扫一扫,分享给好友
看过上一篇文章会知道,我们已经可以生成模型代码和主程序,但还没有进行编译,今天我们对Toolbox进行改造,在点击Build之后除了生成C文件,还将自动的编译生成bin文件。
在此之前,我已经为我的STM32硬件准备好一个完整的工程,把里面的主程序删除掉,剩下的是: Startup,STM32的启动文件 Libraries,里面包含外设驱动头文件和STM32F10xR_V3.0.lib Project,这里只放了一个sct文件 首先我们修改mytarget.tlc这个系统tlc文件,增加设置代码生成路径、二进制文件输出路径和驱动代码路径的功能。 /% BEGIN_RTW_OPTIONS rtwoptions(1).prompt = 'MyTarget'; rtwoptions(1).type = 'Category'; rtwoptions(1).enable = 'on'; rtwoptions(1).default = 4; rtwoptions(1).popupstrings = ''; rtwoptions(1).tlcvariable = ''; rtwoptions(1).tooltip = ''; rtwoptions(1).callback = ''; rtwoptions(1).makevariable = ''; rtwoptions(2).prompt = 'Code Generated Path:'; rtwoptions(2).type = 'Edit'; rtwoptions(2).enable = 'on'; rtwoptions(2).default = ''; rtwoptions(2).tlcvariable = 'tlc_code_output'; rtwoptions(2).makevariable = 'CODE_FILE_PATH'; rtwoptions(2).tooltip = 'The path where generated source code files will be put into'; rtwoptions(2).callback = ''; rtwoptions(3).prompt = 'Browser...'; rtwoptions(3).type = 'Pushbutton'; rtwoptions(3).enable = 'on'; rtwoptions(3).default = ''; rtwoptions(3).tooltip = 'Locate the path where the generated files will be put into'; rtwoptions(3).callback = 'pathbrowsercallback(hDlg,hSrc,''tlc_code_output'')'; rtwoptions(4).prompt = 'Binary Output Path:'; rtwoptions(4).type = 'Edit'; rtwoptions(4).enable = 'on'; rtwoptions(4).default = ''; rtwoptions(4).tlcvariable = 'tlc_bin_output'; rtwoptions(4).makevariable = 'BIN_FILE_PATH'; rtwoptions(4).tooltip = 'The path where binary files will be put into'; rtwoptions(4).callback = ''; rtwoptions(5).prompt = 'Browser...'; rtwoptions(5).type = 'Pushbutton'; rtwoptions(5).enable = 'on'; rtwoptions(5).default = ''; rtwoptions(5).tooltip = 'Locate the path where the binary files will be put into'; rtwoptions(5).callback = 'pathbrowsercallback(hDlg,hSrc,''tlc_bin_output'')'; rtwoptions(6).prompt = 'Driver Path:'; rtwoptions(6).type = 'Edit'; rtwoptions(6).enable = 'on'; rtwoptions(6).default = ''; rtwoptions(6).tlcvariable = 'tlc_driver_path'; rtwoptions(6).makevariable = 'DRIVER_PATH'; rtwoptions(6).tooltip = 'The path where driver project is'; rtwoptions(6).callback = ''; rtwoptions(7).prompt = 'Browser...'; rtwoptions(7).type = 'Pushbutton'; rtwoptions(7).enable = 'on'; rtwoptions(7).default = ''; rtwoptions(7).tooltip = 'Locate the path where the driver is'; rtwoptions(7).callback = 'pathbrowsercallback(hDlg,hSrc,''tlc_driver_path'')'; 经过以上修改后可以看到模型配置选项发生了变化。 文件里的几个makevariable和makefile里的变量名是一样的,为了让代码和二进制文件能够生成到指定路径,并告知编译器使用我们模型生成的代码进行编译,tmf文件做了小幅修改,关键部分放在下面。 MAKE = C:TDM-GCC-64binmake KEIL_PATH = C:KeilARM ARMCC = $(KEIL_PATH)BIN40armcc ARMASM = $(KEIL_PATH)BIN40armasm ARMAR = $(KEIL_PATH)BIN40armar ARMLINK = $(KEIL_PATH)BIN40armlink FROMELF = $(KEIL_PATH)BIN40fromelf MAKECMD = C:TDM-GCC-64binmake SHELL = cmd HOST = PC BUILD = yes SYS_TARGET_FILE = mytarget.tlc COMPILER_TOOL_CHAIN = armcc CODE_FILE_PATH = |>CODE_FILE_PATH<| BIN_FILE_PATH = |>BIN_FILE_PATH<| DRIVER_PATH = |>DRIVER_PATH<| CFLAGS := -c --cpu Cortex-M3 -D__MICROLIB -g -O0 --apcs=interwork CMACRO := -DSTM32F10X_HD -DUSE_STDPERIPH_DRIVER ASMFLAGS := --cpu Cortex-M3 -g --apcs=interwork --pd "__MICROLIB SETA 1" LINKFLAGS := --cpu Cortex-M3 --library_type=microlib --strict MAP := --autoat --summary_stderr --info summarysizes --map --xref --callgraph --symbols INFO := --info sizes --info totals --info unused --info veneers TARGET = $(BIN_FILE_PATH)$(MODEL) OBJMAP := $(BIN_FILE_PATH)*.map OBJHTM := $(BIN_FILE_PATH)*.htm OBJAXF := $(BIN_FILE_PATH)*.axf MODEL_SRC=$(wildcard $(CODE_FILE_PATH)/*.c) MODEL_DIR=$(notdir $(MODEL_SRC)) OBJS=$(patsubst %.c,%.o,$(MODEL_DIR) ) OBJS +=$(DRIVER_PATH)Startupstartup_stm32f10x_hd.o $(DRIVER_PATH)LibrariesCMSIScore_cm3.o $(DRIVER_PATH)LibrariesCMSISsystem_stm32f10x.o $(DRIVER_PATH)LibrariesCMSISstm32f10x_it.o INC := -I$(CODE_FILE_PATH) INC += -I$(KEIL_PATH)RV31INC INC += -I$(KEIL_PATH)CMSISInclude INC += -I$(KEIL_PATH)INCSTSTM32F10x INC += -I$(DRIVER_PATH)LibrariesCMSIS INC += -I$(DRIVER_PATH)LibrariesSTM32F10x_StdPeriph_Driverinc %.o:%.c $(ARMCC) $(CFLAGS) $(INC) $(CMACRO) $< -o $@ %.o:%.s $(ARMASM) $(ASMFLAGS) $(INC) $< -o $@ mytarget:$(OBJS) $(ARMLINK) $(LINKFLAGS) --libpath "$(KEIL_PATH)RV31LIB" --scatter=$(DRIVER_PATH)/Project/mytarget.sct $(MAP) $(INFO) --list $(TARGET).map $^ $(DRIVER_PATH)LibrariesSTM32F10xR_V3.0.lib --output=$(TARGET).axf $(FROMELF) --bin -o $(TARGET).bin $(TARGET).axf $(FROMELF) --i32 -o $(TARGET).hex $(TARGET).axf del $(OBJHTM) $(OBJAXF) $(OBJS) echo ### Created! .PHONY : clean clean: del $(OBJS) *.map *.htm 还记得我们在实现自动配置模型参数的时候有这么一句吗?它是什么作用呢? set_param(cs,‘PostCodeGenCommand’,‘mytarget_postgen(buildInfo)’); 这条语句设置了代码生成之后的回调函数,mytarget_postgen这个m语言的函数主要实现将模型生成的c文件拷贝到指定路径的功能,同时输出过程信息,如果指定的路径下已经有C文件,则先删除。 function mytarget_postgen(buildInfo) disp('MyTarget postgen process!'); currentpath = pwd; modelName = buildInfo.MODELNAME cs = getActiveConfigSet(modelName); % Get target path from model configuration CodePath = get_param(cs,'tlc_code_output'); BinPath = get_param(cs,'tlc_bin_output'); cd(currentpath); % Display work path str = ['Current path is : ', currentpath]; disp(str); str = ['Code will be generated to : ', CodePath]; disp(str); str = ['Binary will be generated to : ', BinPath]; disp(str); % Delete old files cd(CodePath); disp('Delete old files......'); oldcfiles =dir(fullfile(CodePath,'*.c')); for i = 1:length(oldcfiles) delete(oldcfiles(i).name); str = ['Delete old source file : ',oldcfiles(i).name]; disp(str); end oldhfiles =dir(fullfile(CodePath,'*.h')); for i = 1:length(oldhfiles) delete(oldhfiles(i).name); str = ['Delete old header file : ',oldhfiles(i).name]; disp(str); end cd(currentpath); % Copy new files to code path disp('Copy new files......'); cfiles = dir(fullfile(pwd,'*.c')); hfiles = dir(fullfile(pwd,'*.h')); for i = 1:length(cfiles) copyfile(cfiles(i).name,CodePath); str = ['Copy C source file : ',cfiles(i).name]; disp(str); end for i = 1:length(hfiles) copyfile(hfiles(i).name,CodePath); str = ['Copy C header file : ',hfiles(i).name]; disp(str); end end OK,像上次一样,我们的模型里只放置一个进行模型配置的模块,我们点击Build按钮,稍等片刻会弹出代码生成的报告,和上次一样,这次我们再进一步,打开Diagnostic View,可以看到,除了生成了demo这个模型的c文件和makefile文件demo.mk,还如我们预期的进行了copy和编译的操作。 before tlc ### Invoking Target Language Compiler on demo.rtw ### Using System Target File: E:Workspacematlabmytarget_toolboxmytargetmytarget.tlc ### Loading TLC function libraries ### Initial pass through model to cache user defined code . ### Caching model source code ### Writing header file demo_types.h ### Writing header file demo.h ### Writing header file rtwtypes.h . ### Writing source file demo.c ### Writing header file demo_private.h ### Writing header file rtmodel.h ### Writing source file main.c ### TLC code generation complete. ### Generating TLC interface API. . ### Creating ASAP2 file: demo.a2l ### Indenting ASAP2 file. after tlc ### Evaluating PostCodeGenCommand specified in the model MyTarget postgen process! modelName = 'demo' Current path is : E:Workspacematlabdemodemo_mytarget_rtw Code will be generated to : E:Workspacematlabcode Binary will be generated to : E:Workspacematlabbin Delete old files...... Delete old source file : demo.c Delete old source file : main.c Delete old header file : demo.h Delete old header file : demo_private.h Delete old header file : demo_types.h Delete old header file : rtmodel.h Delete old header file : rtwtypes.h Copy new files...... Copy C source file : demo.c Copy C source file : main.c Copy C header file : demo.h Copy C header file : demo_private.h Copy C header file : demo_types.h Copy C header file : rtmodel.h Copy C header file : rtwtypes.h before_make . ### Processing Template Makefile: E:Workspacematlabmytarget_toolboxmytargetmytarget.tmf ### Wrapping unrecognized make command (angle brackets added) ### ### in default batch file ### demo.mk which is generated from E:Workspacematlabmytarget_toolboxmytargetmytarget.tmf is up to date ### Building demo: .demo.bat E:Workspacematlabdemodemo_mytarget_rtw>set MATLAB=D:Program FilesMatlab2017b E:Workspacematlabdemodemo_mytarget_rtw>C:TDM-GCC-64binmake -f demo.mk GENERATE_ASAP2=1 C:KeilARMBIN40armcc -c --cpu Cortex-M3 -D__MICROLIB -g -O0 --apcs=interwork - ------------这里省略各种编译输出信息------------- E:Workspacematlabmytarget_toolboxsrcLibrariesCMSISsystem_stm32f10x.o E:Workspacematlabmytarget_toolboxsrcLibrariesCMSISstm32f10x_it.o echo ### Created! ### Created! after_make Model demo Code genrattion complete for mytarget! ### Creating HTML report file demo_codegen_rpt.html Build process completed successfully 打开设定的Binary文件输出路径,可以看到bin、hex和map文件已经生成到这里。 到这一步,Simulink Toolbox从模型配置到代码生成,再到自动化代码编译的主体流程已经串通,后面要做的就是要针对硬件开发各种外设的模块级S-Function和TLC,在调试过程中不断进行驱动工程的完善和调整。 |
1927 浏览 1 评论
1697 浏览 1 评论
1180 浏览 2 评论
779 浏览 2 评论
1745 浏览 2 评论
1984浏览 9评论
818浏览 4评论
268浏览 3评论
633浏览 3评论
637浏览 3评论
GMT+8, 2025-1-31 10:51 , Processed in 0.682760 second(s), Total 77, Slave 61 queries .
