#include “stm32f10x.h”
/* RCC时钟配置 */ void RCC_config() { ErrorStatus HSEStartUpStatus; /* RCC寄存器设置为默认配置 */ RCC_DeInit(); /* 打开外部高速时钟 */ RCC_HSEConfig(RCC_HSE_ON); /* 等待外部高速时钟稳定 */ HSEStartUpStatus = RCC_WaitForHSEStartUp(); if(HSEStartUpStatus == SUCCESS) { /* 设置HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* 设置PCLK2 = HCLK */ RCC_PCLK2Config(RCC_HCLK_Div1); /* 设置PCLK1 = HCLK / 2 */ RCC_PCLK1Config(RCC_HCLK_Div2); // /* 设置FLASH代码延时 */ // FLASH_SetLatency(FLASH_Latency_2); // /* 使能预取址缓存 */ // FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); /* 设置PLL时钟源为HSE倍频9 72MHz */ RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); /* 使能PLL */ RCC_PLLCmd(ENABLE); /* 等待PLL稳定 */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); /* 设置PLL为系统时钟源 */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* 等待系统时钟源切换到PLL */ while(RCC_GetSYSCLKSource() != 0x08); } } /* GPIO配置 */ void GPIO_config() { GPIO_InitTypeDef GPIO_InitStructure; /* 使能GPIOA时钟 */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE); /* 将GPIOA时钟设置为默认参数 */ GPIO_DeInit(GPIOA); /* 复用推挽输出 */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; /* 第13引脚 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; /* 输出频率50MHz */ GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; /* 初始化GPIOA_0 */ GPIO_Init(GPIOA, &GPIO_InitStructure); } /* 定时器配置 */ void TIMER_config() { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* 允许TIM2的时钟 */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); /* 将定时器2寄存器设为初始值 */ TIM_DeInit(TIM2); /* 设置定时器2由内部时钟 */ TIM_InternalClockConfig(TIM2); /* 预分频值 */ TIM_TimeBaseStructure.TIM_Prescaler = 72 - 1; /* 时钟分割 */ TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; /* 向上计数 */ TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; /* 自动重载值 */ TIM_TimeBaseStructure.TIM_Period = 1000 - 1; /* 初始化定时器2 */ TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 500; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM2, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable); /* 清除中断标志 */ TIM_ClearFlag(TIM2, TIM_IT_CC1); /* 开启TIM2的中断 */ TIM_ITConfig(TIM2, TIM_IT_CC1, ENABLE); /* 开启定时器2 */ TIM_Cmd(TIM2, ENABLE); } /* 中断配置 */ void NVIC_config() { NVIC_InitTypeDef NVIC_InitStructure; /* 选择中断分组1 */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); /* 选择TIM2的中断通道 */ NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; /* 抢占式中断优先级设置为0 */ NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; /* 响应式中断优先级设置为0 */ NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; /* 使能中断 */ NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; /* 中断初始化 */ NVIC_Init(&NVIC_InitStructure); } /* 毫秒延时 */ void delay_ms(uint16_t time) { uint16_t i = 0; while(time--) { i = 12000; while(i--); } } /* 定时器2中断向量 */ void TIM2_IRQHandler(void) { uint16_t capture = 0; if(TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET) { TIM_ClearITPendingBit(TIM2, TIM_IT_CC1); /* 清除中断标志 */ TIM_ClearFlag(TIM2, TIM_IT_CC1); capture = TIM_GetCapture1(TIM2); TIM_SetCompare1(TIM2, 500 - capture); } } int main() { /* 时钟配置 */ RCC_config(); /* GPIO配置 */ GPIO_config(); /* 中断配置*/ NVIC_config(); /* 定时器2配置 */ TIMER_config(); while(1) { delay_ms(1000); } } |
1792 浏览 1 评论
1626 浏览 1 评论
1094 浏览 2 评论
732 浏览 2 评论
1682 浏览 2 评论
1943浏览 9评论
740浏览 4评论
577浏览 3评论
600浏览 3评论
562浏览 3评论
GMT+8, 2024-12-26 01:46 , Processed in 0.621374 second(s), Total 45, Slave 40 queries .
