1.FreeRTOS的配置
见文章 https://blog.csdn.net/weixin_39092315/article/details/108343954?spm=1001.2014.3001.5501 2.串口配置 //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB, ENABLE); //使能USART1,GPIOA时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE); //使能USART1,GPIOA时钟 //USART1_TX GPIOA.9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化GPIOA.9 //USART1_RX GPIOA.10初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PA10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化GPIOA.10 //USART3_TX GPIOB.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PB.10 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化GPIOA.9 //USART3_RX GPIOB.11初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //PB11 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入 GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化GPIOA.10 //Usart1 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ; //抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //Usart3 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ; //抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //USART 初始化设置 USART_InitStructure.USART_BaudRate = bound; //串口波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b; //字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1; //一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No; //无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口1 USART_Init(USART3, &USART_InitStructure); //初始化串口3 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); //开启串口接受中断 USART_ITConfig(USART3, USART_IT_IDLE, ENABLE); //开启串口接受中断 USART_Cmd(USART1, ENABLE); //使能串口1 USART_Cmd(USART3, ENABLE); //使能串口3 } ``` 这里配置串口1/2的方式和普通的方式基本一致,但是需要注意中断的优先级: FreeRTOSconfig.h的 **“系统可管理优先级“#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5 ** //系统可管理的最高中断优先级 意味着中断的优先级不能小于5,因为在FreeRTOS中数字越小优先级越高,所以我们需要取7,小于5大于32即可。 ## 3.任务初始化 ```//任务优先级 #define START_TASK_PRIO 1 //任务堆栈大小 #define START_STK_SIZE 128 //任务句柄 TaskHandle_t StartTask_Handler; //任务函数 void start_task(void *pvParameters); //任务优先级 #define UART_TASK_PRIO 2 //任务堆栈大小 #define UART_STK_SIZE 50 //任务句柄 TaskHandle_t UARTTask_Handler; //任务函数 void UART_task(void *pvParameters); 这里定义了两个任务,优先级-运行内存-任务句柄-任务名称声明,运行内存C8只有10个1024,注意省着点。 4.主函数配置 { NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//设置系统中断优先级分组4 delay_init(); //延时函数初始化 uart_init(115200); //初始化串口 LED_Init(); //初始化LED //创建开始任务 xTaskCreate((TaskFunction_t )start_task, //任务函数 (const char* )"start_task", //任务名称 (uint16_t )START_STK_SIZE, //任务堆栈大小 (void* )NULL, //传递给任务函数的参数 (UBaseType_t )START_TASK_PRIO, //任务优先级 (TaskHandle_t* )&StartTask_Handler); //任务句柄 vTaskStartScheduler(); //开启任务调度 }``` 中断优先级分组默认为4,,具体看注释即可。在这创建开始任务后,程序运行就不局限于main函数里了,开始由内核接管,开始任务调度的进程管理。 //开始任务任务函数 void start_task(void *pvParameters) { taskENTER_CRITICAL(); //进入临界区 //创建UART任务 xTaskCreate((TaskFunction_t )UART_task, (const char* )"UART_task", (uint16_t )UART_STK_SIZE, (void* )NULL, (UBaseType_t )UART_TASK_PRIO, (TaskHandle_t* )&UART_Handler); vTaskDelete(StartTask_Handler); //删除开始任务 taskEXIT_CRITICAL(); //退出临界区 } 在main函数里创建完开始任务函数后,内核就会调用这个start_task任务,执行里面的语句,临界区的作用就是屏蔽外部中断、任务调度等,防止临界区内的代码被打断。但是尽量用在重要的地方。 start_task任务的作用就是创建真正的需要做的事情。 ```void UART_task(void *pvParameters) { while(1) { printf("111"); vTaskDelay(500); } } 创建任务后,就开始调用任务了。vTaskDelay(500)的作用就是告诉内核,我需要500ms的空闲时间,在这500ms中,内核就可以去调用其他任务(这里没有),如果每个任务都需要空闲时间,那么内核就会调用空闲任务。当空闲时间到了之后,内核就会按照到达的时间顺序执行任务,这时候就会有优先级的问题,详情请见手册介绍。 后,就开始调用任务了。vTaskDelay(500)的作用就是告诉内核,我需要500ms的空闲时间,在这500ms中,内核就可以去调用其他任务(这里没有),如果每个任务都需要空闲时间,那么内核就会调用空闲任务。当空闲时间到了之后,内核就会按照到达的时间顺序执行任务,这时候就会有优先级的问题,详情请见手册介绍。 注:printf是基于UART1包装的,可以基于此开拓。 后面应该会更新DMA的版本 MATLAB的温度曲线串口处理脚本与实时画图小白 1.https://blog.csdn.net/weixin_39092315/article/details/116334084 STM32F103C8T6+FreeRTOS+USART1、3 2.https://blog.csdn.net/weixin_39092315/article/details/116329689 在STM32上实现FuzzyPID(理论与代码实现) 3.https://blog.csdn.net/weixin_39092315/article/details/116382016 STM32的HAL库实现定时器TIM6和计算方法 4.https://blog.csdn.net/weixin_39092315/article/details/115432035 初识STM32与其选型 5.https://blog.csdn.net/weixin_39092315/article/details/115432035 STM32F103C8T6及其系列的FreeRTOS移植 6.https://blog.csdn.net/weixin_39092315/article/details/108343954 |
1928 浏览 1 评论
1701 浏览 1 评论
1181 浏览 2 评论
781 浏览 2 评论
1747 浏览 2 评论
1989浏览 9评论
823浏览 4评论
273浏览 3评论
635浏览 3评论
639浏览 3评论
GMT+8, 2025-2-1 20:40 , Processed in 0.669510 second(s), Total 42, Slave 37 queries .
