:A,B,C,D,E,F ,G,H,DP,即由八个发光二极管组成 由0到f编码为: 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e main.c #include "sys.h" #include "delay.h" #include "num.h" int main(void) { RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //系统时钟设置PLL作为系统时钟 delay_init(); //初始化延时函数 NUM_STATIC(); //数码管静态显示 } num.c #include "num.h" //数码管初始化 void NUM_Init(void){ GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //使能GPIO端口时钟,数码管显示GPIO使能配置 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //位选使能 //段码设置 GPIO_InitStructure.GPIO_Pin = NUM_STATIC_GPIO; //数码管段选显示GPIO引脚配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz; //最高输出速率50MHz GPIO_Init(GPIOD, &GPIO_InitStructure); //IO口初始化 //位选设置 GPIO_InitStructure.GPIO_Pin = NUM_STATIC_BIT; //数码管位选显示GPIO引脚配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz; //最高输出速率50MHz GPIO_Init(GPIOC, &GPIO_InitStructure); //IO口初始化 GPIO_ResetBits(GPIOC, NUM_STATIC_BIT); //给数码管位码置0 } //数码管静态函数 void NUM_STATIC(void){ NUM_Init(); while(1) { GPIO_Write(GPIOD,0xc0); //段码输出0 } } num.h #include "sys.h" //段码引脚 #define NUM_STATIC_GPIO GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7 #define NUM_STATIC_BIT GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3 //数码管静态显示 void NUM_STATIC(void); |
2187 浏览 1 评论
1839 浏览 1 评论
1336 浏览 2 评论
874 浏览 2 评论
2207 浏览 2 评论
2116浏览 9评论
1031浏览 4评论
404浏览 3评论
727浏览 3评论
716浏览 3评论
GMT+8, 2025-4-14 06:39 , Processed in 0.968148 second(s), Total 76, Slave 60 queries .
